PlatformIO looks very nice and potentially a replacement for my MPLAB IDE for development of our custom PCBs (NOT stadnard dev kits/boards)…
Is it possible?
How easy (or not) is it to replace the ENTIRE MPLAB IDE with PlatformIO?
How easy (or not) is it to set it up specifically for the PIC32 family
is there anything that MPLAB does that PlatformIO does not?
do I have to manually setup and configure the Microchip PIC32 libraries and the XC32 compiler or are they already pre-setup (perhaps through an automatic install option)?
I would really like to use this but don’t want to if the installation is too risky or time consuming or if the features are much more limited than MPLAB itself.
Depends on what you mean by “is it possible”. To completely replace it? Sure, but there might be some features that MPLAB has that VSCode + PlatformIO doesn’t offer. I’ve never used MPLAB, so no idea. All the basics regarding code compilation and debugging should be there though.
PlatformIO has general support for PIC32, as stated in the documentation with example projects available. After doing the basic installation you can just start off from the pre-prepared examples or create a new project for your target MCU in the project wizard.
All compilers and packages are installed automatically when PlatformIO detects you use them (e.g., framework = arduino in the platformio.ini), you never have to download a compiler of framework yourself.
If the PIC32 peripheral library is compilabe by pic32-gcc, one can setup a baremetal project with the libraries and needed compiler options in it to create a project that can make use of those librarires.
