Dear team
I would like to know your opinion about how to program a single button to behave as a 4 way (meaning 4 different functions)
i have tried to do my homework before writing here, so i found a library with some kind of solution (FWB.h - Pastebin.com) The coder have a single button with a single and double press pless, press and hold, and long press and hold behavior.
I would like to add a second botton and i want to remove the long press behavior for a simoltaneus (a+b) button to make a new function
can you tell me how to add the new button and also the (a+b) activity?
Thanks
// jb_exe
// Class from the code of JEFF'S ARDUINO BLOG
// http://jmsarduino.blogspot.com/2009/10/4-way-button-click-double-click-hold.html
// How to use me :
// "FWB_Project.pde"
// #include "FWB.h"
// #define BP 0 //the pin where your button is connected
// FWB bp;
// void OnClick(int pin)
// //Your code here
// void setup()
// bpUP.Configure(BP);
// bpUP.OnClick = OnClick;
// void loop()
// // Test button state
// bp.CheckBP();
#include "arduino.h"
#define PULL_UP 1
#define PULL_DOWN 0
class FWB
private:
int _pin;
boolean _pullMode;
// Properties //
// Debounce period to prevent flickering when pressing or releasing the button (in ms)
int Debounce;
// Max period between clicks for a double click event (in ms)
int DblClickDelay;
// Hold period for a long press event (in ms)
int LongPressDelay;
// Hold period for a very long press event (in ms)
int VLongPressDelay;
// Variables //
// Value read from button
boolean _state;
// Last value of button state
boolean _lastState;
// whether we're waiting for a double click (down)
boolean _dblClickWaiting;
// whether to register a double click on next release, or whether to wait and click
boolean _dblClickOnNextUp;
// whether it's OK to do a single click
boolean _singleClickOK;
// time the button was pressed down
long _downTime;
// time the button was released
long _upTime;
// whether to ignore the button release because the click+hold was triggered
boolean _ignoreUP;
// when held, whether to wait for the up event
boolean _waitForUP;
// whether or not the hold event happened already
boolean _longPressHappened;
// whether or not the long hold event happened already
boolean _vLongPressHappened;
public:
void (*OnClick)(int pin);
void (*OnDblClick)(int pin);
void (*OnLongPress)(int pin);
void (*OnVLongPress)(int pin);
FWB()
// Initialization of properties
Debounce = 20;
DblClickDelay = 250;
LongPressDelay = 1000;
VLongPressDelay = 3000;
// Initialization of variables
_state = true;
_lastState = true;
_dblClickWaiting = false;
_dblClickOnNextUp = false;
_singleClickOK = false; //Default = true
_downTime = -1;
_upTime = -1;
_ignoreUP = false;
_waitForUP = false;
_longPressHappened = false;
_vLongPressHappened = false;
void Configure(int pin, int pullMode = PULL_DOWN)
_pin = pin;
_pullMode = pullMode;
pinMode(_pin, INPUT);
void CheckBP(void)
int resultEvent = 0;
long millisRes = millis();
_state = digitalRead(_pin) == HIGH;
// Button pressed down
if (_state != _pullMode && _lastState == _pullMode && (millisRes - _upTime) > Debounce)
_downTime = millisRes;
_ignoreUP = false;
_waitForUP = false;
_singleClickOK = true;
if ((millisRes - _upTime) < DblClickDelay && _dblClickOnNextUp == false && _dblClickWaiting == true)
_dblClickOnNextUp = true;
else
// Button released
else if (_state == _pullMode && _lastState != _pullMode && (millisRes - _downTime) > Debounce)
if (_ignoreUP == false) //Replace "(!_ignoreUP)" by "(not _ignoreUP)"
_upTime = millisRes;
if (_dblClickOnNextUp == false) _dblClickWaiting = true;
else
resultEvent = 2;
// Test for normal click event: DblClickDelay expired
if (_state == _pullMode && (millisRes - _upTime) >= DblClickDelay && _dblClickWaiting == true && _dblClickOnNextUp == false && _singleClickOK == true && resultEvent != 2)
resultEvent = 1;
// Test for hold
if (_state != _pullMode && (millisRes - _downTime) >= LongPressDelay)
// Trigger "normal" hold
if (_longPressHappened == false)
resultEvent = 3;
_waitForUP = true;
_ignoreUP = true;
//_downTime = millis();
_longPressHappened = true;
// Trigger "long" hold
if ((millisRes - _downTime) >= VLongPressDelay)
if (_vLongPressHappened == false)
resultEvent = 4;
_vLongPressHappened = true;
_lastState = _state;
if (resultEvent == 1 && OnClick) OnClick(_pin);
if (resultEvent == 2 && OnDblClick) OnDblClick(_pin);
if (resultEvent == 3 && OnLongPress) OnLongPress(_pin);
if (resultEvent == 4 && OnVLongPress) OnVLongPress(_pin);
// if (resultEvent != 0)
// Usb.println(resultEvent);
