I get the error above when I start debug in platformIO using VS Code. I’m using VS Code 1.52.1 and platformIO (core 5.0.4, home 3.3.1) with NUCLEO-F746ZG (mbed framework, upload protocol is mbed as well). The code is able to run (build and upload) on the board without any problems. Any ideas on how to fix this issue?
Reading symbols from c:\msys64\home\MikoNore\GitHub\Multipack_BMU\ISO-SPI-Emulator\CSB-master.pio\build\nucleo_f746zg\firmware.elf…
undefinedC:\Users\MikoNore.platformio\packages\toolchain-gccarmnoneeabi\bin\arm-none-eabi-gdb.exe: warning: Couldn’t determine a path for the index cache directory.
xPack OpenOCD, x86_64 Open On-Chip Debugger 0.10.0+dev-00378-ge5be992df (2020-06-26-09:29)
Licensed under GNU GPL v2
For bug reports, read
OpenOCD: Bug Reporting
srst_only separate srst_nogate srst_open_drain connect_deassert_srstInfo : tcl server disabled
Info : telnet server disabled
Info : clock speed 2000 kHz
Info : STLINK V2J29M18 (API v2) VID:PID 0483:374B
Info : Target voltage: 3.252840
Info : stm32f7x.cpu: hardware has 0 breakpoints, 10 watchpoints
Info : starting gdb server for stm32f7x.cpu on pipe
Info : accepting ‘gdb’ connection from pipe
Info : device id = 0xa05f0000
Warn : Cannot identify target as a STM32 family.
Error: auto_probe failed
Thanks!
