Newie with codes
Can anyone help me with this mimic robot code? i am in the process of building today but want this code perfected please. help me
PlatformIO Project Configuration File
;#include <IRremote.h>
#include <Servo.h>
// Pin assignments for sensors and motors
const int distanceSensorPin = 2; // Ultrasonic or infrared sensor pin
const int leftMotorPin = 3; // Left motor control pin
const int rightMotorPin = 4; // Right motor control pin
const int IRReceiverPin = 11; // IR receiver pin
// Servo object for controlling the robot’s orientation
Servo orientationServo;
// Constants for controlling movement and tracking
const int stopDistance = 30; // Distance threshold to stop following (in cm)
const int rotationSpeed = 80; // Speed of servo rotation (adjust as needed)
const int forwardSpeed = 150; // Speed of forward movement (adjust as needed)
// IR Remote control setup
IRrecv irrecv(IRReceiverPin);
decode_results irData;
// Initialize the motor control pins
pinMode(leftMotorPin, OUTPUT);
pinMode(rightMotorPin, OUTPUT);
// Initialize the sensor pin
pinMode(distanceSensorPin, INPUT);
// Attach the servo to its control pin
orientationServo.attach(5); // Servo control pin
// Start with the robot facing forward
orientationServo.write(90);
// Start the IR receiver
irrecv.enableIRIn();
// Check for remote control input
if (irrecv.decode(&irData)) {
// Process the received IR signal
handleIRCommand(irData.value);
irrecv.resume(); // Receive the next IR signal
// Read the distance from the sensor
int distance = getDistance();
// If the person is within the desired range, stop and face forward
if (distance <= stopDistance) {
stop();
// If the person is detected, track and follow
else {
// Determine the direction of the person relative to the robot
int personDirection = getPersonDirection();
// Adjust the robot's orientation to face the person
orientationServo.write(personDirection);
// Move the robot forward
forward();
int getDistance() {
// Code to measure and return the distance from the sensor
// Adjust this function based on the specific sensor you are using
int getPersonDirection() {
// Code to determine the direction of the person relative to the robot
// This can be based on the position of the person detected by sensors
// Adjust this function based on the specific sensors and algorithm you are using
void handleIRCommand(unsigned long command) {
// Handle different IR remote commands
switch (command) {
case 0xFF906F: // Example command, adjust this based on your remote
forward();
break;
case 0xFFC23D: // Example command, adjust this based on your remote
backward();
break;
case 0xFF02FD: // Example command, adjust this based on your remote
left();
break;
case 0xFF22DD: // Example command, adjust this based on your remote
right();
break;
case 0xFFA857: // Example command, adjust this based on your remote
stop();
break;
// Add more cases for other remote commands as needed
void stop() {
// Code to stop the robot’s movement
digitalWrite(leftMotorPin, LOW);
digitalWrite(rightMotorPin, LOW);
void forward() {
// Code to move the robot forward
digitalWrite(leftMotorPin, HIGH);
digitalWrite(rightMotorPin, HIGH);
// Additional code for controlling the direction and speed of the motors
void backward() {
// Code to move the robot backward
// Implement this based on your specific motor configuration
void left() {
// Code to turn the robot left
void right() {
// Code to turn the robot right
; Redirecting...
[env:nanoatmega328]
board = nanoatmega328
