I’m trying this with multiple boards. Seeduino XIAO ESP32C3 as well as D1 Mini ESP32. My Sketch won’t upload with PlatformIO. Using Mac OS Sonoma 14.2.1 When doing so I suddenly get. After it has been working for the last… weeks?
A fatal error occurred: Could not open /dev/tty.usbmodem1101, the port is busy or doesn't exist.
([Errno 16] could not open port /dev/tty.usbmodem1101: [Errno 16] Resource busy: '/dev/tty.usbmodem1101')
Uploading with the Arduino IDE works. I shut down the Arduino IDE, so it can’t be that there is a serial monitor blocking the port. I also rebooted my mac.
ls -l /System/Library/Extensions/SiLabsUSBDriver.kext and ls -l /Library/Extensions/SiLabsUSBDriver.kext
Gives no results.
The thing is, that this worked once. so apparently something got blocked. i just can’t say what. There is no python or platformio process running that would indicate that something is blocking.
Interestingly i just shut down vscode and upload worked. But not reproducable.
lsof /dev/tty.usbserial-0264D1KX
produces no output.
My platformio.ini is:
[env:d1]
board = wemos_d1_mini32
khoih-prog/ESP32TimerInterrupt@^2.3.0
https://github.com/leandcesar/PeakDetection
upload_port = /dev/tty.usbserial-0264D1KX
monitor_port = /dev/tty.usbserial-0264D1KX
