I am trying to add a custom board to the platformio directory, so far I’ve copied a file from platforms/esp32, and following the instructions I can see the new board with platformio.
When I try creating a new project with that new board, I get an error. PIO is updated.
PIO Core Call Error:
The next files/directories have been created in C:\Users\fault\Documents\PlatformIO\Projects\HelloWorld
File "c:\users\fault\.platformio\penv\lib\site-packages\platformio\__main__.py", line 121, in main
File "c:\users\fault\.platformio\penv\lib\site-packages\click\core.py", line 1128, in __call__
File "c:\users\fault\.platformio\penv\lib\site-packages\click\core.py", line 1053, in main
rv = self.invoke(ctx)
File "c:\users\fault\.platformio\penv\lib\site-packages\platformio\commands\__init__.py", line 44, in invoke
return super(PlatformioCLI, self).invoke(ctx)
File "c:\users\fault\.platformio\penv\lib\site-packages\click\core.py", line 1659, in invoke
File "c:\users\fault\.platformio\penv\lib\site-packages\click\core.py", line 1395, in invoke
File "c:\users\fault\.platformio\penv\lib\site-packages\click\core.py", line 754, in invoke
File "c:\users\fault\.platformio\penv\lib\site-packages\click\decorators.py", line 26, in new_func
File "c:\users\fault\.platformio\penv\lib\site-packages\platformio\commands\project.py", line 194, in project_init
ProjectGenerator(config, environment, ide, board).generate()
File "c:\users\fault\.platformio\penv\lib\site-packages\platformio\project\generator.py", line 147, in generate
tpl_vars = self._load_tplvars()
File "c:\users\fault\.platformio\penv\lib\site-packages\platformio\project\generator.py", line 96, in _load_tplvars
tpl_vars.update(load_project_ide_data(self.project_dir, self.env_name) or {})
File "c:\users\fault\.platformio\penv\lib\site-packages\platformio\project\helpers.py", line 124, in load_project_ide_data
result.update(_load_project_ide_data(project_dir, missed_env_names))
File "c:\users\fault\.platformio\penv\lib\site-packages\platformio\project\helpers.py", line 142, in _load_project_ide_data
raise result.exception
File "c:\users\fault\.platformio\penv\lib\site-packages\click\testing.py", line 408, in invoke
return_value = cli.main(args=args or (), prog_name=prog_name, **extra)
File "c:\users\fault\.platformio\penv\lib\site-packages\platformio\commands\run\command.py", line 134, in cli
process_env(
File "c:\users\fault\.platformio\penv\lib\site-packages\platformio\commands\run\command.py", line 176, in process_env
result = {"env": name, "duration": time(), "succeeded": ep.process()}
File "c:\users\fault\.platformio\penv\lib\site-packages\platformio\commands\run\processor.py", line 67, in process
result = init_platform(self.options["platform"]).run(
File "c:\users\fault\.platformio\penv\lib\site-packages\platformio\platform\_run.py", line 59, in run
self.configure_default_packages(options, targets)
File "C:\Users\fault\.platformio\platforms\atmelavr\platform.py", line 39, in configure_default_packages
self.packages[framework_package]["optional"] = False
KeyError: 'framework-arduino-avr-esp32'
`pip install -U platformio` command
https://docs.platformio.org/page/faq.html
