Official LittleFS support for the ESP32
I’ve been reading through all the threads on how to get LittleFS up and running for the ESP32 and it seems to be a bit of a pain. Are we any closer to having official support for it on the ESP32?
I notice that the latest of the arduino-esp32 - GitHub - espressif/arduino-esp32: Arduino core for the ESP32 - now has LittleFS built into it.
This is already tracked in Add LittleFS and FFat filesystem support · Issue #570 · platformio/platform-espressif32 · GitHub, unless developers implement it in the official platforms, one can only wait or use custom modifications.
for some reason i’m getting all sorts of issues getting LittleFS to run on VSC with PlatformIO on LOLIN S3 board.
It all works fine when I compile code on Arduino IDE but not with VSC + PlatformIO.
Its driving me nuts :slight_smile:
Any help would be appreciated.
This is the error I get with VSC + PlatformIO (I’m using latest libraries)
My platformio.ini file =
[env:lolin_s3]
board = lolin_s3
board_build.partitions = default_8MB.csv
and my main.cpp is =
#include "FS.h"
#include <LittleFS.h>
#define FORMAT_LITTLEFS_IF_FAILED true
void listDir(fs::FS &fs, const char *dirname, uint8_t levels)
  Serial.printf("Listing directory: %s\r\n", dirname);
  File root = fs.open(dirname);
  if (!root)
    Serial.println("- failed to open directory");
    return;
  if (!root.isDirectory())
    Serial.println(" - not a directory");
    return;
  File file = root.openNextFile();
  while (file)
    if (file.isDirectory())
      Serial.print("  DIR : ");
      Serial.println(file.name());
      if (levels)
        listDir(fs, file.path(), levels - 1);
    else
      Serial.print("  FILE: ");
      Serial.print(file.name());
      Serial.print("\tSIZE: ");
      Serial.println(file.size());
void createDir(fs::FS &fs, const char *path)
  Serial.printf("Creating Dir: %s\n", path);
  if (fs.mkdir(path))
    Serial.println("Dir created");
  else
    Serial.println("mkdir failed");
void removeDir(fs::FS &fs, const char *path)
  Serial.printf("Removing Dir: %s\n", path);
  if (fs.rmdir(path))
    Serial.println("Dir removed");
  else
    Serial.println("rmdir failed");
void readFile(fs::FS &fs, const char *path)
  Serial.printf("Reading file: %s\r\n", path);
  File file = fs.open(path);
  if (!file || file.isDirectory())
    Serial.println("- failed to open file for reading");
    return;
  Serial.println("- read from file:");
  while (file.available())
    Serial.write(file.read());
  file.close();
void writeFile(fs::FS &fs, const char *path, const char *message)
  Serial.printf("Writing file: %s\r\n", path);
  File file = fs.open(path, FILE_WRITE);
  if (!file)
    Serial.println("- failed to open file for writing");
    return;
  if (file.print(message))
    Serial.println("- file written");
  else
    Serial.println("- write failed");
  file.close();
void appendFile(fs::FS &fs, const char *path, const char *message)
  Serial.printf("Appending to file: %s\r\n", path);
  File file = fs.open(path, FILE_APPEND);
  if (!file)
    Serial.println("- failed to open file for appending");
    return;
    Serial.println("- message appended");
  else
    Serial.println("- append failed");
  file.close();
void renameFile(fs::FS &fs, const char *path1, const char *path2)
  Serial.printf("Renaming file %s to %s\r\n", path1, path2);
  if (fs.rename(path1, path2))
    Serial.println("- file renamed");
  else
    Serial.println("- rename failed");
void deleteFile(fs::FS &fs, const char *path)
  Serial.printf("Deleting file: %s\r\n", path);
  if (fs.remove(path))
    Serial.println("- file deleted");
  else
    Serial.println("- delete failed");
void writeFile2(fs::FS &fs, const char *path, const char *message)
  if (!fs.exists(path))
    if (strchr(path, '/'))
      Serial.printf("Create missing folders of: %s\r\n", path);
      char *pathStr = strdup(path);
      if (pathStr)
        char *ptr = strchr(pathStr, '/');
        while (ptr)
          *ptr = 0;
          fs.mkdir(pathStr);
          *ptr = '/';
          ptr = strchr(ptr + 1, '/');
      free(pathStr);
  Serial.printf("Writing file to: %s\r\n", path);
  if (!file)
    return;
  else
  file.close();
void deleteFile2(fs::FS &fs, const char *path)
  Serial.printf("Deleting file and empty folders on path: %s\r\n", path);
  else
  if (pathStr)
    char *ptr = strrchr(pathStr, '/');
    if (ptr)
      Serial.printf("Removing all empty folders on path: %s\r\n", path);
    while (ptr)
      *ptr = 0;
      fs.rmdir(pathStr);
    free(pathStr);
void testFileIO(fs::FS &fs, const char *path)
  Serial.printf("Testing file I/O with %s\r\n", path);
  static uint8_t buf[512];
  size_t len = 0;
  if (!file)
    return;
  size_t i;
  Serial.print("- writing");
  uint32_t start = millis();
  for (i = 0; i < 2048; i++)
    if ((i & 0x001F) == 0x001F)
      Serial.print(".");
    file.write(buf, 512);
  Serial.println("");
  uint32_t end = millis() - start;
  Serial.printf(" - %u bytes written in %u ms\r\n", 2048 * 512, end);
  file.close();
  start = millis();
  end = start;
  i = 0;
  if (file && !file.isDirectory())
    len = file.size();
    size_t flen = len;
    start = millis();
    Serial.print("- reading");
    while (len)
      size_t toRead = len;
      if (toRead > 512)
        toRead = 512;
      file.read(buf, toRead);
      if ((i++ & 0x001F) == 0x001F)
        Serial.print(".");
      len -= toRead;
    Serial.println("");
    Serial.printf("- %u bytes read in %u ms\r\n", flen, end);
    file.close();
  else
void setup()
  // Initialize the serial port
  Serial.println("in setup()");
  if (!LittleFS.begin(FORMAT_LITTLEFS_IF_FAILED))
    Serial.println("LittleFS Mount Failed");
    return;
  Serial.println("SPIFFS-like write file to new path and delete it w/folders");
  writeFile2(LittleFS, "/new1/new2/new3/hello3.txt", "Hello3");
  listDir(LittleFS, "/", 3);
  deleteFile2(LittleFS, "/new1/new2/new3/hello3.txt");
  createDir(LittleFS, "/mydir");
  writeFile(LittleFS, "/mydir/hello2.txt", "Hello2");
  listDir(LittleFS, "/", 1);
  deleteFile(LittleFS, "/mydir/hello2.txt");
  removeDir(LittleFS, "/mydir");
  writeFile(LittleFS, "/hello.txt", "Hello ");
  appendFile(LittleFS, "/hello.txt", "World!\r\n");
  readFile(LittleFS, "/hello.txt");
  renameFile(LittleFS, "/hello.txt", "/foo.txt");
  readFile(LittleFS, "/foo.txt");
  deleteFile(LittleFS, "/foo.txt");
  testFileIO(LittleFS, "/test.txt");
  deleteFile(LittleFS, "/test.txt");
  Serial.println("Test complete");
void loop() {}
Please show a screenshot of your Arduino IDE “Tools” menu along with Tools->Board->Board Manager → esp32 so we can see the core version.
this is screeshot from Arduino IDE
just for reference and a test I just also downgraded from V2.0.9 to V2.0.8 in ESP32 in Arduini IDE and it still works in Aurduino IDE when I compile and executed code.
That one’s still missing
apologies, here it is:
Oof, I forgot Arduino IDE 2.0 doesn’t show the actual value of the selected setting. What’s the value of th partition scheme and flash mode?
@maxgerhardt sorry to bother you, wondering if you had a chance to have another look at this issue I am experiening (I’ve added addtional info above as requested).
If you selected this option, the Arduino IDE does
i.e. it uses ffat.csv. Weird that it doesn’t mention LittleFS, but can you set the same partition table in the platformio.ini?
thank you, I’m getting following error:
my platformio.ini file is as follows:
That’s… what in the. The Arduino IDE LittleFS example worked with the Partition scheme set to “FATFS”?
We’ve reached the point where nothing makes even the slightest amount of sense anymore. I’ll see if I have a S3 board here and can flash it with the littlefs example…
No, I don’t have a S3 board. I only have regular ESP32 and ESP32-C3.
Can you please show a screenshot of the LittleFS sketch happily running in the Arduino serial monitor with the partition table being selected as FFat?
got me confused too… here are details:
here is Serial output:
here is code:
// #include <Arduino.h>
// #include <WiFiManager.h> // https://github.com/tzapu/WiFiManager
#include "FS.h"
/* You only need to format LittleFS the first time you run a
   test or else use the LITTLEFS plugin to create a partition
   https://github.com/lorol/arduino-esp32littlefs-plugin
   If you test two partitions, you need to use a custom
   partition.csv file, see in the sketch folder */
 //WiFiManager, Local intialization. Once its business is done, there is no need to keep it around
 //  WiFiManager wm;
//#define TWOPART
void listDir(fs::FS &fs, const char * dirname, uint8_t levels){
    if(!root){
        return;
    if(!root.isDirectory()){
        return;
    while(file){
        if(file.isDirectory()){
            if(levels){
                listDir(fs, file.path(), levels -1);
        } else {
void createDir(fs::FS &fs, const char * path){
    if(fs.mkdir(path)){
    } else {
void removeDir(fs::FS &fs, const char * path){
    if(fs.rmdir(path)){
    } else {
void readFile(fs::FS &fs, const char * path){
    if(!file || file.isDirectory()){
        return;
    while(file.available()){
    file.close();
void writeFile(fs::FS &fs, const char * path, const char * message){
    if(!file){
        return;
    if(file.print(message)){
    } else {
    file.close();
void appendFile(fs::FS &fs, const char * path, const char * message){
    if(!file){
        return;
    } else {
    file.close();
void renameFile(fs::FS &fs, const char * path1, const char * path2){
    if (fs.rename(path1, path2)) {
    } else {
void deleteFile(fs::FS &fs, const char * path){
    if(fs.remove(path)){
    } else {
// SPIFFS-like write and delete file, better use #define CONFIG_LITTLEFS_SPIFFS_COMPAT 1
void writeFile2(fs::FS &fs, const char * path, const char * message){
    if(!fs.exists(path)){
		if (strchr(path, '/')) {
			if (pathStr) {
				while (ptr) {
					*ptr = 0;
					fs.mkdir(pathStr);
					*ptr = '/';
					ptr = strchr(ptr+1, '/');
			free(pathStr);
    if(!file){
        return;
    } else {
    file.close();
void deleteFile2(fs::FS &fs, const char * path){
    } else {
    if (pathStr) {
        if (ptr) {
        while (ptr) {
            *ptr = 0;
            fs.rmdir(pathStr);
        free(pathStr);
void testFileIO(fs::FS &fs, const char * path){
    size_t len = 0;
    if(!file){
        return;
    size_t i;
    Serial.print("- writing" );
    for(i=0; i<2048; i++){
        if ((i & 0x001F) == 0x001F){
          Serial.print(".");
    Serial.println("");
    file.close();
    start = millis();
    end = start;
    i = 0;
    if(file && !file.isDirectory()){
        len = file.size();
        size_t flen = len;
        start = millis();
        Serial.print("- reading" );
        while(len){
            if(toRead > 512){
                toRead = 512;
            if ((i++ & 0x001F) == 0x001F){
              Serial.print(".");
            len -= toRead;
        Serial.println("");
        file.close();
    } else {
void setup(){
#ifdef TWOPART
    if(!LittleFS.begin(FORMAT_LITTLEFS_IF_FAILED, "/lfs2", 5, "part2")){
    Serial.println("part2 Mount Failed");
    return;
    appendFile(LittleFS, "/hello0.txt", "World0!\r\n");
    readFile(LittleFS, "/hello0.txt");
    LittleFS.end();
    Serial.println( "Done with part2, work with the first lfs partition..." );
    if(!LittleFS.begin(FORMAT_LITTLEFS_IF_FAILED)){
        return;
    Serial.println( "SPIFFS-like write file to new path and delete it w/folders" );
    Serial.println( "Test complete" );
    bool res;
    // res = wm.autoConnect(); // auto generated AP name from chipid
    // res = wm.autoConnect("AutoConnectAP"); // anonymous ap
  //  res = wm.autoConnect("AutoConnectAP","password"); // password protected ap
    if(!res) {
        Serial.println("Failed to connect");
        // ESP.restart();
    else {
        //if you get here you have connected to the WiFi
        Serial.println("connected...yeey :)");
void loop(){
partition table selected:
thanks for trying to help.
I hope you or someone in the community figures out an answer … i really exhausted all my knowldge on this :frowning:
