I’ve been at this for hours and unable to figure out how to authenticate a CA certificate against an MQTT broker using the mqtt_client library. One trivial task was learning how to embed text files with platform IO which seems to work fine, finally!!
I’ve reviewed countless examples to no avail but it does connect to the MQTT broker when CA authentication over TLS isn’t used. If anyone can assist it would be greatly appreciated.
