Modifying framework files
I am using a Teensy 3.2, and I am trying to test some modifications to its core files, that are part of the framework-arduinoteensy package.
I am using atom, and I am on Mac OS X El Capitan.
I am trying to do this by modifying the files in ~/.platformio/packages/framework-arduinoteensy/cores but when I compile, it does not appear that the changes are taking effect. I have even tested by making some drastic breaking changes, but my code will still compile just fine even after doing a clean build.
Am I missing a step, or some cached things that are preventing my changes from propagating? Is there a standardized way to create a development version of a package, to test with that I should follow to do this kind of thing?
Thank you!
Turn on verbose mode with pio run --version to see where are files located.
hi,
this is an old thread, but I cannot figure out where to find the source files. With -v I can find the source for the libraries I installed, but not for the core. I would like to modify one of the Arduino Framework files, wiring.c. I can find the .c.o file, but how can I modify the source code?
thanks in advance!
Maybe PlatformIO only recompiled that library. Make sure to clean the project before recompiiling. Do pio run -t clean && pio run -v, there you should find the core files. They should be one of the framework-arduinoXX packages in /home/<user>/.platformio/packages/.
thanks @maxgerhardt! That was easy and worked :slight_smile:
