I’m trying to build an ESP32-S3 code. I need to use Arduino as ESP-IDF component in PlatformIO because I need to set some TCP LWIP params. I’m struggling with errors during building the code:
Processing esp32s3 (board: ESP32-S3-DevKitC-1-N16R8; framework: arduino, espidf; platform: https://github.com/pioarduino/platform-espressif32.git#develop)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/ESP32-S3-DevKitC-1-N16R8.html
PLATFORM: Espressif 32 (54.3.20+develop.sha.f17b2d1) > Espressif ESP32-S3-DevKitC-1-N16R8V (16 MB QD, 8MB PSRAM)
HARDWARE: ESP32S3 240MHz, 320KB RAM, 16MB Flash
DEBUG: Current (esp-builtin) On-board (esp-builtin) External (cmsis-dap, esp-bridge, esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
- framework-arduinoespressif32 @ 3.2.0
- framework-arduinoespressif32-libs @ 5.4.0+sha.f0f2980d05
- framework-espidf @ 3.50401.0 (5.4.1)
- tool-cmake @ 3.30.2
- tool-esp-rom-elfs @ 2024.10.11
- tool-esptoolpy @ 5.0.0
- tool-mklittlefs @ 3.2.0
- tool-ninja @ 1.10.2
- tool-scons @ 4.40801.0 (4.8.1)
- toolchain-xtensa-esp-elf @ 14.2.0+20241119
*** "custom_component" is used to (de)select managed idf components ***
Warning! Arduino framework as an ESP-IDF component doesn't handle the `variant` field! The default `esp32` variant will be used.
-- Found Git: C:/Program Files/Git/cmd/git.exe (found version "2.50.0.windows.1")
-- git rev-parse returned 'fatal: not a git repository (or any of the parent directories): .git'
-- The C compiler identification is GNU 14.2.0
-- The CXX compiler identification is GNU 14.2.0
-- The ASM compiler identification is GNU
-- Found assembler: C:/Users/Czarek/.platformio/packages/toolchain-xtensa-esp-elf/bin/xtensa-esp32s3-elf-gcc.exe
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: C:/Users/Czarek/.platformio/packages/toolchain-xtensa-esp-elf/bin/xtensa-esp32s3-elf-gcc.exe - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: C:/Users/Czarek/.platformio/packages/toolchain-xtensa-esp-elf/bin/xtensa-esp32s3-elf-g++.exe - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Could not use 'git describe' to determine PROJECT_VER.
-- Building ESP-IDF components for target esp32s3
Processing 11 dependencies:
[1/11] chmorgan/esp-libhelix-mp3 (1.0.3)
[2/11] espressif/cbor (0.6.0~1)
[3/11] espressif/esp-dsp (1.4.12)
[4/11] espressif/esp-sr (1.9.5)
[5/11] espressif/esp-zboss-lib (1.6.3)
[6/11] espressif/esp-zigbee-lib (1.6.3)
[7/11] espressif/esp_modem (1.4.0)
[8/11] espressif/mdns (1.8.2)
[9/11] espressif/network_provisioning (1.0.2)
[10/11] joltwallet/littlefs (1.20.0)
[11/11] idf (5.4.1)
-- Project sdkconfig file C:/Users/Czarek/Documents/PlatformIO/Projects/RadioTEST/sdkconfig.esp32s3
-- Configuring incomplete, errors occurred!
File "<frozen runpy>", line 198, in _run_module_as_main
File "<frozen runpy>", line 88, in _run_code
File "C:\Users\Czarek\.platformio\penv\.espidf-5.4.1\Lib\site-packages\kconfgen\__main__.py", line 5, in <module>
from .core import main
File "C:\Users\Czarek\.platformio\penv\.espidf-5.4.1\Lib\site-packages\kconfgen\core.py", line 29, in <module>
import esp_idf_kconfig.gen_kconfig_doc as gen_kconfig_doc
File "C:\Users\Czarek\.platformio\penv\.espidf-5.4.1\Lib\site-packages\esp_idf_kconfig\gen_kconfig_doc.py", line 14, in <module>
import kconfiglib.core as kconfiglib
File "C:\Users\Czarek\.platformio\penv\.espidf-5.4.1\Lib\site-packages\kconfiglib\__init__.py", line 3, in <module>
from .core import Kconfig # noqa F401
File "C:\Users\Czarek\.platformio\penv\.espidf-5.4.1\Lib\site-packages\kconfiglib\core.py", line 27, in <module>
from kconfiglib.report import PRAGMA_PREFIX
File "C:\Users\Czarek\.platformio\penv\.espidf-5.4.1\Lib\site-packages\kconfiglib\report.py", line 29, in <module>
from rich import print as rprint
ModuleNotFoundError: No module named 'rich'
CMake Error at C:/Users/Czarek/.platformio/packages/framework-espidf/tools/cmake/kconfig.cmake:209 (message):
Failed to run kconfgen
(C:/Users/Czarek/.platformio/penv/.espidf-5.4.1/Scripts/python.exe;-m;kconfgen;--list-separator=semicolon;--kconfig;C:/Users/Czarek/.platformio/packages/framework-espidf/Kconfig;--sdkconfig-rename;C:/Users/Czarek/.platformio/packages/framework-espidf/sdkconfig.rename;--config;C:/Users/Czarek/Documents/PlatformIO/Projects/RadioTEST/sdkconfig.esp32s3;--env-file;C:/Users/Czarek/Documents/PlatformIO/Projects/RadioTEST/.pio/build/esp32s3/config.env).
Error 1
C:/Users/Czarek/.platformio/packages/framework-espidf/tools/cmake/build.cmake:691 (__kconfig_generate_config)
C:/Users/Czarek/.platformio/packages/framework-espidf/tools/cmake/project.cmake:718 (idf_build_process)
CMakeLists.txt:3 (project)
======================================================================================= [FAILED] Took 7.13 seconds =======================================================================================
Environment Status Duration
esp32s3 FAILED 00:00:07.135
================================================================================== 1 failed, 0 succeeded in 00:00:07.135 ==================================================================================
* The terminal process "C:\Users\Czarek\.platformio\penv\Scripts\platformio.exe 'run', '--environment', 'esp32s3'" terminated with exit code: 1.
My platformio.ini looks like:
[esp32s3]
board_build.partitions = boards/default_16MB.csv ; 16MB Flash
board = ESP32-S3-DevKitC-1-N16R8 ; 16 MB Flash, 8MB octo PSRAM
[env]
platform = https://github.com/pioarduino/platform-espressif32.git#develop
build_flags = ${common.build_flags}
monitor_speed = ${common.monitor_speed}
upload_speed = 921600
custom_component_remove = espressif/esp_hosted
espressif/esp_wifi_remote
espressif/esp-dsp
espressif/esp32-camera
espressif/libsodium
espressif/esp-modbus
espressif/qrcode
espressif/esp_insights
espressif/esp_diag_data_store
espressif/esp_diagnostics
espressif/esp_rainmaker
espressif/rmaker_common
https://github.com/schreibfaul1/ESP32-audioI2S.git
adafruit/Adafruit GFX Library
adafruit/Adafruit ILI9341
https://github.com/tzapu/WiFiManager
ESP32Async/AsyncTCP
ESP32Async/ESpAsyncWebServer
[env:esp32s3]
board = ${esp32s3.board}
board_build.partitions = ${esp32s3.board_build.partitions}
framework = arduino, espidf
I tried almost everything - deleting .platformio folder, reinstaling PlatformIO and VSCode - no success.
Could someone experienced help me to overcome this issue, please?
