I might not be in the right subforum, but as I have a problem with a command I typed in the CLI I’d post it here. I’m sure it’s a small thing and you can help me in no time.
Trying to alter the partition table of an ESP32 in an existing project ESP-IDF in Visual Studio Code after updating the platform, I’m running into the following errors:
PS D:\CASWorkspace\NodeMCU-HelloWorld> pio run -t menuconfig
Processing nodemcu-32s (platform: espressif32; board: nodemcu-32s; framework: espidf)
----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/nodemcu-32s.html
PLATFORM: Espressif 32 (4.1.0) > NodeMCU-32S
- framework-espidf 3.40302.0 (4.3.2)
- tool-cmake 3.16.4
- tool-esptoolpy 1.30100.210531 (3.1.0)
- tool-idf 1.0.1
- tool-mconf 1.4060000.20190628 (406.0.0)
- tool-ninja 1.9.0
- toolchain-esp32ulp 1.22851.191205 (2.28.51)
Found 0 compatible libraries
Running menuconfig...
[0/1] Re-running CMake...
fatal: not a git repository (or any of the parent directories): .git
-- Project is not inside a git repository, or git repository has no commits; will not use 'git describe' to determine PROJECT_VER.
-- Building ESP-IDF components for target esp32
-- Project sdkconfig file D:/CASWorkspace/NodeMCU-HelloWorld/sdkconfig.nodemcu-32s
CMake Error at C:/Users/cbergs/.platformio/packages/framework-espidf/tools/cmake/crosstool_version_check.cmake:37 (message):
Toolchain:
C:/Users/cbergs/.platformio/packages/toolchain-xtensa32/bin/xtensa-esp32-elf-gcc.exe,
crosstool-ng version esp-2020r3 doesn't match supported version esp-2021r2
Please try to run 'idf.py fullclean' to solve it quickly.
Check Getting Started documentation if the error continues.
You can override this error and proceed with build by defining the
IDF_MAINTAINER environment variable.
C:/Users/cbergs/.platformio/packages/framework-espidf/components/esp32/project_include.cmake:31 (crosstool_version_check)
C:/Users/cbergs/.platformio/packages/framework-espidf/tools/cmake/build.cmake:315 (include)
C:/Users/cbergs/.platformio/packages/framework-espidf/tools/cmake/build.cmake:466 (__build_process_project_includes)
CMakeLists.txt:3 (project)
-- Configuring incomplete, errors occurred!
See also "D:/CASWorkspace/NodeMCU-HelloWorld/.pio/build/nodemcu-32s/CMakeFiles/CMakeOutput.log".
FAILED: build.ninja
C:\Users\cbergs\.platformio\packages\tool-cmake\bin\cmake.exe -SD:\CASWorkspace\NodeMCU-HelloWorld -BD:\CASWorkspace\NodeMCU-HelloWorld\.pio\build\nodemcu-32s
ninja: error: rebuilding 'build.ninja': subcommand failed
Error: Couldn't execute 'menuconfig' target.
scons: *** [menuconfig] Explicit exit, status 1
========================== [FAILED] Took 12.96 seconds =======================
I’d be glad for any help. Thanks for putting your time into this!
Regards
Chris
