i need to use multithreading (should be possible it has 2 cores) on my nucleo-wb55rg with the grumpyoldpizza arduino framework modified by @maxgerhardt
But isn’t the second core (Cortex-M0+) explicitly running the BLE Firmware / Stack from a pre-provided firmware? That’s how I read the datasheet and these files. So if you want to use the normal BLE libraries this core cannot be used directly by your application.
But you should get multithreading (not: Multiprocessing) with a e.g. preemptive realt-time operating system, like FreeRTOS, if that’s what you’re asking.
And actually instead of FreeRTOS, it already seems to have CMSIS-RTOS2, with usages like
with API in here.
thankyou but can you write me a example for this api?
I do not have real hardware to test on, but from my general experience with RTOS sytems (FreeRTOS, CMSIS-OS,…) I came up with this:
static k_task_t myTaskHandle;
static __attribute__((aligned(8))) uint8_t myTaskStack[1024];
void myTaskFunction(void *context) {
(void) context; // ignore unused variable
while(true) {
Serial.println("Hello from second task!");
delay(1000); // internally remaps to k_task_delay()
// should not be reached, but if it is, cleanly exit.
k_task_exit();
Serial.begin(9600);
pinMode(LED_BUILTIN, OUTPUT);
int ret = k_task_create(
&myTaskHandle, /* ptr to task handle for later control */
"My Task", /* task name */
myTaskFunction, /* task function */
NULL, /* context ptr */
15, /* task priority, from K_PRIORITY_MIN=15 to K_PRIORITY_MAX=255 */
&myTaskStack[0], /* ptr to task stack memory */
sizeof(myTaskStack), /* size of task stack memory */
0 /* additional options */
if(ret == K_NO_ERROR) {
Serial.println("Task created successfully!");
} else {
Serial.println("Failed to create task: " + String(ret));
delay(1000);
delay(1000);
// grab some task info for the task
k_task_info_t taskInfo;
if(k_task_info(&myTaskHandle, &taskInfo) == K_NO_ERROR) {
String txt = "Task Name: " + String(taskInfo.name);
txt += "\nPrio: " + String(taskInfo.priority);
txt += "\nState: " + String(taskInfo.state); // K_STATE_INACTIVE, K_STATE_READY, ..
txt += "\nWait: " + String(taskInfo.wait); // special wait bitmask, e.g., K_TASK_STATE_WAIT_SLEEP,...
Serial.println(txt);
} else {
Serial.println("Failed to get task info.");
Many RTOSes offer the same functionality, just in a slightly different API. In reference to the more well-known FreeRTOS e.g., you could say that xTaskCreate() is k_task_create(), k_task_delay is vTaskDelay(), k_task_info() is vTaskGetInfo(), et cetera.
This example does not touch on other RTOS features like semaphores, mutexes, queues, thread signaling, et cetera. Just tries to get a second task up and running.
it works flawlessley thankyou
