This is a question about modifying the env variable for a build.
Say one has a number of libraries (arranged in the lib folder). How does one change the build flag for ONLY a single library without affecting everything else? I’ve tried using a middleware script:
def target-lib_configuration(env, node):
env.Append(CCFLAGS=["-Wno-error=maybe-uninitialized"])
env.AddBuildMiddleware(target-lib_configuration, "*/target-lib/*")
But this appears to effect the entire build, not just the target lib. It also seems cumulative, for each file that matches it appends the change.
Many thanks
