I’m using PlatformIO on VS Code with ESP-IDF 3.3.5 and I the ISR on the following code won’t fire.
I’ve attached an external PWM signal on GPIO 25 and I call ADC_PWM_Init() on setup(). When I read the adc_pwm_ticks (during the main loop()), the struct fields are all zero. I can tell that the ISR is not firing because I’ve placed Serial.print(“isr is firing”); on the first of the ISR on a previous code version and got no message on the UART…
#include "freertos/task.h"
#include "soc/rtc.h"
#include "driver/mcpwm.h"
#include "soc/mcpwm_reg.h"
#include "soc/mcpwm_struct.h"
#include "esp_attr.h"
#include "adc/adc_pwm.h"
#define CAP0_INT_EN BIT(27) //Capture 0 interrupt bit
#define ADC_PWM_PIN GPIO_NUM_25
//this struct is actually contained in the header file, not the .cpp file...
typedef struct {
uint32_t period;
uint32_t duty_cycle;
} ADC_PWM;
volatile uint32_t pos_edg_0 = 0;
volatile uint32_t pos_edg_1 = 0;
volatile uint32_t neg_edg_0 = 0;
volatile uint8_t first_meas = 1;
float ticks2us;
//this struct is declared as "extern" on the header file...
volatile ADC_PWM adc_pwm_ticks={0,0};
static void IRAM_ATTR ADC_PWM_ISR_handler(void*) {
if(mcpwm_capture_signal_get_edge(MCPWM_UNIT_0, MCPWM_SELECT_CAP0) == MCPWM_POS_EDGE) {
if(first_meas) {
first_meas=0;
pos_edg_0 = mcpwm_capture_signal_get_value(MCPWM_UNIT_0, MCPWM_SELECT_CAP0);
} else {
pos_edg_1 = mcpwm_capture_signal_get_value(MCPWM_UNIT_0, MCPWM_SELECT_CAP0);
adc_pwm_ticks.period = pos_edg_1 - pos_edg_0;
pos_edg_0 = pos_edg_1;
} else {
if(!first_meas)
neg_edg_0 = mcpwm_capture_signal_get_value(MCPWM_UNIT_0, MCPWM_SELECT_CAP0);
adc_pwm_ticks.duty_cycle = neg_edg_0 - pos_edg_0;
MCPWM0.int_clr.val = CAP0_INT_EN;
void ADC_PWM_Init() {
ticks2us = 1000000.0 / rtc_clk_apb_freq_get();
mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM_CAP_0, ADC_PWM_PIN);
gpio_pulldown_en(ADC_PWM_PIN);
mcpwm_capture_enable(MCPWM_UNIT_0, MCPWM_SELECT_CAP0, MCPWM_BOTH_EDGE, 0);
MCPWM0.int_ena.val = CAP0_INT_EN;
mcpwm_isr_register(MCPWM_UNIT_0, ADC_PWM_ISR_handler, NULL, ESP_INTR_FLAG_IRAM, NULL);
What am I missing?
Thanks in advance.
