I use both ESP32-C3 and ESP32-S2-SOLO chips.
With C3, using native USB (D+ & D- pins), I can:
1 - upload (flash apps)
2 - print with Serial.print and log_x
3 - debug apps
With S2-SOLO (chip ESP32-S2R2), I can:
Note: I use the ESP32-S2-SOLO module, not a devkit.
With S2-SOLO I cannot:
1 - print using log_x. No errors, but no output
2 - debug natively without using any device. I think it would be possible to do this with my esp-prog. But I don’t want to have to connect up to 6 pins, and many wires during dev periods.
So I have two questions if someone can help me for one of them, or both.
1 - how can I make log_x display output via USB?
2 - what conf can make debugging possible using USB, esp-builtin can’t be used?
Here’s my platformio.ini file.
[env]
board = esp32-s2-saola-1
upload_speed = 921600
-DCORE_DEBUG_LEVEL=3
-DARDUINO_USB_CDC_ON_BOOT=1
-DBOARD_HAS_PSRAM
-mfix-esp32-psram-cache-issue
[env:esp-solo]
build_src_filter = +<main.cpp>
# For debug
platform_packages = platformio/tool-openocd-esp32
;debug_tool = esp-prog
debug_init_break =
set remote hardware-watchpoint-limit 2
break base.cpp:16
debug_extra_cmds = break main.cpp:26
# For testing FRAM
[env:fram]
build_src_filter = +<fram.cpp>
In the minimal app I use:
#include <esp_log.h>
Serial.println... <= prints result
log_v... <= prints nothing
log_e... <= prints nothing
Thanks in advance for any help.
