OneWire devices not found when using platformio
When I compile and upload the “Multiple” example sketch from the Arduino DallasTemperature library using the Arduino IDE, my DS18B20 temperature sensors work fine. If I upload the same sketch with PlatformIO, no sensors are detected.
I have no idea what is going on… As long as the issue persists I will be forced to ditch PlatformIO for the regular Arduino IDE.
You get no error or missing library message at all? Sometimes I include <Arduino.h> just to force it…
Have you tried other pin numbers? Pin numbers may differ in platformio!
#define ONE_WIRE_BUS 2
I found out that I need to change code regularly to work within platformio while it works as-is from the Arduino IDE. I also have one sensor I cannot get working at all and it works fine with the Arduino IDE. So for 80% of my projects I get away with this MUCH better IDE but sometimes I still need the Arduino IDE.
I’m having the same problem. The identical code works when compiled and uploaded via the Arduino IDE and fails when compiled and uploaded with PlatformIO. Made sure to use the same library on both. No luck.
EDIT: Seems to have something to do with threads. When I scan the bus from the main setup/loop there’s no problem. I suspect the DallasTemperature library is also using a separate thread to do its work as well and this may be the root issue.
After few hours of searching I found something.
I’m using stm32 board (STM32F104C8) it has OneWireSTM library in framework-arduinoststm32 package.
So to use it you have to manually edit DallasTemperature to include OneWireSTM.h, but it is not everything :frowning: as compiler will not see this lib till you will change platform to ststm32@~4.5.0 in platform.ini file.
Result:
platform.ini:
[env:genericSTM32F103C8]
build_flags=-D STM32_OFFICIAL_CORE
platform = ststm32@~4.5.0
board = genericSTM32F103C8
upload_protocol = serial
upload_port = COM3
.piolibdeps\DallasTemperature_ID54\DallasTemperature.h:
#include <inttypes.h>
#include <OneWireSTM.h>
// Model IDs
#define DS18S20MODEL 0x10
main.ccp
#define REQUIRESALARMS false
#include <DallasTemperature.h>
OneWire bus(PB9);
DallasTemperature ds(&bus);
void setup()
  Serial.begin(9600);
  ds.begin();
  ds.setResolution(9);
  Serial.println("Set up done");
void loop()
  Serial.print("Number of devices found:");
  Serial.println(ds.getDeviceCount());
  delay(1500);
RESULT:
Number of devices found:2
I have same problem.
Device NodeMcu v3 use DS18B20 sensors no D2 port (GPI04)
platformio.ini
[env:nodemcuv2]
platform = espressif8266
board = nodemcuv2
lib_debs=
    OneWire
    DallasTemperature
main.cpp
#include <OneWire.h>
#define esp_birate 9600
#define one_wire_bus D2 // also try one_wire_bus 4 as GPI04
OneWire oneWire(one_wire_bus);
DallasTemperature sensors(&oneWire);
  Serial.begin(esp_birate);
  sensors.begin();
  Serial.print("Numbers of devices found: " + String(sensors.getDS18Count()) + "\n");
  delay(5000);
Serial Monitor:
Numbers of devices found: 0
And the same code using Arduino IDE produces what output?
Do you have the pullup resistor on D2/GPIO2? 4.7k is the typically recommended value, but I’ve found in some instances lower values like 2.2k has worked better with the 3.3v ESP8266 stuff.
I’m also seeing this issue and cannot understand why it happens - I’ve even tried copying the core files from Arduino IDE into Platformio and vice-versa but the result is the same.
A workaround exists, however - either downgrade to OneWire v2.3.2 or “search” for the OneWire devices twice (e.g. if using the DallasTemperature library, call begin() twice).
This is also discussed here: DS18B20 always reading 85 or -127 · Issue #253 · platformio/platform-espressif32 · GitHub
Hi @photomoose,
I saw your code on the link you provided above. I don’t see a `#include “Arduino.h” anywhere, is there one? I think there should be, and possibly more.
The Arduino IDE goes through various hoops to identify any header files not explicitly included in the sketch. Under PlatformIO, it is your responsibility.
Arduino.h is needed when using the Arduino framework, setup() and loop(). It might be that including that file will pull in some configuration that the ESP needs? I don’t have one, so I’m not sure.
Having said/typed that, I’m pretty sure there would be compilation errors, but you never know.
It probably doesn’t explain why the ESP needs to begin() twice to find devices. :frowning_face:.
Good luck.
Cheers,
Nirm.
Hi @normandunbar,
Yes, when compiling/uploading with Platformio, I can confirm that the very first line was the include statement for Arduino.h.
It’s looks like some sort of weird behaviour between the version of the OneWire library and Platformio:
Arduino IDE + OneWire v2.3.5 —> works OK
Platformio + OneWire v2.3.5 —> does not work, requires two calls to begin()
Arduino IDE + OneWire v.2.3.2 --> works OK
Platformio + OneWire v.2.3.2 --> works OK
For what platformio.ini and example code exactly does this behavior occur? We can do a binary difference analysis…
Also please mention the Arduino IDE version and Arduino IDE platform / board package version (e.g. for AVR or ESP8266) that is being used here.
Hello again @photomoose,
I figured it was a long shot, but I had to ask!
Cheers,
Norm.
platformio.ini
[env:featheresp32]
board = featheresp32
upload_port = /dev/cu.SLAB_USBtoUART
upload_speed = 921600
	OneWire@^2.3.5
main.cpp
OneWire oneWire(21);
void search() {
    uint8_t count = 0;
    Serial.println("Searching for devices...");
    oneWire.reset_search();
    byte deviceAddress[8];
    while (oneWire.search(deviceAddress)) {
        count++;
        Serial.print("Found Device:");
        for (int i = 0; i < 8; i++) {
            Serial.write(' ');
            Serial.print(deviceAddress[i], HEX);
        Serial.println();
    Serial.printf("Found %d devices\r\n", count);
    // First call returns 0 devices when using Platformio
    search();
    // Second call works
    search();
Arduino IDE: v1.8.10
Board: Adafruit ESP32 Feather
Using board 'featheresp32' from platform in folder: /Users/photomoose/Library/Arduino15/packages/esp32/hardware/esp32/1.0.4
Using core 'esp32' from platform in folder: /Users/photomoose/Library/Arduino15/packages/esp32/hardware/esp32/1.0.4
I am facing the same issue with ESP8266. First search doesn’t work, second does. I tried to trace why, but I just can’t figure it out…
I’m having similar issue with an stm32l051c8t6 based board in PlatformIO. Same code/libraries work in ArduinoIDE but in PlatformIO the ds18s20 is not detected.
Anyone have any thoughts on how to troubleshoot? Since the device is not detected I’m just running the Onewire library for now. This is the code I use
platform.ini
[env:stm32l051c8t6]
platform = ststm32
board = minipill_l051c8_lora
board_build.core = STM32L0
upload_protocol = stlink
lib_deps = paulstoffregen/OneWire@^2.3.2
main.cpp:
// OneWire DS18S20, DS18B20, DS1822 Temperature Example
// http://www.pjrc.com/teensy/td_libs_OneWire.html
// The DallasTemperature library can do all this work for you!
// https://github.com/milesburton/Arduino-Temperature-Control-Library
OneWire  ds(PA5);  // on pin 10 (a 4.7K resistor is necessary)
void setup(void) {
  Serial.begin(9600);
void loop(void) {
  byte i;
  byte present = 0;
  byte type_s;
  byte data[9];
  byte addr[8];
  float celsius, fahrenheit;
  if ( !ds.search(addr)) {
    Serial.println("No more addresses.");
    Serial.println();
    ds.reset_search();
    delay(250);
    return;
  Serial.print("ROM =");
  for( i = 0; i < 8; i++) {
    Serial.write(' ');
    Serial.print(addr[i], HEX);
  if (OneWire::crc8(addr, 7) != addr[7]) {
      Serial.println("CRC is not valid!");
      return;
  Serial.println();
  // the first ROM byte indicates which chip
  switch (addr[0]) {
    case 0x10:
      Serial.println("  Chip = DS18S20");  // or old DS1820
      type_s = 1;
      break;
    case 0x28:
      Serial.println("  Chip = DS18B20");
      type_s = 0;
      break;
    case 0x22:
      Serial.println("  Chip = DS1822");
      type_s = 0;
      break;
    default:
      Serial.println("Device is not a DS18x20 family device.");
      return;
  ds.reset();
  ds.select(addr);
  ds.write(0x44, 1);        // start conversion, with parasite power on at the end
  delay(1000);     // maybe 750ms is enough, maybe not
  // we might do a ds.depower() here, but the reset will take care of it.
  present = ds.reset();
  ds.select(addr);
  ds.write(0xBE);         // Read Scratchpad
  Serial.print("  Data = ");
  Serial.print(present, HEX);
  Serial.print(" ");
  for ( i = 0; i < 9; i++) {           // we need 9 bytes
    data[i] = ds.read();
    Serial.print(data[i], HEX);
    Serial.print(" ");
  Serial.print(" CRC=");
  Serial.print(OneWire::crc8(data, 8), HEX);
  Serial.println();
  // Convert the data to actual temperature
  // because the result is a 16 bit signed integer, it should
  // be stored to an "int16_t" type, which is always 16 bits
  // even when compiled on a 32 bit processor.
  int16_t raw = (data[1] << 8) | data[0];
  if (type_s) {
    raw = raw << 3; // 9 bit resolution default
    if (data[7] == 0x10) {
      // "count remain" gives full 12 bit resolution
      raw = (raw & 0xFFF0) + 12 - data[6];
  } else {
    byte cfg = (data[4] & 0x60);
    // at lower res, the low bits are undefined, so let's zero them
    if (cfg == 0x00) raw = raw & ~7;  // 9 bit resolution, 93.75 ms
    else if (cfg == 0x20) raw = raw & ~3; // 10 bit res, 187.5 ms
    else if (cfg == 0x40) raw = raw & ~1; // 11 bit res, 375 ms
    //// default is 12 bit resolution, 750 ms conversion time
  celsius = (float)raw / 16.0;
  fahrenheit = celsius * 1.8 + 32.0;
  Serial.print("  Temperature = ");
  Serial.print(celsius);
  Serial.print(" Celsius, ");
  Serial.print(fahrenheit);
  Serial.println(" Fahrenheit");
