CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/esp12e.htmlPLATFORM: Espressif 8266 (4.0.1) > Espressif ESP8266 ESP-12E
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
- framework-arduinoespressif8266 @ 3.30002.0 (3.0.2)
- tool-esptool @ 1.413.0 (4.13)
- tool-esptoolpy @ 1.30000.201119 (3.0.0)
- tool-mkspiffs @ 1.200.0 (2.0)
- toolchain-xtensa @ 2.100300.210717 (10.3.0)
Found 48 compatible libraries
Scanning dependencies…
|-- CmdParser @ 0.0.0+sha.dcaa7ea
|-- LittleFS @ 0.1.0
|-- ota
| |-- ArduinoOTA @ 1.0
| | |-- ESP8266WiFi @ 1.0
| | |-- ESP8266mDNS @ 1.2
|-- Wire @ 1.0
|-- i2cscan
| |-- Wire @ 1.0
|-- mpu6050
| |-- math
| |-- i2cdev
| | |-- Wire @ 1.0
|-- magneto
| |-- math
|-- math
|-- i2cdev
| |-- Wire @ 1.0
|-- bmi160
| |-- i2cdev
| | |-- Wire @ 1.0
|-- bno055_adafruit
| |-- math
| |-- Wire @ 1.0
|-- bno080
| |-- SPI @ 1.0
| |-- Wire @ 1.0
|-- SparkFun 9DoF IMU Breakout - ICM 20948 - Arduino Library @ 1.2.9
| |-- SPI @ 1.0
| |-- Wire @ 1.0
|-- mpu9250
| |-- math
| |-- i2cdev
| | |-- Wire @ 1.0
Retrieving maximum program size .pio\build\esp12e\firmware.elf
Checking size .pio\build\esp12e\firmware.elf
RAM: [==== ] 43.2% (used 35368 bytes from 81920 bytes)
Flash: [==== ] 40.4% (used 422359 bytes from 1044464 bytes)
Configuring upload protocol…
AVAILABLE: espota, esptool
Looking for upload port…
Auto-detected: COM3
Uploading .pio\build\esp12e\firmware.bin
esptool.py v3.0
Serial port COM3
Connecting…………………_____
A fatal error occurred: Failed to connect to ESP8266: Timed out waiting for packet header
*** [upload] Error 2
========================= [FAILED] Took 30.13 seconds =========================
- The terminal process “C:\Users\Thici.platformio\penv\Scripts\platformio.exe ‘run’, ‘–target’, ‘upload’” terminated with exit code: 1.
- Terminal will be reused by tasks, press any key to close it.
