Thaks for the answer Max.
Could you tell me more about LD4, why shouldn’t care?
I run the debug:
latformIO Unified Debugger → Redirecting...
PlatformIO: debug_tool = stlink
PlatformIO: Initializing remote target…
xPack Open On-Chip Debugger 0.12.0-01004-g9ea7f3d64-dirty (2023-01-30-17:03)
Licensed under GNU GPL v2
For bug reports, read
Info : The selected transport took over low-level target control. The results might differ compared to plain JTAG/SWD
srst_only separate srst_nogate srst_open_drain connect_deassert_srst
Info : tcl server disabled
Info : telnet server disabled
Info : clock speed 2000 kHz
Info : STLINK V2J39M27 (API v2) VID:PID 0483:374B
Info : Target voltage: 3.250394
Info : [stm32f7x.cpu] Cortex-M7 r1p0 processor detected
Info : [stm32f7x.cpu] target has 8 breakpoints, 4 watchpoints
Info : starting gdb server for stm32f7x.cpu on pipe
Info : accepting ‘gdb’ connection from pipe
[stm32f7x.cpu] halted due to debug-request, current mode: Thread
xPSR: 0xa1000000 pc: 0x08003e70 msp: 0x2007fed8
Info : device id = 0x10016451
Info : flash size = 2048 KiB
Info : Single Bank 2048 kiB STM32F76x/77x found
Info : flash size = 1024 bytes
assert_failed (file=file@entry=0x8006534 “/Users/.platformio/packages/framework-arduinoststm32/system/Drivers/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_rcc.c”, line=line@entry=601) at /Users/.platformio/packages/framework-arduinoststm32/libraries/SrcWrapper/src/stm32/stm32_def.c:33
33 _Error_Handler((const char *)file, line);
Info : Unable to match requested speed 2000 kHz, using 1800 kHz
xPSR: 0x01000000 pc: 0x080051a4 msp: 0x20080000
Breakpoint 1 at 0x80034e0: setup. (2 locations)
Note: automatically using hardware breakpoints for read-only addresses.
PlatformIO: Initialization completed
PlatformIO: Resume the execution to debug_init_break = b setup
PlatformIO: More configuration options → Redirecting...
- Errors:
cannot open source file “stm32_def.h”
cannot open source file “core_debug.h”
