New TinyUSB doesn't allow compile?
I just upgraded to the new TinyUSB version that was released, from 3.1.4 to 3.4.0, and I’m getting all of these messages when I try to compile:
I’m totally lost on what this could be. I even switched back to 3.1.4, and PlatformIO reinstalled that version in my project, and yet I’m getting the same message again! Any ideas?
In file included from .pio/libdeps/esp32-s3-devkitc-1/Adafruit TinyUSB Library/src/Adafruit_TinyUSB.h:30,
from .pio/libdeps/esp32-s3-devkitc-1/Adafruit TinyUSB Library/src/arduino/Adafruit_TinyUSB_API.cpp:29:
.pio/libdeps/esp32-s3-devkitc-1/Adafruit TinyUSB Library/src/arduino/ports/esp32/tusb_config_esp32.h:92: warning: “CFG_TUH_ENABLED” redefined
#define CFG_TUH_ENABLED 1
In file included from .pio/libdeps/esp32-s3-devkitc-1/Adafruit TinyUSB Library/src/arduino/Adafruit_TinyUSB_API.cpp:25:
.pio/libdeps/esp32-s3-devkitc-1/Adafruit TinyUSB Library/src/tusb_option.h:318: note: this is the location of the previous definition
#define CFG_TUH_ENABLED (TUH_RHPORT_MODE & OPT_MODE_HOST)
.pio/libdeps/esp32-s3-devkitc-1/Adafruit TinyUSB Library/src/arduino/ports/esp32/tusb_config_esp32.h:93: warning: “CFG_TUH_MAX_SPEED” redefined
#define CFG_TUH_MAX_SPEED OPT_MODE_FULL_SPEED
.pio/libdeps/esp32-s3-devkitc-1/Adafruit TinyUSB Library/src/tusb_option.h:323: note: this is the location of the previous definition
#define CFG_TUH_MAX_SPEED (TUH_RHPORT_MODE & OPT_MODE_SPEED_MASK)
.pio/libdeps/esp32-s3-devkitc-1/Adafruit TinyUSB Library/src/arduino/ports/esp32/tusb_config_esp32.h:94: warning: “CFG_TUH_MAX3421” redefined
#define CFG_TUH_MAX3421 1
.pio/libdeps/esp32-s3-devkitc-1/Adafruit TinyUSB Library/src/tusb_option.h:267: note: this is the location of the previous definition
#define CFG_TUH_MAX3421 0
.pio/libdeps/esp32-s3-devkitc-1/Adafruit TinyUSB Library/src/arduino/ports/esp32/tusb_config_esp32.h:104: warning: “CFG_TUH_HUB” redefined
#define CFG_TUH_HUB 1
.pio/libdeps/esp32-s3-devkitc-1/Adafruit TinyUSB Library/src/tusb_option.h:512: note: this is the location of the previous definition
#define CFG_TUH_HUB 0
.pio/libdeps/esp32-s3-devkitc-1/Adafruit TinyUSB Library/src/arduino/ports/esp32/tusb_config_esp32.h:113: warning: “CFG_TUH_MSC” redefined
#define CFG_TUH_MSC 1
.pio/libdeps/esp32-s3-devkitc-1/Adafruit TinyUSB Library/src/tusb_option.h:569: note: this is the location of the previous definition
#define CFG_TUH_MSC 0
.pio/libdeps/esp32-s3-devkitc-1/Adafruit TinyUSB Library/src/arduino/ports/esp32/tusb_config_esp32.h:117: warning: “CFG_TUH_HID” redefined
#define CFG_TUH_HID (3 * CFG_TUH_DEVICE_MAX)
.pio/libdeps/esp32-s3-devkitc-1/Adafruit TinyUSB Library/src/tusb_option.h:561: note: this is the location of the previous definition
#define CFG_TUH_HID 0
.pio/libdeps/esp32-s3-devkitc-1/Adafruit TinyUSB Library/src/arduino/ports/esp32/tusb_config_esp32.h:121: warning: “CFG_TUH_CDC” redefined
#define CFG_TUH_CDC 1
.pio/libdeps/esp32-s3-devkitc-1/Adafruit TinyUSB Library/src/tusb_option.h:516: note: this is the location of the previous definition
#define CFG_TUH_CDC 0
.pio/libdeps/esp32-s3-devkitc-1/Adafruit TinyUSB Library/src/arduino/ports/esp32/tusb_config_esp32.h:122: warning: “CFG_TUH_CDC_FTDI” redefined
#define CFG_TUH_CDC_FTDI 1
.pio/libdeps/esp32-s3-devkitc-1/Adafruit TinyUSB Library/src/tusb_option.h:521: note: this is the location of the previous definition
#define CFG_TUH_CDC_FTDI 0
.pio/libdeps/esp32-s3-devkitc-1/Adafruit TinyUSB Library/src/arduino/ports/esp32/tusb_config_esp32.h:123: warning: “CFG_TUH_CDC_CP210X” redefined
#define CFG_TUH_CDC_CP210X 1
.pio/libdeps/esp32-s3-devkitc-1/Adafruit TinyUSB Library/src/tusb_option.h:534: note: this is the location of the previous definition
#define CFG_TUH_CDC_CP210X 0
.pio/libdeps/esp32-s3-devkitc-1/Adafruit TinyUSB Library/src/arduino/ports/esp32/tusb_config_esp32.h:124: warning: “CFG_TUH_CDC_CH34X” redefined
#define CFG_TUH_CDC_CH34X 1
.pio/libdeps/esp32-s3-devkitc-1/Adafruit TinyUSB Library/src/tusb_option.h:545: note: this is the location of the previous definition
#define CFG_TUH_CDC_CH34X 0
Compiling .pio/build/esp32-s3-devkitc-1/lib4ad/Adafruit TinyUSB Library/arduino/Adafruit_USBD_Interface.cpp.o
Compiling .pio/build/esp32-s3-devkitc-1/lib4ad/Adafruit TinyUSB Library/arduino/Adafruit_USBH_Host.cpp.o
Compiling .pio/build/esp32-s3-devkitc-1/lib4ad/Adafruit TinyUSB Library/arduino/cdc/Adafruit_USBH_CDC.cpp.o
Compiling .pio/build/esp32-s3-devkitc-1/lib4ad/Adafruit TinyUSB Library/arduino/hid/Adafruit_USBD_HID.cpp.o
Compiling .pio/build/esp32-s3-devkitc-1/lib4ad/Adafruit TinyUSB Library/arduino/midi/Adafruit_USBD_MIDI.cpp.o
Compiling .pio/build/esp32-s3-devkitc-1/lib4ad/Adafruit TinyUSB Library/arduino/msc/Adafruit_USBD_MSC.cpp.o
Compiling .pio/build/esp32-s3-devkitc-1/lib4ad/Adafruit TinyUSB Library/arduino/msc/Adafruit_USBH_MSC.cpp.o
Compiling .pio/build/esp32-s3-devkitc-1/lib4ad/Adafruit TinyUSB Library/arduino/ports/ch32/Adafruit_TinyUSB_ch32.cpp.o
Compiling .pio/build/esp32-s3-devkitc-1/lib4ad/Adafruit TinyUSB Library/arduino/ports/esp32/Adafruit_TinyUSB_esp32.cpp.o
Compiling .pio/build/esp32-s3-devkitc-1/lib4ad/Adafruit TinyUSB Library/arduino/ports/nrf/Adafruit_TinyUSB_nrf.cpp.o
Compiling .pio/build/esp32-s3-devkitc-1/lib4ad/Adafruit TinyUSB Library/arduino/ports/rp2040/Adafruit_TinyUSB_rp2040.cpp.o
Compiling .pio/build/esp32-s3-devkitc-1/lib4ad/Adafruit TinyUSB Library/arduino/ports/samd/Adafruit_TinyUSB_samd.cpp.o
Compiling .pio/build/esp32-s3-devkitc-1/lib4ad/Adafruit TinyUSB Library/arduino/video/Adafruit_USBD_Video.cpp.o
Compiling .pio/build/esp32-s3-devkitc-1/lib4ad/Adafruit TinyUSB Library/arduino/webusb/Adafruit_USBD_WebUSB.cpp.o
Compiling .pio/build/esp32-s3-devkitc-1/lib4ad/Adafruit TinyUSB Library/class/audio/audio_device.c.o
Compiling .pio/build/esp32-s3-devkitc-1/lib4ad/Adafruit TinyUSB Library/class/bth/bth_device.c.o
Compiling .pio/build/esp32-s3-devkitc-1/lib4ad/Adafruit TinyUSB Library/class/cdc/cdc_device.c.o
Compiling .pio/build/esp32-s3-devkitc-1/lib4ad/Adafruit TinyUSB Library/class/cdc/cdc_host.c.o
Compiling .pio/build/esp32-s3-devkitc-1/lib4ad/Adafruit TinyUSB Library/class/dfu/dfu_device.c.o
Compiling .pio/build/esp32-s3-devkitc-1/lib4ad/Adafruit TinyUSB Library/class/dfu/dfu_rt_device.c.o
Compiling .pio/build/esp32-s3-devkitc-1/lib4ad/Adafruit TinyUSB Library/class/hid/hid_device.c.o
Compiling .pio/build/esp32-s3-devkitc-1/lib4ad/Adafruit TinyUSB Library/class/hid/hid_host.c.o
Compiling .pio/build/esp32-s3-devkitc-1/lib4ad/Adafruit TinyUSB Library/class/midi/midi_device.c.o
Compiling .pio/build/esp32-s3-devkitc-1/lib4ad/Adafruit TinyUSB Library/class/msc/msc_device.c.o
Compiling .pio/build/esp32-s3-devkitc-1/lib4ad/Adafruit TinyUSB Library/class/msc/msc_host.c.o
Compiling .pio/build/esp32-s3-devkitc-1/lib4ad/Adafruit TinyUSB Library/class/net/ecm_rndis_device.c.o
Compiling .pio/build/esp32-s3-devkitc-1/lib4ad/Adafruit TinyUSB Library/class/net/ncm_device.c.o
Compiling .pio/build/esp32-s3-devkitc-1/lib4ad/Adafruit TinyUSB Library/class/usbtmc/usbtmc_device.c.o
Compiling .pio/build/esp32-s3-devkitc-1/lib4ad/Adafruit TinyUSB Library/class/vendor/vendor_device.c.o
Compiling .pio/build/esp32-s3-devkitc-1/lib4ad/Adafruit TinyUSB Library/class/video/video_device.c.o
Compiling .pio/build/esp32-s3-devkitc-1/lib4ad/Adafruit TinyUSB Library/common/tusb_fifo.c.o
Compiling .pio/build/esp32-s3-devkitc-1/lib4ad/Adafruit TinyUSB Library/device/usbd.c.o
Compiling .pio/build/esp32-s3-devkitc-1/lib4ad/Adafruit TinyUSB Library/device/usbd_control.c.o
Compiling .pio/build/esp32-s3-devkitc-1/lib4ad/Adafruit TinyUSB Library/host/hub.c.o
Compiling .pio/build/esp32-s3-devkitc-1/lib4ad/Adafruit TinyUSB Library/host/usbh.c.o
Compiling .pio/build/esp32-s3-devkitc-1/lib4ad/Adafruit TinyUSB Library/portable/analog/max3421/hcd_max3421.c.o
Compiling .pio/build/esp32-s3-devkitc-1/lib4ad/Adafruit TinyUSB Library/portable/microchip/samd/dcd_samd.c.o
Compiling .pio/build/esp32-s3-devkitc-1/lib4ad/Adafruit TinyUSB Library/portable/nordic/nrf5x/dcd_nrf5x.c.o
Compiling .pio/build/esp32-s3-devkitc-1/lib4ad/Adafruit TinyUSB Library/portable/raspberrypi/pio_usb/dcd_pio_usb.c.o
Compiling .pio/build/esp32-s3-devkitc-1/lib4ad/Adafruit TinyUSB Library/portable/raspberrypi/pio_usb/hcd_pio_usb.c.o
Compiling .pio/build/esp32-s3-devkitc-1/lib4ad/Adafruit TinyUSB Library/portable/raspberrypi/rp2040/dcd_rp2040.c.o
Compiling .pio/build/esp32-s3-devkitc-1/lib4ad/Adafruit TinyUSB Library/portable/raspberrypi/rp2040/hcd_rp2040.c.o
Compiling .pio/build/esp32-s3-devkitc-1/lib4ad/Adafruit TinyUSB Library/portable/raspberrypi/rp2040/rp2040_usb.c.o
Compiling .pio/build/esp32-s3-devkitc-1/lib4ad/Adafruit TinyUSB Library/portable/st/stm32_fsdev/dcd_stm32_fsdev.c.o
Compiling .pio/build/esp32-s3-devkitc-1/lib4ad/Adafruit TinyUSB Library/portable/synopsys/dwc2/dcd_dwc2.c.o
Compiling .pio/build/esp32-s3-devkitc-1/lib4ad/Adafruit TinyUSB Library/portable/wch/dcd_ch32_usbfs.c.o
Compiling .pio/build/esp32-s3-devkitc-1/lib4ad/Adafruit TinyUSB Library/portable/wch/dcd_ch32_usbhs.c.o
Compiling .pio/build/esp32-s3-devkitc-1/lib4ad/Adafruit TinyUSB Library/tusb.c.o
Compiling .pio/build/esp32-s3-devkitc-1/lib041/MIDI Library/MIDI.cpp.o
Compiling .pio/build/esp32-s3-devkitc-1/src/main.cpp.o
Building .pio/build/esp32-s3-devkitc-1/bootloader.bin
Generating partitions .pio/build/esp32-s3-devkitc-1/partitions.bin
esptool.py v4.5.1
Creating esp32s3 image…
Merged 1 ELF section
Successfully created esp32s3 image.
Compiling .pio/build/esp32-s3-devkitc-1/FrameworkArduino/Esp.cpp.o
Compiling .pio/build/esp32-s3-devkitc-1/FrameworkArduino/FirmwareMSC.cpp.o
Compiling .pio/build/esp32-s3-devkitc-1/FrameworkArduino/FunctionalInterrupt.cpp.o
Compiling .pio/build/esp32-s3-devkitc-1/FrameworkArduino/HWCDC.cpp.o
Compiling .pio/build/esp32-s3-devkitc-1/FrameworkArduino/HardwareSerial.cpp.o
Compiling .pio/build/esp32-s3-devkitc-1/FrameworkArduino/IPAddress.cpp.o
Compiling .pio/build/esp32-s3-devkitc-1/FrameworkArduino/IPv6Address.cpp.o
Compiling .pio/build/esp32-s3-devkitc-1/FrameworkArduino/MD5Builder.cpp.o
Compiling .pio/build/esp32-s3-devkitc-1/FrameworkArduino/Print.cpp.o
For what it’s worth, I ran into the same error of a bunch of redefinitions this afternoon, and spent hours on it. I also couldn’t link due to double function definitions (not sure if you had the same and your log cut off, or if it built for you but had warnings). Here’s a sample of the first two linker errors:
Compiling .pio\build\sim_board\FrameworkArduino\wiring_shift.c.o
Archiving .pio\build\sim_board\libFrameworkArduino.a
Indexing .pio\build\sim_board\libFrameworkArduino.a
Linking .pio\build\sim_board\firmware.elf
c:/users/jeff/.platformio/packages/toolchain-xtensa-esp32s2/bin/../lib/gcc/xtensa-esp32s2-elf/12.2.0/../../../../xtensa-esp32s2-elf/bin/ld.exe: C:/Users/Jeff/.platformio/packages/framework-arduinoespressif32-libs/esp32s2/lib\libarduino_tinyusb.a(tusb.c.obj): in function `tusb_inited':
/home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/components/arduino_tinyusb/tinyusb/src/tusb.c:60: multiple definition of `tusb_inited'; .pio/build/sim_board/lib49d/libAdafruit TinyUSB Library.a(tusb.c.o):C:\Users\Jeff\Nextcloud\Git\sim_project/.pio/libdeps/sim_project/Adafruit TinyUSB Library/src/tusb.c:102: first defined here
c:/users/jeff/.platformio/packages/toolchain-xtensa-esp32s2/bin/../lib/gcc/xtensa-esp32s2-elf/12.2.0/../../../../xtensa-esp32s2-elf/bin/ld.exe: C:/Users/Jeff/.platformio/packages/framework-arduinoespressif32-libs/esp32s2/lib\libarduino_tinyusb.a(tusb.c.obj): in function `tu_desc_find':
/home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/components/arduino_tinyusb/tinyusb/src/tusb.c:78: multiple definition of `tu_desc_find'; .pio/build/sim_board/lib49d/libAdafruit TinyUSB Library.a(tusb.c.o):C:\Users\Jeff\Nextcloud\Git\sim_project/.pio/libdeps/sim_project/Adafruit TinyUSB Library/src/tusb.c:137: first defined here
It did work for me when I explicitly set the Adafruit TinyUSB library version to 3.3.1, but I don’t know why. I wish I’d tried that sooner.
Yes! That’s exactly what is happening to me.
So TinyUSB is already built into the Arduino-ESP32 core in a precompiled form? Then how can you just decide to update it or throw a different TinyUSB version in, on-top? You would need to recompile the core including that prebuilt lib, no? https://github.com/espressif/esp32-arduino-lib-builder
That makes sense, but what doesn’t make sense is that the Adafruit TinyUSB library v3.3.1 (and presumably others) has been working with normal deployment for quite a while. I have this in my platformio.ini file:
[env:develop]
board = lolin_s2_mini
	adafruit/Adafruit TinyUSB Library@3.3.1
…and this in the main header for my app:
#include <SPI.h>
#include <Adafruit_TinyUSB.h>
…and this in the source file that initializes and uses the USB device:
Adafruit_USBD_HID usb_hid(usb_descriptor, sizeof(usb_descriptor), HID_ITF_PROTOCOL_NONE, 2, true);
void usbdev_init()
    // configure USB device
    TinyUSBDevice.setID(CUSTOM_USB_VID, CUSTOM_USB_PID);
    TinyUSBDevice.setDeviceVersion(CUSTOM_USB_DEVICE_VERSION);
    TinyUSBDevice.setManufacturerDescriptor(CUSTOM_USB_MANUFACTURER_STRING);
    TinyUSBDevice.setProductDescriptor(CUSTOM_USB_PRODUCT_STRING);
    // initialize USB HID via TinyUSB
    usb_hid.enableOutEndpoint(true);
    usb_hid.setPollInterval(2);
    usb_hid.setReportDescriptor(usb_descriptor, sizeof(usb_descriptor));
    usb_hid.setReportCallback(hid_get_report_callback, hid_set_report_callback);
    usb_hid.begin();
If we drop Adafruit’s library, do we lose the whole layer of functionality that they’ve built, or is it accessible some other way using the TinyUSB library that’s part of the core?
It looks like Adafruit’s v3.3.1 (or something pre-v3.4.0) is able to peacefully coexist without duplicate definitions. I’m all for whatever lets this continue going forward, including a change to Adafruit’s library code–since it seems like something on their end is what broke the v3.4.0 integration in the first place. Maybe.
Have you been able to figure it out? I still can’t - I confirmed that it is indeed adafruit tinyusb 3.4 and above that breaks it.
If I don’t need to install the adafruit library because it’s redundant, and I can create usb midi devices, this is great too! But this isn’t clear how to do this and how to use the build in MIDI object instead of Adafruit tinyusb
I haven’t spent any effort on making 3.4.x+ work since rolling back to the exact 3.3.1 version in platformio.ini allowed me to keep doing what I needed to do. It’s obviously not an ideal solution, but would the same work for you?
It was good enough for me too – thanks for posting your solution/workaround!
Using actual espressif Arduino core with
platform = https://github.com/pioarduino/platform-espressif32/releases/download/53.03.13/platform-espressif32.zip
and actual TinyUSB will work
Trying to link TinyUSB as static library into pre-existing STM32U575 codebase. The makefile-based builds for the TinyUSB examples are not suitable for us.
May be no one notice this.
What do you want us to do specifically? Create a PlatformIO project for some STM32U575 chip with framework = ??? that has TinyUSB included?
