This is ESP Now. The problem must be in the receiver, because the sender is printing the correct number to Serial.
It’s readingId: readingId = readingId + 1;
The receiver was printing a huge number. I fiddled a bit, and it went to zero. But dig this:
ID value: 1.74
readingID: 0
Is the response to:
Serial.printf("ID value: %4.2f \n", myData.readingId);
Serial.printf("readingID: ");
Serial.print(myData.readingId);
Now it’s consistently 1.74 AND 0.
Any idea what goes on here?
One of the pods was read correctly. I forget which one. Pod 1 and Pod 3 are out of commission. But two of the pods’ “reading ID” was consistently wrong.
This is the receiver code. It’s been here before.
I can’t see any place where “readingId” could be modified.
#include <esp_now.h>
#include <WiFi.h>
#include <Wire.h>
#include "ESPAsyncWebServer.h"
#include "Adafruit_GFX.h"
#include "Fonts/FreeMono12pt7b.h"
#include "Fonts/FreeMono9pt7b.h"
#include <MCUFRIEND_kbv.h>
#include <NTPClient.h>
#include <WiFiUdp.h>
#include "SPIFFS.h"
#define NTP_OFFSET -14400 // In seconds
#define NTP_INTERVAL 60 * 1000 // In miliseconds
#define NTP_ADDRESS "pool.ntp.org"
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define RED 0xF800
#define YELLOW 0xFFE0
#define BLACK 0x0000
#define PINK 0xFC9F
#define AQUA 0x04FF
#define WHITE 0xFFFF
// Replace with your network credentials (STATION)
const char *ssid = "TP-Link_7C28";
const char *password = "64411811";
unsigned int readingId = 0;
// Structure example to receive data
// Must match the sender structure
typedef struct struct_message
int id;
float temperature;
float humidity;
float pressure;
float Gas;
float CO;
float smoke;
float moisture;
float UV;
float CO2;
float NH3;
float NO2;
float VOC;
float H2;
float EtOH;
unsigned int readingId;
} struct_message;
struct_message myData;
WiFiUDP ntpUDP;
NTPClient timeClient(ntpUDP, NTP_ADDRESS, NTP_OFFSET, NTP_INTERVAL);
MCUFRIEND_kbv tft;
AsyncWebServer server(80);
AsyncEventSource events("/events");
// callback function that will be executed when data is received
void OnDataRecv(const uint8_t *mac_addr, const uint8_t *incomingData, int len)
// Copies the sender mac address to a string
char macStr[18];
Serial.print("Packet received from: ");
snprintf(macStr, sizeof(macStr), "%02x:%02x:%02x:%02x:%02x:%02x",
mac_addr[0], mac_addr[1], mac_addr[2], mac_addr[3], mac_addr[4], mac_addr[5]);
Serial.println(macStr);
memcpy(&myData, incomingData, sizeof(myData));
Serial.printf("Board ID %u: %u bytes\n", myData.id, len);
Serial.printf("t value: %4.2f \n", myData.temperature);
Serial.printf("h value: %4.2f \n", myData.humidity);
Serial.printf("p value: %4.2f \n", myData.pressure);
Serial.printf("v value: %4.2f \n", myData.VOC);
Serial.printf("v value: %4.2f \n", myData.CO);
Serial.printf("v value: %4.2f \n", myData.Gas);
Serial.printf("v value: %4.2f \n", myData.smoke);
Serial.printf("v value: %4.2f \n", myData.moisture);
Serial.printf("v value: %4.2f \n", myData.UV);
Serial.printf("v value: %4.2f \n", myData.CO2);
Serial.printf("v value: %4.2f \n", myData.NH3);
Serial.printf("v value: %4.2f \n", myData.NO2);
Serial.printf("v value: %4.2f \n", myData.H2);
Serial.printf("v value: %4.2f \n", myData.EtOH);
Serial.println();
const char index_html[] PROGMEM = R"rawliteral(
<!DOCTYPE HTML><html>
<head>
<title>Monster Laboratories Smart Home</title>
<meta name="viewport" content="width=device-width, initial-scale=1">
<link rel="stylesheet" href="data/monsterlaboratories.css" integrity="sha384-fnmOCqbTlWIlj8LyTjo7mOUStjsKC4pOpQbqyi7RrhN7udi9RwhKkMHpvLbHG9Sr" crossorigin="anonymous">
<link rel="icon" href="data:,">
<style>
html {font-family: Arial; display: inline-block; text-align: center;}
p { font-size: 1.2rem;}
body { margin: 0;}
.topnav { overflow: hidden; background-color: #2f4468; color: white; font-size: 1.7rem; }
.content { padding: 20px; }
.card { background-color: white; box-shadow: 2px 2px 12px 1px rgba(140,140,140,.5); }
.cards { max-width: 700; margin: 0 auto; display: grid; grid-gap: 2rem; grid-template-columns: repeat(auto-fit, minmax(700px, 1fr)); }
.reading { font-size: 2.8rem; }
.packet { color: #bebebe; }
.card.temperature { color: #fa8602; }
.card.humidity { color: #02fab8; }
.card.pressure { color: #204773; }
.card.UV { color: #e502fa; }
.card.CO { color: #4c5959; }
.card.CO2 { color: #47555e; }
.card.Gas { color: #62376e; }
.card.VOC { color: #45112e; }
</style>
</head>
<body>
<div class="topnav">
<h3>Monster Laboratories SmartHome- Air Quality</h3>
</div>
<table width = 950 border = 0 class="cards" >
<tr><td valign = "top">
<div class="card temperature">
<h4><i class="fas fa-thermometer-half"></i> Pod 1 - TEMPERATURE</h4>
<p><span class="reading"><span id="t1"></span> °C</span></p>
<p class="packet">ID: <span id="rt1"></span></p>
</div>
</td><td valign = "top">
<h4><i class="fas fa-thermometer-half"></i> Pod 2 - TEMPERATURE</h4>
<p><span class="reading"><span id="t2"></span> °C</span></p>
<p class="packet">ID: <span id="rt2"></span></p>
</div>
<h4><i class="fas fa-thermometer-half"></i> Pod 3 - TEMPERATURE</h4>
<p><span class="reading"><span id="t3"></span> °C</span></p>
<p class="packet">ID: <span id="rt3"></span></p>
</div>
<div class="card UV">
<h4><i class="fas fa-radiation"></i> Pod 3 - UVindex</h4>
<p><span class="reading"><span id="u3"></span> x</span></p>
<p class="packet">ID: <span id="ru3"></span></p>
</div>
</td></tr>
<tr>
<td valign = "top">
<div class="card humidity">
<h4><i class="fas fa-tint"></i> Pod 1 - HUMIDITY</h4>
<p><span class="reading"><span id="h1"></span> %</span></p>
<p class="packet">ID: <span id="rh1"></span></p>
</div>
</td>
<td valign = "top">
<h4><i class="fas fa-tint"></i> Pod 2 - HUMIDITY</h4>
<p><span class="reading"><span id="h2"></span> %</span></p>
<p class="packet">ID: <span id="rh2"></span></p>
</div>
</td>
<td valign = "top">
<h4><i class="fas fa-tint"></i> Pod 3 - HUMIDITY</h4>
<p><span class="reading"><span id="h3"></span> %</span></p>
<p class="packet">ID: <span id="rh3"></span></p>
</div>
</td>
<td valign = "top">
<div class="card smoke">
<h4><i class="fas fa-tint"></i> Pod 3 - SMOKE</h4>
<p><span class="reading"><span id="s3"></span> </span></p>
<p class="packet">ID: <span id="rs3"></span></p>
</div>
</td></tr>
<tr>
<td valign = "top">
<div class="card pressure">
<h4><i class='fas fa-cloud-download-alt'></i> Pod 1 - PRESSURE</h4>
<p><span class="reading"><span id="p1"></span> "Hg</span></p>
<p class="packet">ID: <span id="rp1"></span></p>
</div>
</td>
<td valign = "top">
<h4><i class='fas fa-cloud-download-alt'></i> Pod 2 - PRESSURE</h4>
<p><span class="reading"><span id="p2"></span> "Hg</span></p>
<p class="packet">ID: <span id="rp2"></span></p>
</div>
<h4><i class='fas fa-cloud-download-alt'></i> Pod 3 - PRESSURE</h4>
<p><span class="reading"><span id="p3"></span> "Hg</span></p>
<p class="packet">ID: <span id="rp3"></span></p>
</div>
</td></tr>
<tr>
<td valign = "top">
<div class="card voc">
<h4><i class='fas fa-cloud-download-alt'></i> Pod 1 - VOC</h4>
<p><span class="reading"><span id="v1"></span> </span></p>
<p class="packet">ID: <span id="rv1"></span></p>
</div>
<h4><i class='fas fa-cloud-download-alt'></i> Pod 2 - VOC</h4>
<p><span class="reading"><span id="v2"></span> </span></p>
<p class="packet">ID: <span id="rv2"></span></p>
</div>
<h4><i class='fas fa-cloud-download-alt'></i> Pod 3 - VOC</h4>
<p><span class="reading"><span id="v3"></span> </span></p>
<p class="packet">ID: <span id="rv3"></span></p>
</div>
</td></tr>
<tr>
<td valign = "top">
<div class="card CO">
<h4><i class="fas fa-skull-crossbones"></i> Pod 2 - CO</h4>
<p><span class="reading"><span id="c2"></span> </span></p>
<p class="packet">ID: <span id="rc2"></span></p>
</div>
<div class="card Gas" >
<h4><i class="fa fa-cloud"></i> Pod 2 - Gas</h4>
<p><span class="reading"><span id="g2"></span> </span></p>
<p class="packet">ID: <span id="rg2"></span></p>
</div>
</td></tr></table>
</div>
</div>
<script>
if (!!window.EventSource) {
var source = new EventSource('/events');
source.addEventListener('open', function(e) {
console.log("Events Connected");
}, false);
source.addEventListener('error', function(e) {
if (e.target.readyState != EventSource.OPEN) {
console.log("Events Disconnected");
}, false);
source.addEventListener('message', function(e) {
console.log("message", e.data);
}, false);
source.addEventListener('new_readings', function(e) {
console.log("new_readings", e.data);
var obj = JSON.parse(e.data);
document.getElementById("t"+obj.id).innerHTML = obj.temperature.toFixed(0);
document.getElementById("h"+obj.id).innerHTML = obj.humidity.toFixed(0);
document.getElementById("p"+obj.id).innerHTML = obj.pressure.toFixed(0);
document.getElementById("u"+obj.id).innerHTML = obj.UV.toFixed(0);
document.getElementById("c"+obj.id).innerHTML = obj.CO.toFixed(0);
document.getElementById("o"+obj.id).innerHTML = obj.CO2.toFixed(0);
document.getElementById("g"+obj.id).innerHTML = obj.Gas.toFixed(0);
document.getElementById("v"+obj.id).innerHTML = obj.VOC.toFixed(0);
document.getElementById("s"+obj.id).innerHTML = obj.smoke.toFixed(0);
document.getElementById("rt"+obj.id).innerHTML = obj.readingId;
document.getElementById("rh"+obj.id).innerHTML = obj.readingId;
document.getElementById("rp"+obj.id).innerHTML = obj.readingId;
document.getElementById("ru"+obj.id).innerHTML = obj.readingId;
document.getElementById("rc"+obj.id).innerHTML = obj.readingId;
document.getElementById("ro"+obj.id).innerHTML = obj.readingId;
document.getElementById("rg"+obj.id).innerHTML = obj.readingId;
document.getElementById("rv"+obj.id).innerHTML = obj.readingId;
document.getElementById("rs"+obj.id).innerHTML = obj.readingId;
console.log(obj.readingId);
}, false);
</script>
</body>
</html>)rawliteral";
void setup()
// Initialize Serial Monitor
Serial.begin(9600);
uint16_t ID = tft.readID();
tft.begin(ID);
// Set the device as a Station and Soft Access Point simultaneously
WiFi.mode(WIFI_AP_STA);
// Set device as a Wi-Fi Station
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED)
delay(1000);
Serial.println("Setting as a Wi-Fi Station..");
Serial.print("Station IP Address: ");
Serial.print("Wi-Fi Channel: ");
Serial.println(WiFi.channel());
// Init ESP-NOW
if (esp_now_init() != ESP_OK)
Serial.println("Error initializing ESP-NOW");
return;
// Once ESPNow is successfully Init, we will register for recv CB to
// get recv packer info
esp_now_register_recv_cb(OnDataRecv);
server.on("/", HTTP_GET, [](AsyncWebServerRequest *request)
{ request->send_P(200, "text/html", index_html); });
events.onConnect([](AsyncEventSourceClient *client)
if(client->lastId()){
Serial.printf("Client reconnected! Last message ID that it got is: %u\n", client->lastId());
// send event with message "hello!", id current millis
// and set reconnect delay to 1 second
client->send("hello!", NULL, millis(), 10000); });
server.addHandler(&events);
server.begin();
void loop()
float dewpoint = (myData.temperature - (100 - myData.humidity)/5);
float heatIndex = 0.5 * (myData.temperature + 61.0) + ((myData.temperature - 68.0) * 1.2) + (myData.humidity * 0.094);
float UV = 0;
UV = (myData.UV/700);
timeClient.update();
String formattedTime = timeClient.getFormattedTime();
tft.setFont(&FreeMono9pt7b);
tft.fillScreen(BLACK);
tft.setTextSize(1);
tft.setTextColor(YELLOW);
tft.setCursor(1, 20);
tft.print("Station IP : ");
tft.println(WiFi.localIP());
tft.setFont(&FreeMono12pt7b);
tft.setTextColor(WHITE);
tft.print("Time: ");
tft.println(formattedTime);
if (myData.id == 1)
tft.setTextColor(CYAN);
else if (myData.id == 2)
tft.setTextColor(PINK);
else if (myData.id == 3)
tft.setTextColor(AQUA);
tft.print("Board ID: ");
tft.println(myData.id);
tft.print("Temperature: ");
tft.print(myData.temperature, 0);
tft.println("*C");
tft.print("Heat Index: ");
tft.print(heatIndex, 0);
tft.println();
tft.print("Pressure: ");
tft.print(myData.pressure, 0);
tft.println(" in Hg");
tft.print("Humidity: ");
tft.print(myData.humidity, 0);
tft.println("%");
tft.print("Dewpoint: ");
tft.print(dewpoint, 0);
tft.println("*C");
tft.print("Moisture: ");
tft.print(myData.moisture, 0);
tft.println("%");
tft.print("Smoke: ");
tft.println(myData.smoke, 0);
tft.print("Uv index: ");
tft.print(UV, 0);
tft.setCursor(1, 290);
tft.print("Gas: ");
tft.println(myData.Gas, 0);
tft.print("CO: ");
tft.println(myData.CO, 0);
tft.print("CO2: "),
tft.println(myData.CO2, 0);
tft.print("VOC: ");
tft.println(myData.VOC, 0);
tft.setCursor(150, 290);
tft.print("H2: ");
tft.println(myData.H2, 0);
tft.setCursor(150, 315);
tft.print("EtOH:");
tft.println(myData.EtOH, 0);
tft.setCursor(150, 340);
tft.print("NH3: ");
tft.println(myData.NH3, 0);
tft.setCursor(150, 365);
tft.print("NO2: "),
tft.println(myData.NO2, 0);
tft.print("Reading ID: ");
tft.println(myData.readingId);
tft.println();
delay(15000);
