I’m not sure if I post in the right forum/channel.
I just started developing with MQTT 5 and I would like to know what are the plans for the integration of ESP-MQTT 5 “natively” :
mqtt5_client.c : esp-mqtt/mqtt5_client.c at master · espressif/esp-mqtt · GitHub
mqtt5_client.h : esp-mqtt/mqtt5_client.h at master · espressif/esp-mqtt · GitHub
…and all other related files including a new version of mqtt_client.h that include conditionally mqtt5.h the following way :
#ifdef CONFIG_MQTT_PROTOCOL_5
#include "mqtt5_client.h"
Meanwhile, how would be the “right” way to override the mqtt_client.h with the new version implementing mqtt5 ?
I’ve read about using “lib_ignore” in platformio.ini this way :
lib_ignore =
mqtt_client
…and adding the new mqtt_client.h under the project include folder. I also added the new mqtt_client.c in the src folder, but that doesn’t seem to work as I got errors that lead me to think that the mqtt_client.h under the include folder of the project was not used but the old one (under .platformio folders tree).
Ex. of errors :
'esp_mqtt_client_config_t' {aka 'const struct <anonymous>'} has no member named 'credentials'
if (config->credentials.client_id) {
'esp_mqtt_client_config_t' {aka 'const struct <anonymous>'} has no member named 'session'
if (config->session.disable_keepalive) {
'esp_mqtt_client_config_t' {aka 'const struct <anonymous>'} has no member named 'network'
client->config->auto_reconnect = !config->network.disable_auto_reconnect;
The new version of mqtt_client.h clearly includes those structs members :
typedef struct esp_mqtt_client_config_t {
* Broker related configuration
struct broker_t {
* Broker address
* - uri have precedence over other fields
* - If uri isn't set at least hostname, transport and port should.
struct address_t {
const char *uri; /*!< Complete *MQTT* broker URI */
const char *hostname; /*!< Hostname, to set ipv4 pass it as string) */
esp_mqtt_transport_t transport; /*!< Selects transport*/
const char *path; /*!< Path in the URI*/
uint32_t port; /*!< *MQTT* server port */
} address; /*!< Broker address configuration */
* Broker identity verification
* If fields are not set broker's identity isn't verified. it's recommended
* to set the options in this struct for security reasons.
struct verification_t {
bool use_global_ca_store; /*!< Use a global ca_store, look esp-tls
documentation for details. */
esp_err_t (*crt_bundle_attach)(void *conf); /*!< Pointer to ESP x509 Certificate Bundle attach function for
the usage of certificate bundles. */
const char *certificate; /*!< Certificate data, default is NULL, not required to verify the server. */
size_t certificate_len; /*!< Length of the buffer pointed to by certificate. */
const struct psk_key_hint *psk_hint_key; /*!< Pointer to PSK struct defined in esp_tls.h to enable PSK
authentication (as alternative to certificate verification).
PSK is enabled only if there are no other ways to
verify broker.*/
bool skip_cert_common_name_check; /*!< Skip any validation of server certificate CN field, this reduces the
security of TLS and makes the *MQTT* client susceptible to MITM attacks */
const char **alpn_protos; /*!< NULL-terminated list of supported application protocols to be used for ALPN */
} verification; /*!< Security verification of the broker */
} broker; /*!< Broker address and security verification */
* Client related credentials for authentication.
struct credentials_t {
const char *username; /*!< *MQTT* username */
const char *client_id; /*!< Set *MQTT* client identifier. Ignored if set_null_client_id == true If NULL set
the default client id. Default client id is ``ESP32_%CHIPID%`` where `%CHIPID%` are
last 3 bytes of MAC address in hex format */
bool set_null_client_id; /*!< Selects a NULL client id */
* Client authentication
* Fields related to client authentication by broker
* For mutual authentication using TLS, user could select certificate and key,
* secure element or digital signature peripheral if available.
struct authentication_t {
const char *password; /*!< *MQTT* password */
const char *certificate; /*!< Certificate for ssl mutual authentication, not required if mutual
authentication is not needed. Must be provided with `key`.*/
size_t certificate_len; /*!< Length of the buffer pointed to by certificate.*/
const char *key; /*!< Private key for SSL mutual authentication, not required if mutual authentication
is not needed. If it is not NULL, also `certificate` has to be provided.*/
size_t key_len; /*!< Length of the buffer pointed to by key.*/
const char *key_password; /*!< Client key decryption password, not PEM nor DER, if provided
`key_password_len` must be correctly set. */
int key_password_len; /*!< Length of the password pointed to by `key_password` */
bool use_secure_element; /*!< Enable secure element, available in ESP32-ROOM-32SE, for SSL connection */
void *ds_data; /*!< Carrier of handle for digital signature parameters, digital signature peripheral is
available in some Espressif devices. */
} authentication; /*!< Client authentication */
} credentials; /*!< User credentials for broker */
* *MQTT* Session related configuration
struct session_t {
* Last Will and Testament message configuration.
struct last_will_t {
const char *topic; /*!< LWT (Last Will and Testament) message topic */
const char *msg; /*!< LWT message, may be NULL terminated*/
int msg_len; /*!< LWT message length, if msg isn't NULL terminated must have the correct length */
int qos; /*!< LWT message QoS */
int retain; /*!< LWT retained message flag */
} last_will; /*!< Last will configuration */
bool disable_clean_session; /*!< *MQTT* clean session, default clean_session is true */
int keepalive; /*!< *MQTT* keepalive, default is 120 seconds */
bool disable_keepalive; /*!< Set `disable_keepalive=true` to turn off keep-alive mechanism, keepalive is active
by default. Note: setting the config value `keepalive` to `0` doesn't disable
keepalive feature, but uses a default keepalive period */
esp_mqtt_protocol_ver_t protocol_ver; /*!< *MQTT* protocol version used for connection.*/
int message_retransmit_timeout; /*!< timeout for retransmitting of failed packet */
} session; /*!< *MQTT* session configuration. */
* Network related configuration
struct network_t {
int reconnect_timeout_ms; /*!< Reconnect to the broker after this value in miliseconds if auto reconnect is not
disabled (defaults to 10s) */
int timeout_ms; /*!< Abort network operation if it is not completed after this value, in milliseconds
(defaults to 10s). */
int refresh_connection_after_ms; /*!< Refresh connection after this value (in milliseconds) */
bool disable_auto_reconnect; /*!< Client will reconnect to server (when errors/disconnect). Set
`disable_auto_reconnect=true` to disable */
} network; /*!< Network configuration */
* Client task configuration
struct task_t {
int priority; /*!< *MQTT* task priority*/
int stack_size; /*!< *MQTT* task stack size*/
} task; /*!< FreeRTOS task configuration.*/
* Client buffer size configuration
* Client have two buffers for input and output respectivelly.
struct buffer_t {
int size; /*!< size of *MQTT* send/receive buffer*/
int out_size; /*!< size of *MQTT* output buffer. If not defined, defaults to the size defined by
``buffer_size`` */
} buffer; /*!< Buffer size configuration.*/
} esp_mqtt_client_config_t;
Note that I also added this line in platform.ini:
-D MQTT_PROTOCOL_5=y
Thank you.
