No Output to Serial Monitor
I’m new to PlatformIO and not able to get output from Serial Monitor. It works in the Arduino IDE and outputs to the Arduino Serial Monitor. Build and Upload are fine. I’ve done some searching and can’t find a solution that works. COM port selected in PlatformIO matches COM port in Device Manager.
Any suggestions would be appreciated.
void setup()
    delay(1000);
void loop()
    Serial.println("Hello world!");
    delay(1000);
[env:esp32-s3-devkitc-1]
board = esp32-s3-devkitc-1
I was able to get this working. I don’t understand why, but my edits kept going to a project that I had deleted in both VS explorer and MS explorer. But, like a zombie it kept coming back from the dead. The VS chat was able to determine the problem and after several attempts to delete the old project, was able to get the edits to the right project. Still, though, the project continues to reappear in my Projects folder after I delete it!
Make sure your’re using the port labled with COM (not the USB labled) port on your ESP32-S3 board!
Otherwise you have to use
  -DARDUINO_USB_CDC_ON_BOOT=1
It can be a mismatched baud rate. Please check.
