New library MultiLog
i created a small library MultiLog, that provides a unified interface to send debugging information to a serial interface or/and a UDP destination: GitHub - dervomsee/multilog: UDP logging library
When you are connected through USB debugging is easy with the HW serial interface. For most of my projects i use OTA. With this library you can use the same mechanism to debug the code.
To receive the debugging information you can use this small Windows application: GitHub - dervomsee/UdpMessageViewer: Udp Message Viewer
What are your thoughts about it?
BR, Cornelius
