Hi all,
I’m fairly new to PlatformIO and want to create a piece of code which also uses the great WifiManager functionalities from GitHub - khoih-prog/ESPAsync_WiFiManager: This is an ESP32 (including ESP32-S2 and ESP32-C3) / ESP8266 WiFi Connection Manager, using ESPAsyncWebServer, with fallback web configuration portal. Use this library for configuring ESP32, ESP8266 modules' WiFi, etc. Credentials at runtime. You can also specify static DNS servers, personalized HostName, fixed or random AP WiFi channel. With examples supporting ArduinoJson 6.0.0+ as well as 5.13.5- . Using AsyncDNSServer instead of DNSServer now. .
But, to keep things a bit clearer, i’d like to do as much as possible of this WiFi setup in a separate file, so that my main.cpp including the loop void and the setup void can remain as empty as possible, to use it for the actual other functionalities of my program.
Unfortunately i’m not in the power of how to achieve this at all, is anyone able to help me out on how to achieve this?
My current (working) main.cpp looks like this:
Async_ConfigOnDoubleReset.ino
This example will open a configuration portal when the reset button is pressed twice.
This method works well on Wemos boards which have a single reset button on board. It avoids using a pin for launching the configuration portal.
How It Works
1) ESP8266
Save data in RTC memory
2) ESP32
Save data in EEPROM from address 256, size 512 bytes (both configurable)
So when the device starts up it checks this region of ram for a flag to see if it has been recently reset.
If so it launches a configuration portal, if not it sets the reset flag. After running for a while this flag is cleared so that
it will only launch the configuration portal in response to closely spaced resets.
Settings
There are two values to be set in the sketch.
DRD_TIMEOUT - Number of seconds to wait for the second reset. Set to 10 in the example.
DRD_ADDRESS - The address in ESP8266 RTC RAM to store the flag. This memory must not be used for other purposes in the same sketch. Set to 0 in the example.
This example, originally relied on the Double Reset Detector library from https://github.com/datacute/DoubleResetDetector
To support ESP32, use ESP_DoubleResetDetector library from //https://github.com/khoih-prog/ESP_DoubleResetDetector
#if !( defined(ESP8266) || defined(ESP32) )
#error This code is intended to run on the ESP8266 or ESP32 platform! Please check your Tools->Board setting.
#define ESP_ASYNC_WIFIMANAGER_VERSION_MIN_TARGET "ESPAsync_WiFiManager v1.15.0"
#define ESP_ASYNC_WIFIMANAGER_VERSION_MIN 1015000
// Use from 0 to 4. Higher number, more debugging messages and memory usage.
#define _ESPASYNC_WIFIMGR_LOGLEVEL_ 3
// To not display stored SSIDs and PWDs on Config Portal, select false. Default is true
// Even the stored Credentials are not display, just leave them all blank to reconnect and reuse the stored Credentials
//#define DISPLAY_STORED_CREDENTIALS_IN_CP false
#include <FS.h>
//Ported to ESP32
#ifdef ESP32
#include <esp_wifi.h>
#include <WiFi.h>
#include <WiFiClient.h>
// From v1.1.1
#include <WiFiMulti.h>
WiFiMulti wifiMulti;
// LittleFS has higher priority than SPIFFS
#if ( defined(ESP_ARDUINO_VERSION_MAJOR) && (ESP_ARDUINO_VERSION_MAJOR >= 2) )
#define USE_LITTLEFS true
#define USE_SPIFFS false
#elif defined(ARDUINO_ESP32C3_DEV)
// For core v1.0.6-, ESP32-C3 only supporting SPIFFS and EEPROM. To use v2.0.0+ for LittleFS
#define USE_LITTLEFS false
#define USE_SPIFFS true
#if USE_LITTLEFS
// Use LittleFS
#include "FS.h"
// Check cores/esp32/esp_arduino_version.h and cores/esp32/core_version.h
//#if ( ESP_ARDUINO_VERSION >= ESP_ARDUINO_VERSION_VAL(2, 0, 0) ) //(ESP_ARDUINO_VERSION_MAJOR >= 2)
#if (_ESPASYNC_WIFIMGR_LOGLEVEL_ > 3)
#warning Using ESP32 Core 1.0.6 or 2.0.0+
// The library has been merged into esp32 core from release 1.0.6
#include <LittleFS.h> // https://github.com/espressif/arduino-esp32/tree/master/libraries/LittleFS
FS* filesystem = &LittleFS;
#define FileFS LittleFS
#define FS_Name "LittleFS"
#else
#warning Using ESP32 Core 1.0.5-. You must install LITTLEFS library
#include <LITTLEFS.h> // https://github.com/lorol/LITTLEFS
FS* filesystem = &LITTLEFS;
#define FileFS LITTLEFS
#elif USE_SPIFFS
#include <SPIFFS.h>
FS* filesystem = &SPIFFS;
#define FileFS SPIFFS
#define FS_Name "SPIFFS"
#else
// +Use FFat
#include <FFat.h>
FS* filesystem = &FFat;
#define FileFS FFat
#define FS_Name "FFat"
#define LED_BUILTIN 2
#define LED_ON HIGH
#define LED_OFF LOW
#else
#include <ESP8266WiFi.h> //https://github.com/esp8266/Arduino
//needed for library
#include <ESPAsyncDNSServer.h>
// From v1.1.1
#include <ESP8266WiFiMulti.h>
ESP8266WiFiMulti wifiMulti;
#if USE_LITTLEFS
#else
#define ESP_getChipId() (ESP.getChipId())
#define LED_ON LOW
#define LED_OFF HIGH
// These defines must be put before #include <ESP_DoubleResetDetector.h>
// to select where to store DoubleResetDetector's variable.
// For ESP32, You must select one to be true (EEPROM or SPIFFS)
// For ESP8266, You must select one to be true (RTC, EEPROM, SPIFFS or LITTLEFS)
// Otherwise, library will use default EEPROM storage
#ifdef ESP32
#if USE_LITTLEFS
#define ESP_DRD_USE_LITTLEFS true
#define ESP_DRD_USE_SPIFFS false
#define ESP_DRD_USE_EEPROM false
#elif USE_SPIFFS
#define ESP_DRD_USE_LITTLEFS false
#define ESP_DRD_USE_SPIFFS true
#else
#define ESP_DRD_USE_EEPROM true
#else //ESP8266
// For DRD
#if USE_LITTLEFS
#else
#define ESP8266_DRD_USE_RTC false
#define DOUBLERESETDETECTOR_DEBUG true //false
#include <ESP_DoubleResetDetector.h> //https://github.com/khoih-prog/ESP_DoubleResetDetector
// Number of seconds after reset during which a
// subseqent reset will be considered a double reset.
#define DRD_TIMEOUT 10
// RTC Memory Address for the DoubleResetDetector to use
#define DRD_ADDRESS 0
//DoubleResetDetector drd(DRD_TIMEOUT, DRD_ADDRESS);
DoubleResetDetector* drd;//////
// Onboard LED I/O pin on NodeMCU board
const int PIN_LED = 2; // D4 on NodeMCU and WeMos. GPIO2/ADC12 of ESP32. Controls the onboard LED.
// From v1.1.1
// You only need to format the filesystem once
//#define FORMAT_FILESYSTEM true
#define FORMAT_FILESYSTEM false
#define MIN_AP_PASSWORD_SIZE 8
#define SSID_MAX_LEN 32
//From v1.0.10, WPA2 passwords can be up to 63 characters long.
#define PASS_MAX_LEN 64
typedef struct
char wifi_ssid[SSID_MAX_LEN];
char wifi_pw [PASS_MAX_LEN];
} WiFi_Credentials;
typedef struct
String wifi_ssid;
String wifi_pw;
} WiFi_Credentials_String;
#define NUM_WIFI_CREDENTIALS 2
// Assuming max 49 chars
#define TZNAME_MAX_LEN 50
#define TIMEZONE_MAX_LEN 50
typedef struct
WiFi_Credentials WiFi_Creds [NUM_WIFI_CREDENTIALS];
char TZ_Name[TZNAME_MAX_LEN]; // "America/Toronto"
char TZ[TIMEZONE_MAX_LEN]; // "EST5EDT,M3.2.0,M11.1.0"
uint16_t checksum;
} WM_Config;
WM_Config WM_config;
#define CONFIG_FILENAME F("/wifi_cred.dat")
// Indicates whether ESP has WiFi credentials saved from previous session, or double reset detected
bool initialConfig = false;
// Use false if you don't like to display Available Pages in Information Page of Config Portal
// Comment out or use true to display Available Pages in Information Page of Config Portal
// Must be placed before #include <ESPAsync_WiFiManager.h>
#define USE_AVAILABLE_PAGES true //false
// From v1.0.10 to permit disable/enable StaticIP configuration in Config Portal from sketch. Valid only if DHCP is used.
// You'll loose the feature of dynamically changing from DHCP to static IP, or vice versa
// You have to explicitly specify false to disable the feature.
//#define USE_STATIC_IP_CONFIG_IN_CP false
// Use false to disable NTP config. Advisable when using Cellphone, Tablet to access Config Portal.
// See Issue 23: On Android phone ConfigPortal is unresponsive (https://github.com/khoih-prog/ESP_WiFiManager/issues/23)
#define USE_ESP_WIFIMANAGER_NTP false
// Just use enough to save memory. On ESP8266, can cause blank ConfigPortal screen
// if using too much memory
#define USING_AFRICA false
#define USING_AMERICA true
#define USING_ANTARCTICA false
#define USING_ASIA false
#define USING_ATLANTIC false
#define USING_AUSTRALIA false
#define USING_EUROPE false
#define USING_INDIAN false
#define USING_PACIFIC false
#define USING_ETC_GMT false
// Use true to enable CloudFlare NTP service. System can hang if you don't have Internet access while accessing CloudFlare
// See Issue #21: CloudFlare link in the default portal (https://github.com/khoih-prog/ESP_WiFiManager/issues/21)
#define USE_CLOUDFLARE_NTP false
// New in v1.0.11
#define USING_CORS_FEATURE true
// Use USE_DHCP_IP == true for dynamic DHCP IP, false to use static IP which you have to change accordingly to your network
#if (defined(USE_STATIC_IP_CONFIG_IN_CP) && !USE_STATIC_IP_CONFIG_IN_CP)
// Force DHCP to be true
#if defined(USE_DHCP_IP)
#undef USE_DHCP_IP
#define USE_DHCP_IP true
#else
// You can select DHCP or Static IP here
//#define USE_DHCP_IP false
#if ( USE_DHCP_IP )
// Use DHCP
#warning Using DHCP IP
IPAddress stationIP = IPAddress(0, 0, 0, 0);
IPAddress gatewayIP = IPAddress(192, 168, 2, 1);
IPAddress netMask = IPAddress(255, 255, 255, 0);
#else
// Use static IP
#warning Using static IP
#ifdef ESP32
IPAddress stationIP = IPAddress(192, 168, 2, 232);
#else
IPAddress stationIP = IPAddress(192, 168, 2, 186);
#define USE_CONFIGURABLE_DNS true
IPAddress dns1IP = gatewayIP;
IPAddress dns2IP = IPAddress(8, 8, 8, 8);
#define USE_CUSTOM_AP_IP false
IPAddress APStaticIP = IPAddress(192, 168, 100, 1);
IPAddress APStaticGW = IPAddress(192, 168, 100, 1);
IPAddress APStaticSN = IPAddress(255, 255, 255, 0);
#include <ESPAsync_WiFiManager.h> //https://github.com/khoih-prog/ESPAsync_WiFiManager
// Redundant, for v1.10.0 only
//#include <ESPAsync_WiFiManager-Impl.h> //https://github.com/khoih-prog/ESPAsync_WiFiManager
// SSID and PW for Config Portal
// String ssid = "ESP_" + String(ESP_getChipId(), HEX);
String ssid = "AudioContr FallBack_ESP_" + String(ESP_getChipId(), HEX);
String password= "4454";
// AP_SSID = "AudioController FallBack_AP_ ESP_" + chipID;
// AP_PASS = "4454";
//const char* password = "your_password";
// SSID and PW for your Router
String Router_SSID;
String Router_Pass;
#define HTTP_PORT 80
// New in v1.4.0
// Defined in ESPAsync_WiFiManager.h
typedef struct
IPAddress _ap_static_ip;
IPAddress _ap_static_gw;
IPAddress _ap_static_sn;
} WiFi_AP_IPConfig;
typedef struct
IPAddress _sta_static_ip;
IPAddress _sta_static_gw;
IPAddress _sta_static_sn;
#if USE_CONFIGURABLE_DNS
IPAddress _sta_static_dns1;
IPAddress _sta_static_dns2;
//WiFi_STA_IPConfig;
WiFi_AP_IPConfig WM_AP_IPconfig;
WiFi_STA_IPConfig WM_STA_IPconfig;
void initAPIPConfigStruct(WiFi_AP_IPConfig &in_WM_AP_IPconfig)
in_WM_AP_IPconfig._ap_static_ip = APStaticIP;
in_WM_AP_IPconfig._ap_static_gw = APStaticGW;
in_WM_AP_IPconfig._ap_static_sn = APStaticSN;
void initSTAIPConfigStruct(WiFi_STA_IPConfig &in_WM_STA_IPconfig)
in_WM_STA_IPconfig._sta_static_ip = stationIP;
in_WM_STA_IPconfig._sta_static_gw = gatewayIP;
in_WM_STA_IPconfig._sta_static_sn = netMask;
in_WM_STA_IPconfig._sta_static_dns1 = dns1IP;
in_WM_STA_IPconfig._sta_static_dns2 = dns2IP;
void displayIPConfigStruct(WiFi_STA_IPConfig in_WM_STA_IPconfig)
LOGERROR3(F("stationIP ="), in_WM_STA_IPconfig._sta_static_ip, ", gatewayIP =", in_WM_STA_IPconfig._sta_static_gw);
LOGERROR1(F("netMask ="), in_WM_STA_IPconfig._sta_static_sn);
LOGERROR3(F("dns1IP ="), in_WM_STA_IPconfig._sta_static_dns1, ", dns2IP =", in_WM_STA_IPconfig._sta_static_dns2);
void configWiFi(WiFi_STA_IPConfig in_WM_STA_IPconfig)
// Set static IP, Gateway, Subnetmask, DNS1 and DNS2. New in v1.0.5
WiFi.config(in_WM_STA_IPconfig._sta_static_ip, in_WM_STA_IPconfig._sta_static_gw, in_WM_STA_IPconfig._sta_static_sn, in_WM_STA_IPconfig._sta_static_dns1, in_WM_STA_IPconfig._sta_static_dns2);
#else
// Set static IP, Gateway, Subnetmask, Use auto DNS1 and DNS2.
WiFi.config(in_WM_STA_IPconfig._sta_static_ip, in_WM_STA_IPconfig._sta_static_gw, in_WM_STA_IPconfig._sta_static_sn);
uint8_t connectMultiWiFi()
#if ESP32
// For ESP32, this better be 0 to shorten the connect time.
// For ESP32-S2/C3, must be > 500
#if ( USING_ESP32_S2 || USING_ESP32_C3 )
#define WIFI_MULTI_1ST_CONNECT_WAITING_MS 500L
#else
// For ESP32 core v1.0.6, must be >= 500
#define WIFI_MULTI_1ST_CONNECT_WAITING_MS 800L
#else
// For ESP8266, this better be 2200 to enable connect the 1st time
#define WIFI_MULTI_1ST_CONNECT_WAITING_MS 2200L
#define WIFI_MULTI_CONNECT_WAITING_MS 500L
uint8_t status;
//WiFi.mode(WIFI_STA);
LOGERROR(F("ConnectMultiWiFi with :"));
if ( (Router_SSID != "") && (Router_Pass != "") )
LOGERROR3(F("* Flash-stored Router_SSID = "), Router_SSID, F(", Router_Pass = "), Router_Pass );
LOGERROR3(F("* Add SSID = "), Router_SSID, F(", PW = "), Router_Pass );
wifiMulti.addAP(Router_SSID.c_str(), Router_Pass.c_str());
for (uint8_t i = 0; i < NUM_WIFI_CREDENTIALS; i++)
// Don't permit NULL SSID and password len < MIN_AP_PASSWORD_SIZE (8)
if ( (String(WM_config.WiFi_Creds[i].wifi_ssid) != "") && (strlen(WM_config.WiFi_Creds[i].wifi_pw) >= MIN_AP_PASSWORD_SIZE) )
LOGERROR3(F("* Additional SSID = "), WM_config.WiFi_Creds[i].wifi_ssid, F(", PW = "), WM_config.WiFi_Creds[i].wifi_pw );
LOGERROR(F("Connecting MultiWifi..."));
#if !USE_DHCP_IP
// New in v1.4.0
configWiFi(WM_STA_IPconfig);
int i = 0;
status = wifiMulti.run();
delay(WIFI_MULTI_1ST_CONNECT_WAITING_MS);
while ( ( i++ < 20 ) && ( status != WL_CONNECTED ) )
status = WiFi.status();
if ( status == WL_CONNECTED )
break;
else
delay(WIFI_MULTI_CONNECT_WAITING_MS);
LOGERROR1(F("WiFi connected after time: "), i);
LOGERROR3(F("SSID:"), WiFi.SSID(), F(",RSSI="), WiFi.RSSI());
LOGERROR3(F("Channel:"), WiFi.channel(), F(",IP address:"), WiFi.localIP() );
else
LOGERROR(F("WiFi not connected"));
// To avoid unnecessary DRD
drd->loop();
#if ESP8266
ESP.reset();
#else
ESP.restart();
return status;
#if USE_ESP_WIFIMANAGER_NTP
void printLocalTime()
#if ESP8266
static time_t now;
now = time(nullptr);
if ( now > 1451602800 )
Serial.print("Local Date/Time: ");
Serial.print(ctime(&now));
#else
struct tm timeinfo;
getLocalTime( &timeinfo );
// Valid only if year > 2000.
// You can get from timeinfo : tm_year, tm_mon, tm_mday, tm_hour, tm_min, tm_sec
if (timeinfo.tm_year > 100 )
Serial.print( asctime( &timeinfo ) );
void heartBeatPrint()
printLocalTime();
#else
static int num = 1;
if (WiFi.status() == WL_CONNECTED)
Serial.print(F("H")); // H means connected to WiFi
else
Serial.print(F("F")); // F means not connected to WiFi
if (num == 80)
Serial.println();
num = 1;
else if (num++ % 10 == 0)
Serial.print(F(" "));
void check_WiFi()
if ( (WiFi.status() != WL_CONNECTED) )
Serial.println(F("\nWiFi lost. Call connectMultiWiFi in loop"));
connectMultiWiFi();
void check_status()
static ulong checkstatus_timeout = 0;
static ulong checkwifi_timeout = 0;
static ulong current_millis;
#define WIFICHECK_INTERVAL 1000L
#define HEARTBEAT_INTERVAL 60000L
#else
#define HEARTBEAT_INTERVAL 10000L
current_millis = millis();
// Check WiFi every WIFICHECK_INTERVAL (1) seconds.
if ((current_millis > checkwifi_timeout) || (checkwifi_timeout == 0))
check_WiFi();
checkwifi_timeout = current_millis + WIFICHECK_INTERVAL;
// Print hearbeat every HEARTBEAT_INTERVAL (10) seconds.
if ((current_millis > checkstatus_timeout) || (checkstatus_timeout == 0))
heartBeatPrint();
checkstatus_timeout = current_millis + HEARTBEAT_INTERVAL;
int calcChecksum(uint8_t* address, uint16_t sizeToCalc)
uint16_t checkSum = 0;
for (uint16_t index = 0; index < sizeToCalc; index++)
checkSum += * ( ( (byte*) address ) + index);
return checkSum;
bool loadConfigData()
File file = FileFS.open(CONFIG_FILENAME, "r");
LOGERROR(F("LoadWiFiCfgFile "));
memset((void *) &WM_config, 0, sizeof(WM_config));
// New in v1.4.0
memset((void *) &WM_STA_IPconfig, 0, sizeof(WM_STA_IPconfig));
if (file)
file.readBytes((char *) &WM_config, sizeof(WM_config));
// New in v1.4.0
file.readBytes((char *) &WM_STA_IPconfig, sizeof(WM_STA_IPconfig));
file.close();
LOGERROR(F("OK"));
if ( WM_config.checksum != calcChecksum( (uint8_t*) &WM_config, sizeof(WM_config) - sizeof(WM_config.checksum) ) )
LOGERROR(F("WM_config checksum wrong"));
return false;
// New in v1.4.0
displayIPConfigStruct(WM_STA_IPconfig);
return true;
else
LOGERROR(F("failed"));
return false;
void saveConfigData()
File file = FileFS.open(CONFIG_FILENAME, "w");
LOGERROR(F("SaveWiFiCfgFile "));
if (file)
WM_config.checksum = calcChecksum( (uint8_t*) &WM_config, sizeof(WM_config) - sizeof(WM_config.checksum) );
file.write((uint8_t*) &WM_config, sizeof(WM_config));
// New in v1.4.0
file.write((uint8_t*) &WM_STA_IPconfig, sizeof(WM_STA_IPconfig));
file.close();
LOGERROR(F("OK"));
else
// #include "wifisetup.h"
void setup()
// initialize the LED digital pin as an output.
pinMode(PIN_LED, OUTPUT);
while (!Serial);
delay(200);
Serial.print(F("\nStarting Async_ConfigOnDoubleReset using ")); Serial.print(FS_Name);
Serial.print(F(" on ")); Serial.println(ARDUINO_BOARD);
Serial.println(ESP_ASYNC_WIFIMANAGER_VERSION);
Serial.println(ESP_DOUBLE_RESET_DETECTOR_VERSION);
#if defined(ESP_ASYNC_WIFIMANAGER_VERSION_INT)
if (ESP_ASYNC_WIFIMANAGER_VERSION_INT < ESP_ASYNC_WIFIMANAGER_VERSION_MIN)
Serial.print("Warning. Must use this example on Version later than : ");
Serial.println(ESP_ASYNC_WIFIMANAGER_VERSION_MIN_TARGET);
Serial.setDebugOutput(false);
if (FORMAT_FILESYSTEM)
FileFS.format();
// Format FileFS if not yet
#ifdef ESP32
if (!FileFS.begin(true))
#else
if (!FileFS.begin())
#ifdef ESP8266
FileFS.format();
Serial.println(F("SPIFFS/LittleFS failed! Already tried formatting."));
// prevents debug info from the library to hide err message.
delay(100);
#if USE_LITTLEFS
Serial.println(F("LittleFS failed!. Please use SPIFFS or EEPROM. Stay forever"));
#else
Serial.println(F("SPIFFS failed!. Please use LittleFS or EEPROM. Stay forever"));
while (true)
delay(1);
drd = new DoubleResetDetector(DRD_TIMEOUT, DRD_ADDRESS);
unsigned long startedAt = millis();
// New in v1.4.0
initAPIPConfigStruct(WM_AP_IPconfig);
initSTAIPConfigStruct(WM_STA_IPconfig);
//Local intialization. Once its business is done, there is no need to keep it around
// Use this to default DHCP hostname to ESP8266-XXXXXX or ESP32-XXXXXX
//ESPAsync_WiFiManager ESPAsync_wifiManager(&webServer, &dnsServer);
// Use this to personalize DHCP hostname (RFC952 conformed)
AsyncWebServer webServer(HTTP_PORT);
ESPAsync_WiFiManager ESPAsync_wifiManager(&webServer, NULL, "AsyncConfigOnDoubleReset");
#else
AsyncDNSServer dnsServer;
ESPAsync_WiFiManager ESPAsync_wifiManager(&webServer, &dnsServer, "AsyncConfigOnDoubleReset");
#if USE_CUSTOM_AP_IP
//set custom ip for portal
// New in v1.4.0
ESPAsync_wifiManager.setAPStaticIPConfig(WM_AP_IPconfig);
ESPAsync_wifiManager.setMinimumSignalQuality(-1);
// From v1.0.10 only
// Set config portal channel, default = 1. Use 0 => random channel from 1-11
ESPAsync_wifiManager.setConfigPortalChannel(0);
#if !USE_DHCP_IP
// Set (static IP, Gateway, Subnetmask, DNS1 and DNS2) or (IP, Gateway, Subnetmask). New in v1.0.5
// New in v1.4.0
ESPAsync_wifiManager.setSTAStaticIPConfig(WM_STA_IPconfig);
// New from v1.1.1
#if USING_CORS_FEATURE
ESPAsync_wifiManager.setCORSHeader("Your Access-Control-Allow-Origin");
// We can't use WiFi.SSID() in ESP32 as it's only valid after connected.
// SSID and Password stored in ESP32 wifi_ap_record_t and wifi_config_t are also cleared in reboot
// Have to create a new function to store in EEPROM/SPIFFS for this purpose
Router_SSID = ESPAsync_wifiManager.WiFi_SSID();
Router_Pass = ESPAsync_wifiManager.WiFi_Pass();
//Remove this line if you do not want to see WiFi password printed
Serial.println("ESP Self-Stored: SSID = " + Router_SSID + ", Pass = " + Router_Pass);
// SSID to uppercase
// ssid.toUpperCase();
// password = "My" + ssid;
bool configDataLoaded = false;
// From v1.1.0, Don't permit NULL password
LOGERROR3(F("* Add SSID = "), Router_SSID, F(", PW = "), Router_Pass);
ESPAsync_wifiManager.setConfigPortalTimeout(120); //If no access point name has been previously entered disable timeout.
Serial.println(F("Got ESP Self-Stored Credentials. Timeout 120s for Config Portal"));
if (loadConfigData())
configDataLoaded = true;
Serial.println(F("Got stored Credentials. Timeout 120s for Config Portal"));
if ( strlen(WM_config.TZ_Name) > 0 )
LOGERROR3(F("Current TZ_Name ="), WM_config.TZ_Name, F(", TZ = "), WM_config.TZ);
#if ESP8266
configTime(WM_config.TZ, "pool.ntp.org");
#else
//configTzTime(WM_config.TZ, "pool.ntp.org" );
configTzTime(WM_config.TZ, "time.nist.gov", "0.pool.ntp.org", "1.pool.ntp.org");
else
Serial.println(F("Current Timezone is not set. Enter Config Portal to set."));
else
// Enter CP only if no stored SSID on flash and file
Serial.println(F("Open Config Portal without Timeout: No stored Credentials."));
initialConfig = true;
if (drd->detectDoubleReset())
// DRD, disable timeout.
ESPAsync_wifiManager.setConfigPortalTimeout(0);
Serial.println(F("Open Config Portal without Timeout: Double Reset Detected"));
if (initialConfig)
Serial.print(F("Starting configuration portal @ "));
Serial.print(APStaticIP);
#else
Serial.print(F("192.168.4.1"));
Serial.print(F(", SSID = "));
Serial.print(ssid);
Serial.print(F(", PWD = "));
Serial.println(password);
digitalWrite(PIN_LED, LED_ON); // turn the LED on by making the voltage LOW to tell us we are in configuration mode.
//sets timeout in seconds until configuration portal gets turned off.
//If not specified device will remain in configuration mode until
//switched off via webserver or device is restarted.
//ESPAsync_wifiManager.setConfigPortalTimeout(600);
#if DISPLAY_STORED_CREDENTIALS_IN_CP
// New. Update Credentials, got from loadConfigData(), to display on CP
ESPAsync_wifiManager.setCredentials(WM_config.WiFi_Creds[0].wifi_ssid, WM_config.WiFi_Creds[0].wifi_pw,
WM_config.WiFi_Creds[1].wifi_ssid, WM_config.WiFi_Creds[1].wifi_pw);
// Starts an access point
if (!ESPAsync_wifiManager.startConfigPortal((const char *) ssid.c_str(), password.c_str()))
Serial.println(F("Not connected to WiFi but continuing anyway."));
else
Serial.println(F("WiFi connected...yeey :)"));
// Stored for later usage, from v1.1.0, but clear first
memset(&WM_config, 0, sizeof(WM_config));
String tempSSID = ESPAsync_wifiManager.getSSID(i);
String tempPW = ESPAsync_wifiManager.getPW(i);
if (strlen(tempSSID.c_str()) < sizeof(WM_config.WiFi_Creds[i].wifi_ssid) - 1)
strcpy(WM_config.WiFi_Creds[i].wifi_ssid, tempSSID.c_str());
else
strncpy(WM_config.WiFi_Creds[i].wifi_ssid, tempSSID.c_str(), sizeof(WM_config.WiFi_Creds[i].wifi_ssid) - 1);
if (strlen(tempPW.c_str()) < sizeof(WM_config.WiFi_Creds[i].wifi_pw) - 1)
strcpy(WM_config.WiFi_Creds[i].wifi_pw, tempPW.c_str());
else
strncpy(WM_config.WiFi_Creds[i].wifi_pw, tempPW.c_str(), sizeof(WM_config.WiFi_Creds[i].wifi_pw) - 1);
LOGERROR3(F("* Add SSID = "), WM_config.WiFi_Creds[i].wifi_ssid, F(", PW = "), WM_config.WiFi_Creds[i].wifi_pw );
wifiMulti.addAP(WM_config.WiFi_Creds[i].wifi_ssid, WM_config.WiFi_Creds[i].wifi_pw);
String tempTZ = ESPAsync_wifiManager.getTimezoneName();
if (strlen(tempTZ.c_str()) < sizeof(WM_config.TZ_Name) - 1)
strcpy(WM_config.TZ_Name, tempTZ.c_str());
else
strncpy(WM_config.TZ_Name, tempTZ.c_str(), sizeof(WM_config.TZ_Name) - 1);
const char * TZ_Result = ESPAsync_wifiManager.getTZ(WM_config.TZ_Name);
if (strlen(TZ_Result) < sizeof(WM_config.TZ) - 1)
strcpy(WM_config.TZ, TZ_Result);
else
strncpy(WM_config.TZ, TZ_Result, sizeof(WM_config.TZ_Name) - 1);
LOGERROR3(F("Saving current TZ_Name ="), WM_config.TZ_Name, F(", TZ = "), WM_config.TZ);
#if ESP8266
#else
else
LOGERROR(F("Current Timezone Name is not set. Enter Config Portal to set."));
// New in v1.4.0
ESPAsync_wifiManager.getSTAStaticIPConfig(WM_STA_IPconfig);
saveConfigData();
digitalWrite(PIN_LED, LED_OFF); // Turn led off as we are not in configuration mode.
if (!initialConfig)
// Load stored data, the addAP ready for MultiWiFi reconnection
if (!configDataLoaded)
loadConfigData();
if ( WiFi.status() != WL_CONNECTED )
Serial.println(F("ConnectMultiWiFi in setup"));
connectMultiWiFi();
Serial.print(F("After waiting "));
Serial.print((float) (millis() - startedAt) / 1000);
Serial.print(F(" secs more in setup(), connection result is "));
Serial.print(F("connected. Local IP: "));
else
Serial.println(ESPAsync_wifiManager.getStatus(WiFi.status()));
void loop()
// Call the double reset detector loop method every so often,
// so that it can recognise when the timeout expires.
// You can also call drd.stop() when you wish to no longer
// consider the next reset as a double reset.
drd->loop();
// put your main code here, to run repeatedly
check_status();
Ideally it would look something along these lines:
void setup()
WifiSetup();
MyProgramSetupTask1();
void loop()
WifiCheck(); //Checks status and the double-reset behaviour
MyProgramTask1();
MyProgramTask2();
//etc.
