I am running a Github Action to build my project with platform io. It works without problems on the windows runner, but not on the ubuntu runners (tried 20.04, 22.04).
This is the yaml file:
name: Build firmware with PIO
on: [push]
jobs:
build:
runs-on: windows-2022
environment: CICD
steps:
- uses: actions/checkout@v4
with:
fetch-depth: '100' # fetch last 100 to make sure we have a tag
fetch-tags: 'true' # fetch tags for static header generation
- uses: actions/cache@v4
with:
path: |
~/.cache/pip
~/.platformio/.cache
key: ${{ runner.os }}-pio
- uses: actions/setup-python@v5
with:
python-version: '3.11'
- name: Install PlatformIO Core
run: pip install --upgrade platformio
- name: test git describe
run: git describe --tags --match v[0-9]*
- name: Build PlatformIO Project
run: pio run -e sensotronic2 -vv
The error that happens only on ubuntu:
In file included from src/ble/BLENotifyTPLCharacteristic.h:4:0,
from src/ble/BLEGridService.h:4,
from src/IMUPropagater.h:7,
from src/IMUPropagater.cpp:1:
src/ble/BLENotifyTPLHelper.h:5:10: fatal error: TPLHelperbase.h: No such file or directory
With the according compiler command (it shows that -Ilib/protocol/include in included, the TPLHelperbase.h file is there):
arm-none-eabi-g++ -o .pio/build/sensotronic2/src/ModeManager.cpp.o -c -fno-rtti -fno-exceptions -std=gnu++11 -fno-threadsafe-statics -mthumb -mcpu=cortex-m4 -Ofast -ffunction-sections -fdata-sections -Wall -nostdlib --param max-inline-insns-single=500 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -u _printf_float -DPLATFORMIO=60114 -DARDUINO_NRF52840_FEATHER -DNRF52840_XXAA -D_BSD_SOURCE -DUSE_LISTCALIBRATION=true -DNOT_AN_INTERRUPT=-1 -DSPI_32MHZ_INTERFACE=1 -DLFS_FLASH_ADDR=0xD9000 -DF_CPU=64000000L -DARDUINO=10804 -DARDUINO_ARCH_NRF52 -DARDUINO_BSP_VERSION=\"1.6.0\" -DARDUINO_NRF52_ADAFRUIT -DNRF52_SERIES -DLFS_NAME_MAX=64 -DDX_CC_TEE -DSOFTDEVICE_PRESENT -DUSBCON -DUSE_TINYUSB -DUSB_VID=0x239A -DUSB_PID=0x8029 "-DUSB_PRODUCT=\"Feather nRF52840 Express\"" -DUSB_MANUFACTURER=\"Adafruit\" -DCFG_DEBUG=0 -Iinclude -Isrc -Ilib/IMU/include -Ilib/IMU/src -Ilib/Config/include -Ilib/Config/src -Ilib/GridSensorReading/include -Ilib/GridSensorReading/src -Ilib/Calibration/include -Ilib/Calibration/src -Ilib/time/include -Ilib/time/src -Ilib/BatteryMonitor/include -Ilib/BatteryMonitor/src -I/home/runner/.platformio/packages/framework-arduinoadafruitnrf52/libraries/Bluefruit52Lib/src -I/home/runner/.platformio/packages/framework-arduinoadafruitnrf52/libraries/Adafruit_nRFCrypto/src -I/home/runner/.platformio/packages/framework-arduinoadafruitnrf52/libraries/InternalFileSytem/src -I/home/runner/.platformio/packages/framework-arduinoadafruitnrf52/libraries/Adafruit_LittleFS/src -Ilib/protocol/include -Ilib/protocol/src -Ilib/util/include -Ilib/util/src -I.pio/libdeps/sensotronic2/EasyButton/src -I.pio/libdeps/sensotronic2/Fusion "-I.pio/libdeps/sensotronic2/Adafruit BusIO" -I/home/runner/.platformio/packages/framework-arduinoadafruitnrf52/libraries/Wire -I.pio/libdeps/sensotronic2/ArduinoLog "-I.pio/libdeps/sensotronic2/RTT Stream/src" "-I.pio/libdeps/sensotronic2/Adafruit SPIFlash/src" -I/home/runner/.platformio/packages/framework-arduinoadafruitnrf52/libraries/Adafruit_TinyUSB_Arduino/src "-I.pio/libdeps/sensotronic2/SdFat - Adafruit Fork/src" -I/home/runner/.platformio/packages/framework-arduinoadafruitnrf52/libraries/SPI -I.pio/libdeps/sensotronic2/StreamUtils/src -I.pio/libdeps/sensotronic2/Regexp/src -I.pio/libdeps/sensotronic2/SafeString/src -I.pio/libdeps/sensotronic2/CRC32/src -I.pio/libdeps/sensotronic2/ArduinoJson/src -I/home/runner/.platformio/packages/framework-cmsis/CMSIS/Core/Include -I/home/runner/.platformio/packages/framework-cmsis/CMSIS/DSP/Include -I/home/runner/.platformio/packages/framework-arduinoadafruitnrf52/cores/nRF5/nordic -I/home/runner/.platformio/packages/framework-arduinoadafruitnrf52/cores/nRF5/nordic/nrfx -I/home/runner/.platformio/packages/framework-arduinoadafruitnrf52/cores/nRF5/nordic/nrfx/hal -I/home/runner/.platformio/packages/framework-arduinoadafruitnrf52/cores/nRF5/nordic/nrfx/mdk -I/home/runner/.platformio/packages/framework-arduinoadafruitnrf52/cores/nRF5/nordic/nrfx/soc -I/home/runner/.platformio/packages/framework-arduinoadafruitnrf52/cores/nRF5/nordic/nrfx/drivers/include -I/home/runner/.platformio/packages/framework-arduinoadafruitnrf52/cores/nRF5/nordic/nrfx/drivers/src -I/home/runner/.platformio/packages/framework-arduinoadafruitnrf52/cores/nRF5/nordic/softdevice/s140_nrf52_6.1.1_API/include -I/home/runner/.platformio/packages/framework-arduinoadafruitnrf52/cores/nRF5/nordic/softdevice/s140_nrf52_6.1.1_API/include/nrf52 -I/home/runner/.platformio/packages/framework-arduinoadafruitnrf52/cores/nRF5/freertos/Source/include -I/home/runner/.platformio/packages/framework-arduinoadafruitnrf52/cores/nRF5/freertos/config -I/home/runner/.platformio/packages/framework-arduinoadafruitnrf52/cores/nRF5/freertos/portable/GCC/nrf52 -I/home/runner/.platformio/packages/framework-arduinoadafruitnrf52/cores/nRF5/freertos/portable/CMSIS/nrf52 -I/home/runner/.platformio/packages/framework-arduinoadafruitnrf52/cores/nRF5/sysview/SEGGER -I/home/runner/.platformio/packages/framework-arduinoadafruitnrf52/cores/nRF5/sysview/Config -I/home/runner/.platformio/packages/framework-arduinoadafruitnrf52/libraries/Adafruit_TinyUSB_Arduino/src/arduino -I/home/runner/.platformio/packages/framework-arduinoadafruitnrf52/cores/nRF5 -Isensotronic_variants/feather_nrf52840_express src/ModeManager.cpp
I don’t really get why it does not find it on ubuntu. I checked the pio version that both use (they are both platformio-6.1.14.tar.gz) and also the compiler version is the same (toolchain-gccarmnoneeabi @ 1.70201.0).
