MSP340 (MSP-EXP340FR5994) debuging
Hello there,
Debuging MSP430 does not work. Debuging console:
Preparing firmware for debugging...
Processing lpmsp430fr5994 (platform: timsp430; board: lpmsp430fr5994)
CONFIGURATION: https://docs.platformio.org/page/boards/timsp430/lpmsp430fr5994.html
PLATFORM: TI MSP430 (2.4.0) > TI LaunchPad MSP-EXP430FR5994LP
HARDWARE: MSP430FR5994 16MHz, 4KB RAM, 256KB Flash
DEBUG: Current (mspdebug) On-board (mspdebug)
 - toolchain-timsp430 @ 1.40603.210219 (4.6.3)
Found 0 compatible libraries
Building in debug mode
Checking size .pio/build/lpmsp430fr5994/firmware.elf
RAM:   [          ]   0.0% (used 2 bytes from 4096 bytes)
Flash: [          ]   0.2% (used 472 bytes from 262144 bytes)
========================= [SUCCESS] Took 0.25 seconds =========================
MSPDebug version 0.24 - debugging tool for MSP430 MCUs
Copyright (C) 2009-2016 Daniel Beer <dlbeer@gmail.com>
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Chip info database from MSP430.dll v3.3.1.4 Copyright (C) 2013 TI, Inc.
undefinedUnknown driver: dslite. Try --help for a list.
Reading symbols from /home/edi/Dokumente/PlatformIO/Projects/Serial/.pio/build/lpmsp430fr5994/firmware.elf...
done.
PlatformIO: debug_tool = mspdebug
:2000: Die Wartezeit für die Verbindung ist abgelaufen.
Terminal:
*  Task wird im Ordner Serial ausgeführt: platformio debug
Compiling .pio/build/lpmsp430fr5994/src/main.o
Linking .pio/build/lpmsp430fr5994/firmware.elf
Building .pio/build/lpmsp430fr5994/firmware.hex
======================================================================== [SUCCESS] Took 0.34 seconds ========================================================================
Any ideas?
Thanks, Edi
MSP430 (MSP-EXP430FR5994) debuging does not work · Issue #31 · platformio/platform-timsp430 · GitHub is already the right place for that discussion.
