Hi, I am trying to get a FRDM-k64F to work with platformio, debug included. So I need to communicate with it in cmsis-dap mode, but I get the following error in the pyOCD library:
ModuleNotFoundError: No module named ‘board’
Does anyone know how to solve this? Thank you.
$ platformio run -t upload -v Processing frdm_k64f (platform: freescalekinetis; board: frdm_k64f; framework: mbed; upload_protocol: cmsis-dap) ---------------------------------------------------------------------------------------- CONFIGURATION: https://docs.platformio.org/page/boards/freescalekinetis/frdm_k64f.html PLATFORM: Freescale Kinetis 5.0.1 > Freescale Kinetis FRDM-K64F HARDWARE: MK64FN1M0VLL12 120MHz, 256KB RAM, 1MB Flash DEBUG: Current (cmsis-dap) On-board (cmsis-dap) External (jlink) PACKAGES: - framework-mbed 6.51401.200113 (5.14.1) - tool-pyocd 0.801.0 (8.1) - toolchain-gccarmnoneeabi 1.70201.0 (7.2.1) Collecting mbed sources... LDF: Library Dependency Finder -> http://bit.ly/configure-pio-ldf LDF Modes: Finder ~ chain, Compatibility ~ soft Found 4 compatible libraries Scanning dependencies... No dependencies Building in release mode MethodWrapper(["checkprogsize"], [".pio/build/frdm_k64f/firmware.elf"]) Advanced Memory Usage is available via "PlatformIO Home > Project Inspect" RAM: [ ] 2.2% (used 5880 bytes from 262144 bytes) Flash: [ ] 4.5% (used 46712 bytes from 1048576 bytes) .pio/build/frdm_k64f/firmware.elf : section size addr .interrupts 1024 0 .flash_config 16 1024 .text 43928 1088 .ARM 8 45016 .init_array 4 45024 .fini_array 4 45028 .interrupts_ram 1024 536805376 .crash_data_ram 256 536806400 .heap_0 64256 536806656 .data 2784 536870912 .uninitialized 0 536873696 .bss 3096 536873696 .heap 186632 536876792 .ARM.attributes 46 0 .debug_info 428387 0 .debug_abbrev 54558 0 .debug_loc 113026 0 .debug_aranges 8016 0 .debug_ranges 11344 0 .debug_line 91581 0 .debug_str 99884 0 .comment 126 0 .debug_frame 26844 0 .stab 60 0 .stabstr 118 0 Total 1137022 <lambda>(["upload"], [".pio/build/frdm_k64f/firmware.bin"]) AVAILABLE: cmsis-dap, jlink, mbed CURRENT: upload_protocol = cmsis-dap "/home/daniele/.platformio/penv/bin/python3" "/home/daniele/.platformio/packages/tool-pyocd/pyocd-flashtool.py" -t k64f .pio/build/frdm_k64f/firmware.bin Traceback (most recent call last): File "/home/daniele/.platformio/packages/tool-pyocd/pyocd-flashtool.py", line 24, in <module> from pyOCD.tools.flash_tool import main File "/home/daniele/.platformio/packages/tool-pyocd/site-packages/pyOCD/__init__.py", line 18, in <module> import board ModuleNotFoundError: No module named 'board' *** [upload] Error 1 ============================== [FAILED] Took 5.45 seconds ==============================
This is the content of my platform.ini:
[env:frdm_k64f]
platform = freescalekinetis
board = frdm_k64f
framework = mbed
EDIT: solved by using an updated pyocd with custom upload and debug:
[env:frdm_k64f]
board = frdm_k64f
framework = mbed
upload_protocol = custom
upload_command = pyocd flash $SOURCE
debug_tool = custom
debug_server = pyocd-gdbserver
