Hello Everyone!
I need help in uploading of Nucleo code into Generic STM32 chip.
I have Nucleo STM32F103RB board and developed a firmware for it using Arduino (with STM32Duino latest Framework). Now I need to upload and use this firmware into generic STM32F103RB chip. Chips are the same. I use ST-Link V2 Mini for connection to the chip.
ST-Link utility allows me to connect to the chip. I can read its memory. So it works. When I try to upload firmware from VSCode PIO IDE to the chip I get the following error:
GNU MCU Eclipse OpenOCD, 32-bitOpen On-Chip Debugger 0.10.0+dev-00593-g23ad80df4 (2019-04-22-16:40)
Licensed under GNU GPL v2
For bug reports, read
debug_level: 1
adapter speed: 1000 kHz
adapter_nsrst_delay: 100
none separate
Error: timed out while waiting for target halted
TARGET: stm32f1x.cpu - Not halted
in procedure 'program'
embedded:startup.tcl:479: Error: ** Unable to reset target **
in procedure 'program_error' called at file "embedded:startup.tcl", line 504
at file "embedded:startup.tcl", line 479
*** [upload] Error 1
So, it seems that the programmer can’t reset my chip.
For testing that I started a new project that uses GenericSTM32F103RB board. And it can upload the test firmware very well:
OpenOCD: Bug Reporting
debug_level: 1
hla_swd
none separate
xPSR: 0x01000000 pc: 0x080024ec msp: 0x20005000
** Programming Started **
auto erase enabled
wrote 19456 bytes from file .pio\build\genericSTM32F103RB\firmware.elf in 1.128910s (16.830 KiB/s)
** Programming Finished **
** Verify Started **
verified 19244 bytes in 0.341058s (55.102 KiB/s)
** Verified OK **
** Resetting Target **
shutdown command invoked
I can’t compile my firmware for GenericSTM32F103RB because it uses mapple core instead of STM32Duino.
What shall I try to solve the problem?
