NUCLEO-G431 hal initialization
hello, I’m using NUCLEO-G431RB with platformio ststm32
the code I use is as follows.
  • main.cpp
#include "utilityG431.h"
void delay(volatile uint32_t count);
void setup(){
    HAL_Init();
    SystemClock_Config();
    MX_GPIO_Init();
int main(void) {
    setup();
    HAL_GPIO_WritePin(GPIOA, GPIO_PIN_5, GPIO_PIN_SET);
    HAL_Delay(500);
    HAL_GPIO_WritePin(GPIOA, GPIO_PIN_5, GPIO_PIN_RESET);
static void MX_GPIO_Init(void) {
  GPIO_InitTypeDef GPIO_InitStruct = {0};
  __HAL_RCC_GPIOC_CLK_ENABLE();
  __HAL_RCC_GPIOF_CLK_ENABLE();
  __HAL_RCC_GPIOA_CLK_ENABLE();
  /*Configure GPIO pin Output Level */
  GPIO_InitStruct.Pin = GPIO_PIN_5;
  GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  GPIO_InitStruct.Pull = GPIO_NOPULL;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
  HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
void delay(volatile uint32_t count) {
    while (count--) { __asm("nop"); }
  • utilityG431.cpp
void SystemClock_Config(void) {
  RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
  HAL_PWREx_ControlVoltageScaling(PWR_REGULATOR_VOLTAGE_SCALE1_BOOST);
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  RCC_OscInitStruct.HSEState = RCC_HSE_ON;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
  RCC_OscInitStruct.PLL.PLLM = RCC_PLLM_DIV2;
  RCC_OscInitStruct.PLL.PLLN = 28;
  RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
  RCC_OscInitStruct.PLL.PLLQ = RCC_PLLQ_DIV2;
  RCC_OscInitStruct.PLL.PLLR = RCC_PLLR_DIV2;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
  { Error_Handler(); }
  /** Initializes the CPU, AHB and APB buses clocks
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_4) != HAL_OK)
  SystemCoreClockUpdate();
void Error_Handler() {
    __disable_irq(); while ( 1 ) { }
  • utilityG431.h
#ifndef SRC_UTILITYG431_H_
#define SRC_UTILITYG431_H_
#ifdef __cplusplus
extern "C" {
#include "stm32g431xx.h"
#include "stm32g4xx_hal.h"
void Error_Handler(void);
void SystemClock_Config(void);
static void MX_GPIO_Init(void);
#ifdef __cplusplus
#endif /* __MAIN_H */
when I uploaded firmware and reset the MCU, USER LED(LD2, PA5) is turn on and does not change the state. I have no idea why this thing happens…
You’re forgetting to implement the SysTick_Handler interrupt in which you must increment the HAL tick. Without that, HAL_Delay() will delay forever…
Don’t forget to use
extern "C" void SysTick_Handler(void)
  HAL_IncTick();
if you’re implementing this in a C++ file instead of a C file.
wow… I am stupid…
thanks for your help!
