[MBED] Thread not defined
Today I needed to compile an old code (4month old) that used to work/compile in platfomio without issue.
today after a PIO update, the code got mad at me and decided that line was not valid anymore:
use “mbed.h”
Thread envent1,t2;
return “Thread is not defined” error in the editor but the compiling worked.
The platformio.ini is like that:
[env:nucleo_f446re]
platform = ststm32
board = nucleo_f446re
framework = mbed
build_flags = -D PIO_FRAMEWORK_MBED_RTOS_PRESENT
debug_tool = stlink
I checked [Mbed — PlatformIO latest documentation](http://pio mbed doc) and couldn’t find anything helpful.
Any help will be appreciated !
Thanks
Try to add the rtos header file explicitly: #include "rtos.h"
It works but I got the same with ‘EventQueue’.
I added Event.h but nothing changed.
Thanks for your support!
Try #include "mbed_events.h"
