I simply do not get the debugging running…
did try with Lilygo T7-S3, with an ESP32-C3 with direkt connection, and also with an ESP-PROG in between. Simply no communicaton at debugging.
I did install the FTDI-drivers, i did use Zadeg to exchange the driver, i did reboot.
Error is always:
Info : tcl server disabled
Info : telnet server disabled
Error: libusb_open() failed with LIBUSB_ERROR_NOT_SUPPORTED
Info : clock speed 1000 kHz
Error: JTAG scan chain interrogation failed: all zeroes
Error: Check JTAG interface, timings, target power, etc.
Error: Trying to use configured scan chain anyway...
Error: esp32s3.cpu0: IR capture error; saw 0x00 not 0x01
Warn : Bypassing JTAG setup events due to errors
Error: Unexpected OCD_ID = 00000000
Warn : target esp32s3.cpu0 examination failed
Warn : target esp32s3.cpu1 examination failed
Info : starting gdb server for esp32s3.cpu0 on pipe
Error: Target not examined yet
Error executing event gdb-attach on target esp32s3.cpu0:
Warn : No symbols for FreeRTOS!
Error: Target not halted
Error: auto_probe failed
Error: Connect failed. Consider setting up a gdb-attach event for the target to prepare target for GDB connect, or use 'gdb_memory_map disable'.
Error: attempted 'gdb' connection rejected
Error: error during select: Unknown error
Remote communication error. Target disconnected.: Success.
Wondering what i am doing wrong here.
My platformio.ini for the ESP32-C3:
[env:esp32-c3-devkitm-1]
board = esp32-c3-devkitm-1
debug_tool = esp-builtin
upload_protocol = esp-builtin
debug_speed = 1000
build_type = debug
debug_build_flags = -O0 -g -ggdb
How to debug the debug ?
