PlatformIO Core, version 6.1.7
Absolutely brand new to PIO (Windows VS Studio code). I am using it to flash a home automation project GitHub - sidoh/esp8266_milight_hub: Replacement for a Milight/LimitlessLED hub hosted on an ESP8266 to an EsP32 WROOM DEV.
After building, and resolving Git missing client/Pio path issues, I am attempting to flash the project using the commands below:
set ESP_BOARD=nodemcuv2
platformio run -e $ESP_BOARD --target upload
Admittedly, my knowledge of the arguments is at best sketchy but I was surprised at the error message I received:
Error: Got unexpected extra argument (upload)
‘upload’ appears to be a valid target text value, as shown on the pio cli web page examples. I need help in understanding what should be in the -target value for flashing this project to an esp board.
I did run a list-targets command and got the following:
Environment Group Name Title Description
nodemcuv2 Platform upload Upload
huzzah Platform upload Upload
esp12 Platform upload Upload
d1_mini Platform upload Upload
d1_mini_pro Platform upload Upload
esp07 Platform upload Upload
Unsure as to whether platform.ini settings will help but I have pasted them below:
; http://docs.platformio.org/page/projectconf.html
[common]
platform = espressif8266@~1.8
board_f_cpu = 160000000L
lib_deps_builtin =
lib_deps_external =
WiFiManager=https://github.com/sidoh/WiFiManager.git#cmidgley
RF24@~1.3.2
ArduinoJson@~6.10.1
PubSubClient@~2.7
https://github.com/ratkins/RGBConverter.git#07010f2
WebSockets@~2.2.0
CircularBuffer@~1.2.0
PathVariableHandlers@~2.0.0
RichHttpServer@~2.0.2
extra_scripts =
pre:.build_web.py
test_ignore = remote
upload_speed = 460800
!python3 .get_version.py
# For compatibility with WebSockets 2.1.4 and v2.4 of the Arduino SDK
-D USING_AXTLS
-D MQTT_MAX_PACKET_SIZE=360
-D HTTP_UPLOAD_BUFLEN=128
-D FIRMWARE_NAME=milight-hub
-D RICH_HTTP_REQUEST_BUFFER_SIZE=2048
-D RICH_HTTP_RESPONSE_BUFFER_SIZE=2048
-Idist -Ilib/DataStructures
# -D STATE_DEBUG
# -D DEBUG_PRINTF
# -D MQTT_DEBUG
# -D MILIGHT_UDP_DEBUG
# -D STATE_DEBUG
[env:nodemcuv2]
platform = ${common.platform}
framework = ${common.framework}
upload_speed = ${common.upload_speed}
board = nodemcuv2
build_flags = ${common.build_flags} -Wl,-Tesp8266.flash.4m1m.ld -D FIRMWARE_VARIANT=nodemcuv2
extra_scripts = ${common.extra_scripts}
${common.lib_deps_builtin}
${common.lib_deps_external}
test_ignore = ${common.test_ignore}
[env:d1_mini]
board = d1_mini
build_flags = ${common.build_flags} -Wl,-Tesp8266.flash.4m1m.ld -D FIRMWARE_VARIANT=d1_mini
[env:esp12]
board = esp12e
build_flags = ${common.build_flags} -Wl,-Tesp8266.flash.4m1m.ld -D FIRMWARE_VARIANT=esp12
[env:esp07]
board = esp07
build_flags = ${common.build_flags} -Wl,-Tesp8266.flash.1m64.ld -D FIRMWARE_VARIANT=esp07
[env:huzzah]
board = huzzah
build_flags = ${common.build_flags} -D FIRMWARE_VARIANT=huzzah
[env:d1_mini_pro]
board = d1_mini_pro
build_flags = ${common.build_flags} -Wl,-Tesp8266.flash.4m1m.ld -D FIRMWARE_VARIANT=d1_mini_PRO
