Newest ESP32-PLATFORMIO framework isn working properly
Nothing works properly. I have problems with wire lib,spi lib,I have this issue with ESP32 S3 ILI9341 problems with rotation of display and rendering · Issue #3457 · Bodmer/TFT_eSPI · GitHub this lib also I see that anything that accesses wire crashes the esp.
I extracted esp32 s3 bactrace and the error is in this.
with help from https://www.msys2.org/ addr2line tool. I dont know.
C:/Users/micha/.platformio/packages/framework-arduinoespressif32@3.20006.221224/libraries/Wire/src/Wire.cpp:409
C:/Users/micha/.platformio/packages/framework-arduinoespressif32@3.20006.221224/libraries/Wire/src/Wire.cpp:637
Idk what is going on
Even better on arduino esp32 framework it is working fine.
I found this error of diplay library like 20 days before.
sorry for my broken english Im just frustrated.
There could be several sources of error.
  • Are you using the same Arduino-ESP32 core version in PlatformIO as you do in the Arduino IDE?
  • Are you using the same TFT_eSPI library version in PlatformIO as you do in the Arduino IDE?
  • Are you using the same TFT_eSPI configuration file / options in PlatformIO as you do in the Arduino IDE?
These are the basic ones. From your log of
It’s already apparent that you’re running an outdated version of the espressif32 platform with Arduino-ESP32 2.0.6. Is this intentional? The latest release works on Arduino-ESP32 2.0.17. Note that this is still not the very latest Arduino-ESP32 v3.0.4.
What we need for now is
  • your exact platformio.ini
  • PlatformIO Core CLIpio run -t clean && pio run -v -j1 > compile.txt (the compile log, upload to https://pastebin.com/ and paste link here)
  • In the Arduino IDE: File → Preferences → Turn on “Verbose Build”. Press the build button again. Copy-paste all the output into https://pastebin.com/ and paste link here
Thanks for answering.
Sorry I used the wrong text but even the newest doestn work.
Im runing wait like 5min.
btw where can i locate the compile.txt
nothing just i got it
platform io
sorry i dont have native version of arduino ide of my program just display testing codes
btw i can totaly provide you source if you want.
Is everything ok? What is it looking to be the bug?
