Probably a noob problem, but I searched everywhere and tried a lot of things but it didnt work. i get this error:
src/main.cpp:2:10: fatal error: displaylog.h: No such file or directory
* Looking for displaylog.h dependency? Check our library registry!
* CLI > platformio lib search "header:displaylog.h"
* Web > https://registry.platformio.org/search?q=header:displaylog.h
#include "displaylog.h"
compilation terminated.
*** [.pio\build\esp32-c3-devkitm-1\src\main.cpp.o] Error 1
but it’s in the lib folder at first there were the same issues with wire.h and spi.h which is weird because they are built in… I messed a little bit around and after adding SPI and wire to the lib_deps. I only realy used Arduino IDE before. Thanks for the help!
