Hello guys!
However I’m new in this forum, I’m using platformIO for years and I really appreciate your effort!
Today I’m facing some problems with some (maybe old) LCD libraries used in PlatformIO. The build log shows nothing really:
====================[ Build | Production | nanoatmega328 ]======================
C:\Users\zsolt\AppData\Local\JetBrains\Toolbox\apps\CLion\ch-0\221.5591.52\bin\cmake\win\bin\cmake.exe --build D:\arduino\scylla-display\cmake-build-nanoatmega328 --target Production -j 9
[1/1] cmd.exe /C "cd /D D:\arduino\scylla-display && platformio -c clion run -enanoatmega328"
FAILED: CMakeFiles/Production D:/arduino/scylla-display/cmake-build-nanoatmega328/CMakeFiles/Production
Processing nanoatmega328 (platform: atmelavr; board: nanoatmega328; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/nanoatmega328.html
PLATFORM: Atmel AVR (3.4.0) > Arduino Nano ATmega328
HARDWARE: ATMEGA328P 16MHz, 2KB RAM, 30KB Flash
- framework-arduino-avr @ 5.1.0
Found 10 compatible libraries
|-- Adafruit ST7735 and ST7789 Library @ 1.9.3(License: Unknown, Path: D:\arduino\scylla-display\.pio\libdeps\nanoatmega328\Adafruit ST7735 and ST7789 Library)
| |-- Adafruit GFX Library @ 1.11.1(License: Unknown, Path: D:\arduino\scylla-display\.pio\libdeps\nanoatmega328\Adafruit GFX Library)
| | |-- SPI @ 1.0(License: Unknown, Path: C:\Users\zsolt\.platformio\packages\framework-arduino-avr\libraries\SPI)
avr-g++ -o .pio\build\nanoatmega328\src\main.cpp.o -c -fno-exceptions -fno-threadsafe-statics -fpermissive -std=gnu++11 -Os -Wall -ffunction-sections -fdata-sections -flto -mmcu=atmega328p -DPLATFORMIO=60000 -DARDUINO_AVR_NANO -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO=10808 -Iinclude -Isrc "-I.pio\libdeps\nanoatmega328\Adafruit ST7735 and ST7789 Library" "-I.pio\libdeps\nanoatmega328\Adafruit GFX Library" -IC:\Users\zsolt\.platformio\packages\framework-arduino-avr\libraries\SPI\src -IC:\Users\zsolt\.platformio\packages\framework-arduino-avr\cores\arduino -IC:\Users\zsolt\.platformio\packages\framework-arduino-avr\variants\eightanaloginputs src\main.cpp
avr-g++ -o .pio\build\nanoatmega328\lib1e7\SPI\SPI.cpp.o -c -fno-exceptions -fno-threadsafe-statics -fpermissive -std=gnu++11 -Os -Wall -ffunction-sections -fdata-sections -flto -mmcu=atmega328p -DPLATFORMIO=60000 -DARDUINO_AVR_NANO -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO=10808 -IC:\Users\zsolt\.platformio\packages\framework-arduino-avr\libraries\SPI\src -IC:\Users\zsolt\.platformio\packages\framework-arduino-avr\cores\arduino -IC:\Users\zsolt\.platformio\packages\framework-arduino-avr\variants\eightanaloginputs C:\Users\zsolt\.platformio\packages\framework-arduino-avr\libraries\SPI\src\SPI.cpp
avr-g++ -o ".pio\build\nanoatmega328\libda7\Adafruit GFX Library\Adafruit_GFX.cpp.o" -c -fno-exceptions -fno-threadsafe-statics -fpermissive -std=gnu++11 -Os -Wall -ffunction-sections -fdata-sections -flto -mmcu=atmega328p -DPLATFORMIO=60000 -DARDUINO_AVR_NANO -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO=10808 "-I.pio\libdeps\nanoatmega328\Adafruit GFX Library" -IC:\Users\zsolt\.platformio\packages\framework-arduino-avr\libraries\SPI\src -IC:\Users\zsolt\.platformio\packages\framework-arduino-avr\cores\arduino -IC:\Users\zsolt\.platformio\packages\framework-arduino-avr\variants\eightanaloginputs ".pio\libdeps\nanoatmega328\Adafruit GFX Library\Adafruit_GFX.cpp"
avr-g++ -o ".pio\build\nanoatmega328\libda7\Adafruit GFX Library\Adafruit_GrayOLED.cpp.o" -c -fno-exceptions -fno-threadsafe-statics -fpermissive -std=gnu++11 -Os -Wall -ffunction-sections -fdata-sections -flto -mmcu=atmega328p -DPLATFORMIO=60000 -DARDUINO_AVR_NANO -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO=10808 "-I.pio\libdeps\nanoatmega328\Adafruit GFX Library" -IC:\Users\zsolt\.platformio\packages\framework-arduino-avr\libraries\SPI\src -IC:\Users\zsolt\.platformio\packages\framework-arduino-avr\cores\arduino -IC:\Users\zsolt\.platformio\packages\framework-arduino-avr\variants\eightanaloginputs ".pio\libdeps\nanoatmega328\Adafruit GFX Library\Adafruit_GrayOLED.cpp"
avr-g++ -o ".pio\build\nanoatmega328\libda7\Adafruit GFX Library\Adafruit_SPITFT.cpp.o" -c -fno-exceptions -fno-threadsafe-statics -fpermissive -std=gnu++11 -Os -Wall -ffunction-sections -fdata-sections -flto -mmcu=atmega328p -DPLATFORMIO=60000 -DARDUINO_AVR_NANO -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO=10808 "-I.pio\libdeps\nanoatmega328\Adafruit GFX Library" -IC:\Users\zsolt\.platformio\packages\framework-arduino-avr\libraries\SPI\src -IC:\Users\zsolt\.platformio\packages\framework-arduino-avr\cores\arduino -IC:\Users\zsolt\.platformio\packages\framework-arduino-avr\variants\eightanaloginputs ".pio\libdeps\nanoatmega328\Adafruit GFX Library\Adafruit_SPITFT.cpp"
avr-gcc -o ".pio\build\nanoatmega328\libda7\Adafruit GFX Library\glcdfont.c.o" -c -std=gnu11 -fno-fat-lto-objects -Os -Wall -ffunction-sections -fdata-sections -flto -mmcu=atmega328p -DPLATFORMIO=60000 -DARDUINO_AVR_NANO -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO=10808 "-I.pio\libdeps\nanoatmega328\Adafruit GFX Library" -IC:\Users\zsolt\.platformio\packages\framework-arduino-avr\libraries\SPI\src -IC:\Users\zsolt\.platformio\packages\framework-arduino-avr\cores\arduino -IC:\Users\zsolt\.platformio\packages\framework-arduino-avr\variants\eightanaloginputs ".pio\libdeps\nanoatmega328\Adafruit GFX Library\glcdfont.c"
avr-g++ -o ".pio\build\nanoatmega328\lib159\Adafruit ST7735 and ST7789 Library\Adafruit_ST7735.cpp.o" -c -fno-exceptions -fno-threadsafe-statics -fpermissive -std=gnu++11 -Os -Wall -ffunction-sections -fdata-sections -flto -mmcu=atmega328p -DPLATFORMIO=60000 -DARDUINO_AVR_NANO -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO=10808 "-I.pio\libdeps\nanoatmega328\Adafruit ST7735 and ST7789 Library" "-I.pio\libdeps\nanoatmega328\Adafruit GFX Library" -IC:\Users\zsolt\.platformio\packages\framework-arduino-avr\libraries\SPI\src -IC:\Users\zsolt\.platformio\packages\framework-arduino-avr\cores\arduino -IC:\Users\zsolt\.platformio\packages\framework-arduino-avr\variants\eightanaloginputs ".pio\libdeps\nanoatmega328\Adafruit ST7735 and ST7789 Library\Adafruit_ST7735.cpp"
avr-g++ -o ".pio\build\nanoatmega328\lib159\Adafruit ST7735 and ST7789 Library\Adafruit_ST7789.cpp.o" -c -fno-exceptions -fno-threadsafe-statics -fpermissive -std=gnu++11 -Os -Wall -ffunction-sections -fdata-sections -flto -mmcu=atmega328p -DPLATFORMIO=60000 -DARDUINO_AVR_NANO -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO=10808 "-I.pio\libdeps\nanoatmega328\Adafruit ST7735 and ST7789 Library" "-I.pio\libdeps\nanoatmega328\Adafruit GFX Library" -IC:\Users\zsolt\.platformio\packages\framework-arduino-avr\libraries\SPI\src -IC:\Users\zsolt\.platformio\packages\framework-arduino-avr\cores\arduino -IC:\Users\zsolt\.platformio\packages\framework-arduino-avr\variants\eightanaloginputs ".pio\libdeps\nanoatmega328\Adafruit ST7735 and ST7789 Library\Adafruit_ST7789.cpp"
avr-g++ -o ".pio\build\nanoatmega328\lib159\Adafruit ST7735 and ST7789 Library\Adafruit_ST77xx.cpp.o" -c -fno-exceptions -fno-threadsafe-statics -fpermissive -std=gnu++11 -Os -Wall -ffunction-sections -fdata-sections -flto -mmcu=atmega328p -DPLATFORMIO=60000 -DARDUINO_AVR_NANO -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO=10808 "-I.pio\libdeps\nanoatmega328\Adafruit ST7735 and ST7789 Library" "-I.pio\libdeps\nanoatmega328\Adafruit GFX Library" -IC:\Users\zsolt\.platformio\packages\framework-arduino-avr\libraries\SPI\src -IC:\Users\zsolt\.platformio\packages\framework-arduino-avr\cores\arduino -IC:\Users\zsolt\.platformio\packages\framework-arduino-avr\variants\eightanaloginputs ".pio\libdeps\nanoatmega328\Adafruit ST7735 and ST7789 Library\Adafruit_ST77xx.cpp"
avr-gcc-ar rc .pio\build\nanoatmega328\libFrameworkArduinoVariant.a
avr-g++ -o .pio\build\nanoatmega328\FrameworkArduino\CDC.cpp.o -c -fno-exceptions -fno-threadsafe-statics -fpermissive -std=gnu++11 -Os -Wall -ffunction-sections -fdata-sections -flto -mmcu=atmega328p -DPLATFORMIO=60000 -DARDUINO_AVR_NANO -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO=10808 -IC:\Users\zsolt\.platformio\packages\framework-arduino-avr\cores\arduino -IC:\Users\zsolt\.platformio\packages\framework-arduino-avr\variants\eightanaloginputs C:\Users\zsolt\.platformio\packages\framework-arduino-avr\cores\arduino\CDC.cpp
avr-g++ -o .pio\build\nanoatmega328\FrameworkArduino\HardwareSerial.cpp.o -c -fno-exceptions -fno-threadsafe-statics -fpermissive -std=gnu++11 -Os -Wall -ffunction-sections -fdata-sections -flto -mmcu=atmega328p -DPLATFORMIO=60000 -DARDUINO_AVR_NANO -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO=10808 -IC:\Users\zsolt\.platformio\packages\framework-arduino-avr\cores\arduino -IC:\Users\zsolt\.platformio\packages\framework-arduino-avr\variants\eightanaloginputs C:\Users\zsolt\.platformio\packages\framework-arduino-avr\cores\arduino\HardwareSerial.cpp
avr-gcc-ranlib .pio\build\nanoatmega328\libFrameworkArduinoVariant.a
ninja: build stopped: subcommand failed.
Can any of you help me out with this? I’m clueless.
What I did checked is the followings:
- Reinstalled the library several times.
- Created a blinky with the same board setup, works fine
- Tried to install library from git repo, nothing
- Installed the same library into Arduino IDE, works fine there
- Tried cleaning and reinitializing repo multiple times, nothing
Thanks for your help,
Zsolt
