This error comes while we build
-- Application: C:/Users/dell/Documents/PlatformIO/Projects/test/zephyr
-- Zephyr version: 2.3.0 (C:/Users/dell/.platformio/packages/framework-zephyr)
-- Found Python3: C:/Users/dell/.platformio/penv/Scripts/python.exe (found suitable exact version "3.7.7") found components: Interpreter
-- Board: nrf52832_mdk
-- Found dtc: C:/Users/dell/.platformio/packages/tool-dtc/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Configuring incomplete, errors occurred!
Python path: C:/Users/dell/.platformio/penv/Scripts/python.exe
CMake Error at C:/Users/dell/.platformio/packages/framework-zephyr/cmake/zephyr_module.cmake:46 (message):
File "C:/Users/dell/.platformio/packages/framework-zephyr/scripts/zephyr_module.py", line 24, in <module>
import pykwalify.core
File "c:\users\dell\.platformio\penv\lib\site-packages\pykwalify\core.py", line 25, in <module>
from dateutil.parser import parse
File "c:\users\dell\.platformio\penv\lib\site-packages\dateutil\parser\__init__.py", line 2, in <module>
from ._parser import parse, parser, parserinfo, ParserError
File "c:\users\dell\.platformio\penv\lib\site-packages\dateutil\parser\_parser.py", line 42, in <module>
import six
ModuleNotFoundError: No module named 'six'
C:/Users/dell/.platformio/packages/framework-zephyr/cmake/app/boilerplate.cmake:507 (include)
CMakeLists.txt:2 (include)
================================================================ [FAILED] Took 2.37 seconds ================================================================
The terminal process "C:\Users\dell\.platformio\penv\Scripts\platformio.exe 'run'" terminated with exit code: 1.
