I am using PlatformIO IDE on Linux for the ESP210 board. It works just great but you have to explicitly set --dtr and --rts options to 0 in order to get the serial monitor working. These are not currently available in the advanced settings.
I was able to add these options by adding
<div class="form-group">
<label>DTR</label>
<select class="form-control monitor-option" data-monitor-option="dtr">
<option value="0" selected>off</option>
<option value="1">on</option>
</select>
</div>
<label>RTS</label>
<select class="form-control monitor-option" data-monitor-option="rts">
</select>
</div>
to the advanced-settings div element in my ~/.atom/packages/platformio-ide/lib/serial-monitor/template.html file.
It would be nice if these options could get into the PlatformIO IDE.
I am not sure what the default options are supposed to be in order not to break communication using the other boards/OSs though.
Thanks / Mikael
