Sir,
After run
#include “mbed.h”
DigitalOut myled(LED1);
int main() {
while(1) {
myled = 1;
wait(0.1);
myled = 0;
wait(0.1);
printf(“hello”);
[env:nrf52_dk]
platform = nordicnrf52
board = ublox_evk_nina_b1
framework = mbed
Does printf send data to wich NINA B pin ?
Can you verify ?
What does the PinNames.h
header say about standard UART pins?
The is not to ev nina b1
look
C:\Users\tcpipchip.platformio\packages\framework-mbed\targets\TARGET_ublox\TARGET_HI2110\TARGET_SARA_NBIOT
Only Sara!
Maybe is fflush problem!, i can see that there is a big delay to send the data out!
Solved
#include “mbed.h”
#include “stdio.h”
int main() {
while(1) {
myled = 1;
wait(1.0);
myled = 0;
wait(1.0);
printf(“hello from Miguel wisintainer\r”);
fflush(stdout);
CTS RTS must be short circuited
Miguel_Alexandre_Wis:
Where is that file ?
Just put #include "PinNames.h"
in your IDE and follow the symbol. Takes you to framework-mbed/targets/TARGET_NORDIC/TARGET_NRF5x/TARGET_NRF52/TARGET_MCU_NRF52832/TARGET_UBLOX_EVK_NINA_B1/PinNames.h
Says right there
// Nordic SDK pin names
RX_PIN_NUMBER = p5,
TX_PIN_NUMBER = p6,
CTS_PIN_NUMBER = p7,
RTS_PIN_NUMBER = p31,
STDIO_UART_TX = TX_PIN_NUMBER,
STDIO_UART_RX = RX_PIN_NUMBER,
STDIO_UART_CTS = CTS_PIN_NUMBER,
STDIO_UART_RTS = RTS_PIN_NUMBER,
I2C_SDA0 = p2,
I2C_SCL0 = p3,
// mBed interface pins
USBTX = TX_PIN_NUMBER,
USBRX = RX_PIN_NUMBER
You can also add the object
Serial pc(USBTX, USBRX, "serial", 115200);
to your main.cpp
and call printf()
on that object to make sure it’s using those pins.
And about Analog, do you have a good example to mbed nina b ? With full analog setup ?
#include “mbed.h”
#include “stdio.h”
#include “pinNames.h”
AnalogIn ain(A0);
int main() {
while(1) {
myled = 1;
wait(1.0);
myled = 0;
wait(1.0);
float f=ain.read_u16();
printf("%f\r",f);
printf("hello from Miguel wisintainer\r");
fflush(stdout);
This example only read the analog, but i cant see the analog setup ?
What do you mean by ‘analog setup’.
Good morning
I mean for example , to config the resolution, gain, etc!
It’s implemented in mbed-os/analogin_api.c at master · ARMmbed/mbed-os · GitHub with config values coming from mbed-os/sdk_config.h at master · ARMmbed/mbed-os · GitHub .
If you want a different config call nrf_drv_saadc_init
and nrf_drv_saadc_channel_init
again, I guess.
