Hi
Let me say some thing before I am not a soft man I am an electromechanical one. I started in playing with 8080, machine language then I passed on Freescale starting with CPU 12VCC. When I retired I try to use PIC and TI, but at the end I discover that Nano and Mega boards was more than enough for the needs of today. This speech is just to say I put in a box MSP-EXP430G2, MSP430F5529LP and EK-LM4F120XL and I forgot them. As Platformio seems to be able to work with my old boards I said let me check
Fist board first check
pinMode(P1_6, OUTPUT);
digitalWrite(P1_6, LOW);
digitalWrite(P1_6, HIGH);
delayMicroseconds(500);
Result is working but compiling
Compiling .pio\build\lpmsp430g2452\FrameworkEnergia\main.cpp.o
C:\Users\gsrad\.platformio\packages\framework-energiamsp430\cores\msp430\atof.c: In function 'atof':
C:\Users\gsrad\.platformio\packages\framework-energiamsp430\cores\msp430\atof.c:71:9: warning: floating constant exceeds range of 'double' [-Woverflow]
Second test same as before plus LCD
#include <LiquidCrystal.h>
// initialize the library by associating any needed LCD interface pin
// with the arduino pin number it is connected to
const int rs = P1_4, en = P1_5, d4 = P1_3, d5 = P1_2, d6 = P1_1, d7 = P1_0;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
lcd.begin(16, 2);
lcd.print("hello, world!");
[env:lpmsp430g2452]
platform = timsp430
board = lpmsp430g2452
lib_deps = arduino-libraries/LiquidCrystal@^1.0.7
Result is compiling and uploading but LDC display not working an port P1.6 no more working.
CHANGED BOARD AND CPU G2553
Test with just loop of port P1.6 compiling loading Working
added LCD via I2C
#include <Wire.h>
#include <LiquidCrystal_I2C.h>
LiquidCrystal_I2C lcd(0x27,16,2);
pinMode(P1_0, OUTPUT);
digitalWrite(P1_0, LOW);
lcd.init(P1_7, P1_6);
lcd.backlight();
lcd.setCursor(0, 0);
lcd.print ("PIPPO POLDO");
digitalWrite(P1_0, HIGH);
env:lpmsp430g2553]
platform = timsp430
board = lpmsp430g2553
lib_deps = tonykambo/LiquidCrystal_I2C@0.0.0-alpha+sha.3aa702a291
C:\Users\gsrad\.platformio\packages\framework-energiamsp430\libraries\Wire\utility\twi.c: In function 'twi_disable':
C:\Users\gsrad\.platformio\packages\framework-energiamsp430\libraries\Wire\utility\twi.c:443:5: error: 'UCBzCTLW0' undeclared (first use in this function)
C:\Users\gsrad\.platformio\packages\framework-energiamsp430\libraries\Wire\utility\twi.c:443:5: note: each undeclared identifier is reported only once for each function it appears in
Compiling .pio\build\lpmsp430g2553\FrameworkEnergia\Stream.cpp.o
*** [.pio\build\lpmsp430g2553\libdd6\Wire\utility\twi.c.o] Error 1
.pio\libdeps\lpmsp430g2553\LiquidCrystal_I2C\LiquidCrystal_I2C.cpp: In member function 'void LiquidCrystal_I2C::init_priv(uint8_t, uint8_t)':
.pio\libdeps\lpmsp430g2553\LiquidCrystal_I2C\LiquidCrystal_I2C.cpp:61:30: error: no matching function for call to 'TwoWire::begin(uint8_t&, uint8_t&)'
.pio\libdeps\lpmsp430g2553\LiquidCrystal_I2C\LiquidCrystal_I2C.cpp:61:30: note: candidates are:
C:\Users\gsrad\.platformio\packages\framework-energiamsp430\libraries\Wire/Wire.h:65:10: note: void TwoWire::begin()
C:\Users\gsrad\.platformio\packages\framework-energiamsp430\libraries\Wire/Wire.h:65:10: note: candidate expects 0 arguments, 2 provided
C:\Users\gsrad\.platformio\packages\framework-energiamsp430\libraries\Wire/Wire.h:66:10: note: void TwoWire::begin(uint8_t)
C:\Users\gsrad\.platformio\packages\framework-energiamsp430\libraries\Wire/Wire.h:66:10: note: candidate expects 1 argument, 2 provided
C:\Users\gsrad\.platformio\packages\framework-energiamsp430\libraries\Wire/Wire.h:67:10: note: void TwoWire::begin(int)
C:\Users\gsrad\.platformio\packages\framework-energiamsp430\libraries\Wire/Wire.h:67:10: note: candidate expects 1 argument, 2 provided
*** [.pio\build\lpmsp430g2553\libe14\LiquidCrystal_I2C\LiquidCrystal_I2C.cpp.o] Error 1
TESTING SAME BOARD OF BEFORE DIFFERENT LIB
#include <Wire.h>
#include <hd44780.h>
#include <hd44780ioClass/hd44780_HC1627_I2C.h>
hd44780_HC1627_I2C lcd(0x27);
const int LCD_COLS = 16;
const int LCD_ROWS = 2;
int status;
lcd.print("Hello, World!");
[env:lpmsp430g2553]
platform = timsp430
lib_deps = duinowitchery/hd44780@^1.3.2
Compiling .pio\build\lpmsp430g2553\FrameworkEnergia\MACAddress.cpp.o
Your suggestion may be also “put again in the box”
