Need help with custom samd21e18a board and usb upload
So I made this custom samd21e18 board that has an external crystal and I flashed the arduino zero bootloader via arduino ide and jlink edu mini. It worked great in arduino ide 1.0 and I was able to upload code and use the serial monitor! The issue comes with intergrating the project into platformio. I wasnt sure what the platformio.ini file should look like and what other changes I have to make and I wasnt able to use the board with it. I would really like to use platformio as I have used it with other boards and all my existing code is in there. As for it working on Arduino IDE, I used the Rapid Prototypes TAU arduino board to upload code as the pin descriptions are similar even though that board uses the samd21e17a. Also I was able to upload code using the jlink in platformio.
this is my .ini file:`; PlatformIO Project Configuration File
; Redirecting...
[env:custom_atsamd21e17a]
platform = atmelsam
board = custom_atsamd21e17a
board_build.variants_dir = custom_arduino_variant
upload_protocol = sam-ba
In general, how do I setup a new custom board in platformio?
