I just set up a new project using the ESP32-c3 and wanted to run the debugger.
The code gets (re-)build and the debugger start but dies without error.
Going to the debug console I can see:
undefinedFileNotFoundError: Traceback (most recent call last):
File “/home/nerdyscout/.platformio/penv/lib/python3.11/site-packages/platformio/main.py”, line 103, in main
File “/home/nerdyscout/.platformio/penv/lib/python3.11/site-packages/click/core.py”, line 1157, in call
File “/home/nerdyscout/.platformio/penv/lib/python3.11/site-packages/click/core.py”, line 1078, in main
rv = self.invoke(ctx)
File “/home/nerdyscout/.platformio/penv/lib/python3.11/site-packages/platformio/cli.py”, line 85, in invoke
return super().invoke(ctx)
File “/home/nerdyscout/.platformio/penv/lib/python3.11/site-packages/click/core.py”, line 1688, in invoke
File “/home/nerdyscout/.platformio/penv/lib/python3.11/site-packages/click/core.py”, line 1434, in invoke
File “/home/nerdyscout/.platformio/penv/lib/python3.11/site-packages/click/core.py”, line 783, in invoke
File “/home/nerdyscout/.platformio/penv/lib/python3.11/site-packages/click/decorators.py”, line 33, in new_func
File “/home/nerdyscout/.platformio/penv/lib/python3.11/site-packages/platformio/debug/cli.py”, line 109, in cli
_run(project_dir, debug_config, client_extra_args)
File “/home/nerdyscout/.platformio/penv/lib/python3.11/site-packages/platformio/debug/cli.py”, line 175, in _run
loop.run_until_complete(coro)
File “/usr/lib/python3.11/asyncio/base_events.py”, line 653, in run_until_complete
return future.result()
File “/home/nerdyscout/.platformio/penv/lib/python3.11/site-packages/platformio/debug/process/gdb.py”, line 57, in run
await self.spawn(*args, cwd=self.project_dir, wait_until_exit=True)
File “/home/nerdyscout/.platformio/penv/lib/python3.11/site-packages/platformio/debug/process/base.py”, line 76, in spawn
await loop.subprocess_exec(
File “/usr/lib/python3.11/asyncio/base_events.py”, line 1694, in subprocess_exec
transport = await self._make_subprocess_transport(
File “/usr/lib/python3.11/asyncio/unix_events.py”, line 207, in _make_subprocess_transport
transp = _UnixSubprocessTransport(self, protocol, args, shell,
File “/usr/lib/python3.11/asyncio/base_subprocess.py”, line 36, in init
self._start(args=args, shell=shell, stdin=stdin, stdout=stdout,
File “/usr/lib/python3.11/asyncio/unix_events.py”, line 818, in _start
self._proc = subprocess.Popen(
File “/usr/lib/python3.11/subprocess.py”, line 1026, in init
self._execute_child(args, executable, preexec_fn, close_fds,
File “/usr/lib/python3.11/subprocess.py”, line 1950, in _execute_child
raise child_exception_type(errno_num, err_msg, err_filename)
> FileNotFoundError: [Errno 2] No such file or directory: ‘riscv32-esp-elf-gdb’============================================================
Verify that you have the latest version of PlatformIO using
python -m pip install -U platformio
commandTry to find answer in FAQ Troubleshooting section
Redirecting...Report this problem to the developers
Issues · platformio/platformio-core · GitHub============================================================
I suppose the missing riscv32-esp-elf-gdb is my issue, but should this not be installed according to the dependencies?
dependencies list:
Resolving ESP32-C3 dependencies…
Platform espressif32 @ 6.5.0 (required: espressif32)
├── framework-arduinoespressif32 @ 3.20014.231204 (required: platformio/framework-arduinoespressif32 @ ~3.20014.0)
├── tool-esptoolpy @ 1.40501.0 (required: platformio/tool-esptoolpy @ ~1.40501.0)
├── tool-mkfatfs @ 2.0.1 (required: platformio/tool-mkfatfs @ ~2.0.0)
├── tool-mklittlefs @ 1.203.210628 (required: platformio/tool-mklittlefs @ ~1.203.0)
├── tool-mkspiffs @ 2.230.0 (required: platformio/tool-mkspiffs @ ~2.230.0)
├── tool-openocd-esp32 @ 2.1100.20220706 (required: platformio/tool-openocd-esp32 @ ~2.1100.0)
└── toolchain-riscv32-esp @ 8.4.0+2021r2-patch5 (required: espressif/toolchain-riscv32-esp @ 8.4.0+2021r2-patch5)
