Hi All
I am trying to move from Arduino IDE to PlatformIO and its a very step learning curve
I have build the code previously in Arduino IDE and have had it run successfully but had a few little issues so I thought I would migrate my build to here but have got more issues that I cant find solutions for.
Its failed and I don’t know why. I am also a newbie in code writing so be gentle.
My Code is this
#include <WiFi.h>
#include <HTTPClient.h>
#include <HX711.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#include <DHT.h>
#define calibration_factor -21500.0
#define zero_factor 8364129
#define LOADCELL_DOUT_PIN 22
#define LOADCELL_SCK_PIN 23
// Replace with your network credentials
const char* ssid = "....";
const char* password = "....";
// REPLACE with your Domain name and URL path or IP address with path
const char* serverName = ".....";
// Keep this API Key value to be compatible with the PHP code provided in the project page.
// If you change the apiKeyValue value, the PHP file /post-data.php also needs to have the same key
String apiKeyValue = "....";
#define DHTPIN 4 // Digital pin connected to the DHT sensor
#define DHTTYPE DHT22 // DHT 22 (AM2302), AM2321
#define ONE_WIRE_BUS 15 // Data wire is connected to GPIO15
HX711 scale;
// Setup a oneWire instance to communicate with a OneWire device
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature sensor
DallasTemperature sensors(&oneWire);
DeviceAddress sensor1 = { 0x28, 0x6A, 0x48, 0x7C, 0x0C, 0x00, 0x00, 0xC4 }; // long
DeviceAddress sensor2 = { 0x28, 0xFA, 0x14, 0x7B, 0x0C, 0x00, 0x00, 0x47 }; //short
DHT dht(DHTPIN, DHTTYPE);
// Time to sleep
uint64_t uS_TO_S_FACTOR = 1000000; // Conversion factor for micro seconds to seconds
// sleep for 30 minutes = 1800 seconds
uint64_t TIME_TO_SLEEP = 1800;
// Get Sensor Readings
String getSensorReadings() {
sensors.requestTemperatures();
Serial.begin(9600);
sensors.begin();
dht.begin();
scale.begin(LOADCELL_DOUT_PIN, LOADCELL_SCK_PIN);
scale.set_scale(calibration_factor); //This value is obtained by using the SparkFun_HX711_Calibration sketch
scale.set_offset(zero_factor); //Zero out the scale using a previously known zero_factor
WiFi.begin(ssid, password);
Serial.println("Connecting");
while(WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println("");
Serial.print("Connected to WiFi network with IP Address: ");
// enable timer deep sleep
esp_sleep_enable_timer_wakeup(TIME_TO_SLEEP * uS_TO_S_FACTOR);
void loop(){
Serial.println("Requesting temperatures...");
sensors.requestTemperatures(); // Send the command to get temperatures
// Serial.println("DONE");
Serial.print("8 Frame Hive: ");
Serial.print(sensors.getTempC(sensor1));
Serial.print("°C: ");
Serial.print("10 Frame Hive: ");
Serial.print(sensors.getTempC(sensor2));
Serial.print("Weight ");
Serial.print(scale.get_units(), 1);
Serial.print(" Kgs ");
// Reading temperature or humidity takes about 250 milliseconds!
// Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
float h = dht.readHumidity();
// Read temperature as Celsius (the default)
float t = dht.readTemperature();
// Check if any reads failed and exit early (to try again).
if (isnan(h) || isnan(t)) {
Serial.println(F("Failed to read from DHT sensor!"));
return;
Serial.print(F("8 Frame Roof Temp: "));
Serial.print(t);
Serial.print(F("°C "));
Serial.print(F("8 Frame Roof Humidity: "));
Serial.print(h);
Serial.print(F("% "));
Serial. print('\n');
delay(5000);
//Check WiFi connection status
if(WiFi.status()== WL_CONNECTED){
HTTPClient http;
// Your Domain name with URL path or IP address with path
http.begin(serverName);
// Specify content-type header
http.addHeader("Content-Type", "application/x-www-form-urlencoded");
// Prepare your HTTP POST request data
String httpRequestData = "api_key=" + apiKeyValue + "&value1=" + String(dht.readTemperature())
+ "&value2=" + String(dht.readHumidity()) + "&value3=" + String(sensors.getTempC(sensor1)) + "&value4=" + String(sensors.getTempC(sensor2))+ "&value5=" + String(scale.get_units(), 1) +"";
Serial.print("httpRequestData: ");
Serial.println(httpRequestData);
// Send HTTP POST request
int httpResponseCode = http.POST(httpRequestData);
// If you need an HTTP request with a content type: text/plain
//http.addHeader("Content-Type", "text/plain");
//int httpResponseCode = http.POST("Hello, World!");
// If you need an HTTP request with a content type: application/json, use the following:
//http.addHeader("Content-Type", "application/json");
//int httpResponseCode = http.POST("{\"value1\":\"19\",\"value2\":\"67\",\"value3\":\"78\"}");
if (httpResponseCode>0) {
Serial.print("HTTP Response code: ");
Serial.println(httpResponseCode);
else {
Serial.print("Error code: ");
// Free resources
http.end();
else {
Serial.println("WiFi Disconnected");
// //Send an HTTP POST request every 30 seconds
// delay(30000);
// // Wait a few seconds between measurements.
// delay(20000);
Serial.println("Going to sleep now");
// start deep sleep for 1800 seconds (30 minutes)
esp_deep_sleep_start();
And My Build log is
Processing esp32doit-devkit-v1 (platform: espressif32; board: esp32doit-devkit-v1; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/esp32doit- devkit-v1.html
PLATFORM: Espressif 32 (3.3.0) > DOIT ESP32 DEVKIT V1
- framework-arduinoespressif32 3.10006.210326 (1.0.6)
- tool-esptoolpy 1.30100.210531 (3.1.0)
- toolchain-xtensa32 2.50200.97 (5.2.0)
Found 33 compatible libraries
|-- <HX711> 0.7.4
|-- <OneWire> 2.3.5
|-- <DallasTemperature> 3.9.1
| |-- <OneWire> 2.3.5
|-- <DHT sensor library> 1.4.2
| |-- <Adafruit Unified Sensor> 1.1.4
|-- <HTTPClient> 1.2
| |-- <WiFi> 1.0
| |-- <WiFiClientSecure> 1.0
| | |-- <WiFi> 1.0
|-- <WiFi> 1.0
Compiling .pio\build\esp32doit-devkit-v1\src\Sparkfun Calibration JP.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\src\Temp Humidity and weight v1.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\src\main.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\lib5b4\HX711\HX711.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\libb25\OneWire\OneWire.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\liba08\DallasTemperature \DallasTemperature.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\libf67\Adafruit Unified Sensor\Adafruit_Sensor.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\lib7f8\DHT sensor library\DHT.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\lib7f8\DHT sensor library\DHT_U.cpp.o
src\Temp Humidity and weight v1.cpp: In function 'String getSensorReadings()':
src\Temp Humidity and weight v1.cpp:57:1: warning: no return statement in function returning non-void [-Wreturn-type]
.pio\libdeps\esp32doit-devkit-v1\OneWire\OneWire.cpp: In member function 'uint8_t OneWire::reset()':
.pio\libdeps\esp32doit-devkit-v1\OneWire\OneWire.cpp:167:24: warning: unused variable 'reg' [-Wunused-variable]
volatile IO_REG_TYPE *reg IO_REG_BASE_ATTR = baseReg;
.pio\libdeps\esp32doit-devkit-v1\OneWire\OneWire.cpp: In member function 'void OneWire::write_bit(uint8_t)':
.pio\libdeps\esp32doit-devkit-v1\OneWire\OneWire.cpp:201:24: warning: unused variable 'reg' [-Wunused-variable]
.pio\libdeps\esp32doit-devkit-v1\OneWire\OneWire.cpp: In member function 'uint8_t OneWire::read_bit()':
.pio\libdeps\esp32doit-devkit-v1\OneWire\OneWire.cpp:229:24: warning: unused variable 'reg' [-Wunused-variable]
Compiling .pio\build\esp32doit-devkit-v1\lib80b\WiFi\ETH.cpp.o
Archiving .pio\build\esp32doit-devkit-v1\lib5b4\libHX711.a
Compiling .pio\build\esp32doit-devkit-v1\lib80b\WiFi\WiFi.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\lib80b\WiFi\WiFiAP.cpp.o
Archiving .pio\build\esp32doit-devkit-v1\libb25\libOneWire.a
Compiling .pio\build\esp32doit-devkit-v1\lib80b\WiFi\WiFiClient.cpp.o
Archiving .pio\build\esp32doit-devkit-v1\libf67\libAdafruit Unified Sensor.a
Archiving .pio\build\esp32doit-devkit-v1\liba08\libDallasTemperature.a
Compiling .pio\build\esp32doit-devkit-v1\lib80b\WiFi\WiFiGeneric.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\lib80b\WiFi\WiFiMulti.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\lib80b\WiFi\WiFiSTA.cpp.o
Archiving .pio\build\esp32doit-devkit-v1\lib7f8\libDHT sensor library.a
Compiling .pio\build\esp32doit-devkit-v1\lib80b\WiFi\WiFiScan.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\lib80b\WiFi\WiFiServer.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\lib80b\WiFi\WiFiUdp.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\lib1eb\WiFiClientSecure \WiFiClientSecure.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\lib1eb\WiFiClientSecure\ssl_client.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\libe26\HTTPClient\HTTPClient.cpp.o
Archiving .pio\build\esp32doit-devkit-v1\lib80b\libWiFi.a
Archiving .pio\build\esp32doit-devkit-v1\lib1eb\libWiFiClientSecure.a
Archiving .pio\build\esp32doit-devkit-v1\libe26\libHTTPClient.a
Linking .pio\build\esp32doit-devkit-v1\firmware.elf
.pio\build\esp32doit-devkit-v1\src\Temp Humidity and weight v1.cpp.o: (.bss.scale+0x0): multiple definition of `scale'
.pio\build\esp32doit-devkit-v1\src\Sparkfun Calibration JP.cpp.o:(.bss.scale+0x0): first defined here
.pio\build\esp32doit-devkit-v1\src\Temp Humidity and weight v1.cpp.o: In function `setup()':
Temp Humidity and weight v1.cpp:(.text._Z5setupv+0x0): multiple definition of `setup()'
.pio\build\esp32doit-devkit-v1\src\Sparkfun Calibration JP.cpp.o:Sparkfun Calibration JP.cpp:(.text._Z5setupv+0x0): first defined here
.pio\build\esp32doit-devkit-v1\src\main.cpp.o: In function `setup()':
main.cpp:(.text._Z5setupv+0x0): multiple definition of `setup()'
.pio\build\esp32doit-devkit-v1\src\main.cpp.o: In function `loop()':
main.cpp:(.text._Z4loopv+0x0): multiple definition of `loop()'
.pio\build\esp32doit-devkit-v1\src\Temp Humidity and weight v1.cpp.o:Temp Humidity and weight v1.cpp:(.text._Z4loopv+0x0): first defined here
*** [.pio\build\esp32doit-devkit-v1\firmware.elf] Error 1
================================================= [FAILED] Took 32.24 seconds =================================================
The terminal process "C:\Users\jcp\.platformio\penv\Scripts\platformio.exe 'run'" terminated with exit code: 1.
> Executing task in folder Bee Hive Monitor: C:\Users\jcp\.platformio\penv\Scripts \platformio.exe run <
