Hello, I would use FakeIt library, but I don’t know how. FakeIt documentation tell, that I should include fakeit.hpp file, but when I’m trying to do it, platform.io doesn’t see it. Unfortunately fakeIt library has more than one fakeit.hpp file. How to correctly include fakeIt library to platformio projects?
@maxgerhardt That’s my PlatformIO.ini file. What should I type there?
;settings:
[enviroment]
version = '"alpha"'
bblanchon/ArduinoJson @ ^6.18.5
-DVERSION=${enviroment.version}
[test_enviroment]
test_lib_deps =
https://github.com/eranpeer/FakeIt.git
${enviroment.lib_deps}
${test_enviroment.test_lib_deps}
native_build_flags =
-DTEST
${enviroment.build_flags}
common_build_flags =
-DARDUINO
${test_enviroment.native_build_flags}
[platformio]
default_envs =
nanoNew
unoR3
;Arduino nano V3.0
[env:nanoNew]
board = nanoatmega328new
lib_deps = ${enviroment.lib_deps}
build_flags = ${enviroment.build_flags}
[env:test_nanoNew]
lib_deps = ${test_enviroment.lib_deps}
build_flags = ${test_enviroment.common_build_flags}
;Arduino uno R3
[env:unoR3]
board = uno
[env:test_unoR3]
board = uno
;native
[env:native]
platform = native
build_flags = ${test_enviroment.native_build_flags}
Sorry I’m very busy in the moment to do in-depth analysis, but have you tried the ArduinoFake example which is intended for Mocking Arduino on embedded platforms? There is an official example at platformio-examples/unit-testing/arduino-mock at develop · platformio/platformio-examples · GitHub.
No, I haven’t. Is ArduinoFake in early access? I’m scared to use early access software.
GitHub - FabioBatSilva/ArduinoFake: Arduino mocking made easy has had 3 releases and is well-used.
Ok, I think that’s solve my problem. Thank’s for help.
