Hi all. I am trying to communicate via UART0, but It seems I am not receiving anything. I can receive via the micro USB port just fine. My USB to TTL adapter stops flashing a blue light when Serial1.write(" HELLO1 "); is commented out, so I think it is reaching there. In tio I am connected, but nothing is being shown for the adapter, whereas the serial over the micro USB port works fine.
src/main.cpp
// the setup routine runs once when you press reset:
// initialize the digital pin as an output.
pinMode(LED_BUILTIN, OUTPUT);
Serial1.begin(115200);
// the loop routine runs over and over again forever:
Serial.write(" HELLO ");
digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(LED_BUILTIN, LOW); // turn the LED off by making the voltage LOW
platformio.ini
; Build options: build flags, source filter, extra scripting
; Upload options: custom port, speed and extra flags
[env:pico]
platform = https://github.com/maxgerhardt/platform-raspberrypi.git
board = pico
; platform = raspberrypi
board_build.core = earlephilhower
board_build.filesystem_size = 0.5m
Regards,
Bruce
