I’ve been struggling for many hours trying to figure out why I’m getting a “Multiple Definition” compile error when I include a header file via the pio.ini file (eg. -include Single_ESP.h)
Note that the program compiles fine when I include the exact same file directly at the top of main.cpp
Here is the a snippet of error:
c:/users/achro/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld.exe: .pio\build\singleTestESP8266\lib349\FastLED\bitswap.cpp.o:(.bss.densityEnable+0x0): multiple definition of `densityEnable'; .pio\build\singleTestESP8266\lib349\FastLED\FastLED.cpp.o:(.bss.densityEnable+0x0): first defined here
c:/users/achro/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld.exe: .pio\build\singleTestESP8266\lib349\FastLED\colorpalettes.cpp.o:(.bss.densityEnable+0x0): multiple definition of `densityEnable'; .pio\build\singleTestESP8266\lib349\FastLED\FastLED.cpp.o:(.bss.densityEnable+0x0): first defined here
The error gets repeated many more times for different files, but I’ve only showed part of it for brevity. For some reason, the complier things the boolean “densityEnable” is defined in multiple places, but I’ve confirmed (serached all files in project) that it is only defined once in the header file “Single_ESP.h”.
Also note, that the error does NOT occur if I include the header file directly in the top of main.cpp
Here is the header file Single_ESP.h:
// THIS IS A SINGLE ESP CONTROLLER SETUP
// - USED FOR TESTING
/* Need to change the following parameters before compiling for each controller to set their identity */
#ifndef ESP_ID
#define ESP_ID 0 // Number used to identify this particular LED controller in a multi-controller setup (MASTER = 0)
#endif // - used to pass LED control to another controller in a multi-controller setup (coordinated with ESP_NOW)
// - Controller '0' is the first controller, and ESP_NOW MASTER
// - all other controllers are ESP_NOW clients
#define TOTAL_NUM_ESP 1 // Set to total number of ESP controllers in the multi-controller group
#define MASTER_DENSITY 60 // 30 LEDs/metre - MASTER Strip Density - used by CLIENTS to adjust various parameters to match speed and size of patterns
#if ESP_ID == 0
#define ESP_SN 1 // ESP Serial Number for this controller (SN marked with sharpie on each ESP eg. SN = 1 for ESP12-1 )
#define NUM_LEDS 600 // How many leds in your strip?
#define STRIP_DENSITY 60
bool densityEnable = 0; // flag to enable density adjutments to parameters (1 = adjustment allowed)
#define INV_REV 0 // Used to invert chase_rev to align string orientation in multi-contrller setup
#define STASSID "1F-TP-Link_2.4GHz_9B52B8" // Network SSID
/* Parameters for the Firework pattern */
// MAX_HEIGHT is unique to a configuration, as it depends on how the strips are physically arranged
// eg. the Porch Lights have 600 LEDS, but they are arranged in a triangle, so Total height is 300 LEDS (middle of string), so want to set MAX_HEIGHT less than this to allow room for explosion
// this Config is just a single strip of 150 LEDS, so MAX_HEIGHT can be set based on NUM_LEDS
const uint16_t MAX_HEIGHT = NUM_LEDS;
const uint16_t MIN_HEIGHT = MAX_HEIGHT / 2;
#endif //ESP_ID ==
#define MASTER 1
/* The following flags are used to: *
- Select the board type (ESP vs Arduino) *
- Enable Wifi code in the sketch *
#define ESPboard 1 // set to 1 for ESP board
#define wifiGUI 1 // Set to 1 to include WiFi, 0 to exclude
#ifdef ESP8266
#define FL_DATA_PIN D5 // do NOT use D0, as its connected to onboard LED on ESP12, and this drops the voltage too much for the signal to be recognized by WS2812 LEDs
#else
#define FL_DATA_PIN 19 // for ESP32
#define LED_TYPE WS2812B
#define COLOR_ORDER GRB // for strip LEDs
/* ==== SET PATTERN ORDER HERE ======================================================================================================================================================= */
/* The following is used to initialize array that is used to set the random order of the patterns when they are automatically cycled */
#define PATTERN_ORDER 32, 31, 30, 1, 3, 6, 8, 9, 10, 11, 12, 13, 14, 16, 19, 20, 22, 26 // 1st element is used as default pattern on boot up
/* ESP12 has two UARTS (second one only has Tx). The #define below allows you to select which UART you want the
Wifi setup and error messages to go to */
// #define logger (&Serial1) // this is for second UART on ESP, use this for normal operation of the "Serial Bridge"
#define logger (&Serial) // This is the primary UART on ESP that is conected to USB.
/* wifiGUI is a flag used to select the Input/Output device for the sketch by setting serialSel as follows:
- "Serial" - will use the usual serial monitor and keyboard for I/O
- "serverClient" - will use the WiFi client (eg. Android device) */
#if wifiGUI == 0
#define serialSel Serial
#define debugLog Serial
#else
#define serialSel serverClient
#endif // wifiGUI
#define BAUD_SERIAL 115200 // 57600
#define BAUD_LOGGER 115200 // 57600
#define RXBUFFERSIZE 256
Here is the .ini file:
[platformio]
; default_envs = testESP32
; default_envs = testESP32_C3_mini
default_envs = singleTestESP8266
; Base configuration
; Options that are used (or extended) in all device sections (and hence environments) are defined here
[base]
upload_port =
monitor_port =
build_type = release
upload_speed = 921600
lib_extra_dirs = ~/Documents/Arduino/libraries
lib_deps = fastled/FastLED @3.4.0 ;3.9.5, 3.6.0, 3.4.0, 3.3.3
arduino-libraries/NTPClient@^3.2.1
; Can find ESP8266 DEBUG flags here: https://docs.platformio.org/en/latest/platforms/espressif8266.html#serial-debug
;build_flags = -DDEBUG_ESP_CORE -DDEBUG_ESP_WIFI -DDEBUG_ESP_PORT=Serial
build_flags = ; needs this here, otherwise I get error in the "dev_" definitions
; Device sections
; Sections starting with "dev_" contain general settings for a particular type of device.
; They extend the "base" config, both in general and in terms of build flags and dependencies,
; where applicable.
[dev_nodemcuv2]
extends = base
platform = espressif8266
board = nodemcuv2
[dev_d1minipro]
extends = base
board = d1_mini_pro
[dev_lolinESP32]
extends = base
platform = espressif32 @ 6.9.0
board = lolin32
[dev_lolinESP32_C3_mini]
extends = base
board = lolin_c3_mini
; Basic environment section, automatically inherited by all others
[env]
; Project environments
; These are the actual environments defined in this file. Each configures one project for one
; specific device. They extend the "dev_" config for the device in question, both in general
; and in terms of build flags and dependencies, where applicable.
; Note: when adding a new environment to the list, don't forget to explicitly add the device
; section's build_flags and lib_deps options (using ${dev_<device>.<option>}) if you define
; either or both in the environment you add. PlatformIO does not merge them automatically.
; In addition to the build_flags and lib_deps of the device, capability flags and/or dependencies
; can be included where appropriate.
[env:singleTestESP8266]
extends = dev_nodemcuv2
build_flags = -DESP_ID=0
; -v ;enable verbose build
-Isrc ; note that you need forward-slash (/) if you need to add more folders to path
; I noted that -I/src/ does NOT work, but -Isrc/ works
${dev_nodemcuv2.build_flags}
; upload_protocol = espota
; upload_port = 192.168.0.112 ;deck LEDs
[env:testESP32]
extends = dev_lolinESP32
${dev_lolinESP32.build_flags}
[env:testESP32_C3_mini]
extends = dev_lolinESP32_C3_mini
-DFL_DATA_PIN=3
-DTREE_LED_PIN=4
-DledESP=8
${dev_lolinESP32_C3_mini.build_flags}
The main.cpp is large - I tried to attach it, but would not let me…is there a way I can share the main.cpp?
I do have a work around by I really want to understand why this is a problem.
(The workaround is to declare densityEnable in the main.cpp, and using #define in header file to initialize it.)
I hope you can help me solve this mystery
