Hi there,
I’m working on a project for uni and I would like to use PlatformIO for the project development, since it seems more practical than the Arduino IDE. However, I keep getting this error when trying to upload any file to my Nucleo F303RE.
CONFIGURATION: https://docs.platformio.org/page/boards/ststm32/nucleo_f303re.html
PLATFORM: ST STM32 (19.0.0) > ST Nucleo F303RE
HARDWARE: STM32F303RET6 72MHz, 64KB RAM, 512KB Flash
- framework-arduinoststm32 @ 4.20900.0 (2.9.0)
- framework-cmsis @ 2.50900.0 (5.9.0)
- tool-dfuutil @ 1.11.0
- tool-dfuutil-arduino @ 1.11.0
- tool-openocd @ 3.1200.0 (12.0)
- tool-stm32duino @ 1.0.2
- toolchain-gccarmnoneeabi @ 1.120301.0 (12.3.1)
Found 14 compatible libraries
Checking size .pio\build\nucleo_f303re\firmware.elf
RAM: [ ] 1.8% (used 1204 bytes from 65536 bytes)
Flash: [ ] 1.8% (used 9336 bytes from 524288 bytes)
AVAILABLE: blackmagic, cmsis-dap, jlink, mbed, stlink
Uploading .pio\build\nucleo_f303re\firmware.elf
Licensed under GNU GPL v2
For bug reports, read
debug_level: 1
Error: libusb_open() failed with LIBUSB_ERROR_NOT_FOUND
Error: open failed
in procedure 'program'
** OpenOCD init failed **
shutdown command invoked
*** [upload] Error 1
This is the whole upload log when I try to upload the project (after already compiling it).
I’ve read through some other topics and the errors others seem to have with other boards was that they’re improperly connected/missing a channel/etc. but the Nucleo should only need the one usb cable.
The Nucleo works fine with the Arduino IDE and I was able to upload to it many times, so I don’t understand why it gives a LIBUSB_ERROR_NOT_FOUND. I also tried setting the exact upload_port
to com7
, which is the usb port I use, but it didn’t change anything.
Does anyone have any insights? Cause I’m not experienced enough to fix this…
ETA: My platformio.ini is this:
[env:nucleo_f303re]
platform = ststm32
board = nucleo_f303re
