Missing package manifest error
My Teensy project compiled when I last used it. Today it won’t and I get the error shown below. Any help much appreciated
My code uses ezbutton debounce library, so not sure why the library manager has decided to remove it.
from my main.cpp:
#include <ezButton.h>
error detail:
Processing teensy36 (platform: teensy; board: teensy36; framework: arduino)
-----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Removing unused dependencies...
Library Manager: Removing ezButton @ 1.0.6
MissingPackageManifestError: Could not find one of 'library.json, library.properties, module.json' manifest files in the package
 *  The terminal process "C:\Users\Paul\.platformio\penv\Scripts\platformio.exe 'run'" terminated with exit code: 1.
PIO file content:
[env:teensy36]
platform = teensy
board = teensy36
lib_deps = dfrobot/DFRobot_MCP23017@^1.0.0
i solved it by deleting the ezbutton library folder - drastic action, glad I’m not at work…
Then reinstalled the ezbutton library. Code now compiles.
thanks for looking.
Paul
Simply add the library to your lib_deps:
  arduinogetstarted/ezButton@^1.0.6
See PlatformIO Registry
