I have Visual Studio Code:
Version: 1.47.3 (user setup)
Commit: 91899dcef7b8110878ea59626991a18c8a6a1b3e
Date: 2020-07-23T13:12:49.994Z
Electron: 7.3.2
Chrome: 78.0.3904.130
Node.js: 12.8.1
V8: 7.8.279.23-electron.0
OS: Windows_NT x64 10.0.19041
And installed PlatformIO to start a software development in a Nucleo F072RB. I tested the STM32Cube framework and worked very good, but the problem was when I started to test the Mbed framework.
I setup a simple project with this platform.ini :
[env:nucleo_f072rb]
platform = ststm32
board = nucleo_f072rb
framework = mbed
I did not even write any code to the main.cpp file and started to build the project. The fact is that it never ends, I waited for like 5 minutes and the build process keeps scrolling, loading and using my CPU resources and I can’t find this logically correct. So I wanted to see if you could help to find a solution for this issue.
I already decided to uninstall and install the PlatformIO extension again but this did not solve the problem.
Hope to receive some news from you guys soon! Thanks!
This is the output that I could get from the build process until I ended:
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\nanostack-hal-mbed-cmsis-rtos\ns_file_system_api.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\nanostack-hal-mbed-cmsis-rtos\ns_hal_init.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\nanostack-hal-mbed-cmsis-rtos\nvm\nvm_ram.o
In file included from C:/Users/AIOTIK~1/PLATFO~1/packages/FRAMEW~2/targets/TAE5D3~1/TARGET~1/common_objects.h:40,
from C:/Users/AIOTIK~1/PLATFO~1/packages/FRAMEW~2/targets/TAE5D3~1/TARGET~1/TARGET~2/objects.h:57,
from C:/Users/AIOTIK~1/PLATFO~1/packages/FRAMEW~2/targets/TAE5D3~1/device.h:38,
from C:/Users/AIOTIK-005/.platformio/packages/framework-mbed/hal/ticker_api.h:25,
from C:/Users/AIOTIK-005/.platformio/packages/framework-mbed/hal/us_ticker_api.h:24,
from C:/Users/AIOTIK-005/.platformio/packages/framework-mbed/drivers/HighResClock.h:21,
from C:/Users/AIOTIK~1/PLATFO~1/packages/FRAMEW~2/drivers/Timeout.h:20,
from C:\Users\AIOTIK-005\.platformio\packages\framework-mbed\features\nanostack\nanostack-hal-mbed-cmsis-rtos\arm_hal_timer.cpp:25:
C:/Users/AIOTIK~1/PLATFO~1/packages/FRAMEW~2/targets/TAE5D3~1/TARGET~1/device/stm32f0xx_ll_crc.h: In function 'void LL_CRC_FeedData16(CRC_TypeDef*, uint16_t)':
C:/Users/AIOTIK~1/PLATFO~1/packages/FRAMEW~2/targets/TAE5D3~1/TARGET~1/device/stm32f0xx_ll_crc.h:371:4: warning: dereferencing type-punned pointer will break strict-aliasing rules
[-Wstrict-aliasing]
371 | *(uint16_t __IO *)(&CRCx->DR) = (uint16_t) InData;
| ^~~~~~~~~~~~~~~~~~Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\nanostack-interface\Nanostack.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack-eventloop\source\event.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack-eventloop\source\ns_timeout.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack-eventloop\source\ns_timer.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack-eventloop\source\system_timer.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\Bootstraps\Generic\network_lib.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\Bootstraps\Generic\protocol_6lowpan.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\Bootstraps\Generic\protocol_6lowpan_bootstrap.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\Bootstraps\Generic\protocol_6lowpan_interface.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\Fragmentation\cipv6_fragmenter.o
from C:/Users/AIOTIK~1/PLATFO~1/packages/FRAMEW~2/features/netsocket/SocketStats.h:24,
from C:/Users/AIOTIK~1/PLATFO~1/packages/FRAMEW~2/features/netsocket/InternetSocket.h:30,
from C:/Users/AIOTIK~1/PLATFO~1/packages/FRAMEW~2/features/netsocket/UDPSocket.h:23,
from C:/Users/AIOTIK~1/PLATFO~1/packages/FRAMEW~2/features/NETSOC~1/nsapi.h:40,
from C:/Users/AIOTIK~1/PLATFO~1/packages/FRAMEW~2/features/NETSOC~1/OnboardNetworkStack.h:20,
from C:\Users\AIOTIK-005\.platformio\packages\framework-mbed\features\nanostack\nanostack-interface\Nanostack.h:21,
from C:\Users\AIOTIK-005\.platformio\packages\framework-mbed\features\nanostack\nanostack-interface\Nanostack.cpp:20:
[-Wstrict-aliasing]
| ^~~~~~Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\IPHC_Decode\6lowpan_iphc.o
~~~~Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\IPHC_Decode\iphc_compress.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\IPHC_Decode\iphc_decompress.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\IPHC_Decode\lowpan_context.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\MAC\beacon_handler.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\MAC\mac_data_poll.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\MAC\mac_helper.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\MAC\mac_ie_lib.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\MAC\mac_pairwise_key.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\MAC\mac_response_handler.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\Mesh\mesh.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\ND\nd_router_object.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\NVM\nwk_nvm.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\Thread\thread_bbr_api.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\Thread\thread_bbr_commercial.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\Thread\thread_beacon.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\Thread\thread_bootstrap.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\Thread\thread_border_router_api.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\Thread\thread_ccm.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\Thread\thread_commissioning_api.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\Thread\thread_commissioning_if.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\Thread\thread_common.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\Thread\thread_dhcpv6_server.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\Thread\thread_diagnostic.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\Thread\thread_discovery.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\Thread\thread_host_bootstrap.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\Thread\thread_joiner_application.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\Thread\thread_leader_service.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\Thread\thread_lowpower_api.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\Thread\thread_lowpower_private_api.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\Thread\thread_management_api.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\Thread\thread_management_client.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\Thread\thread_management_if.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\Thread\thread_management_server.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\Thread\thread_mdns.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\Thread\thread_meshcop_lib.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\Thread\thread_mle_message_handler.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\Thread\thread_nd.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\Thread\thread_neighbor_class.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\Thread\thread_net_config_api.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\Thread\thread_network_data_lib.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\Thread\thread_network_data_storage.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\Thread\thread_network_synch.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\Thread\thread_nvm_store.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\Thread\thread_resolution_client.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\Thread\thread_resolution_server.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\Thread\thread_router_bootstrap.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\Thread\thread_routing.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\Thread\thread_test_api.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\adaptation_interface.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\ws\ws_bbr_api.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\ws\ws_bootstrap.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\ws\ws_cfg_settings.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\ws\ws_common.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\ws\ws_eapol_auth_relay.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\ws\ws_eapol_pdu.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\ws\ws_eapol_relay.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\ws\ws_eapol_relay_lib.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\ws\ws_empty_functions.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\ws\ws_ie_lib.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\ws\ws_llc_data_service.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\ws\ws_management_api.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\ws\ws_mpx_header.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\ws\ws_neighbor_class.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\ws\ws_pae_auth.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\ws\ws_pae_controller.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\ws\ws_pae_key_storage.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\ws\ws_pae_lib.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\ws\ws_pae_nvm_data.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\ws\ws_pae_nvm_store.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\ws\ws_pae_supp.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\ws\ws_pae_time.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\ws\ws_pae_timers.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\ws\ws_stats.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\6LoWPAN\ws\ws_test_api.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\BorderRouter\border_router.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\Common_Protocols\icmpv6.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\Common_Protocols\icmpv6_prefix.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\Common_Protocols\icmpv6_radv.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\Common_Protocols\ipv6.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\Common_Protocols\ipv6_flow.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\Common_Protocols\ipv6_fragmentation.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\Common_Protocols\ipv6_resolution.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\Common_Protocols\mld.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\Common_Protocols\tcp.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\Common_Protocols\udp.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\Core\buffer_dyn.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\Core\ns_address_internal.o
C:\Users\AIOTIK-005\.platformio\packages\framework-mbed\features\nanostack\sal-stack-nanostack\source\Common_Protocols\tcp.c:86:20: warning: 'trace_tcp_flags' defined but not used
[-Wunused-function]
86 | static const char *trace_tcp_flags(uint16_t flags)
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\Core\ns_monitor.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\Core\ns_socket.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\Core\sockbuf.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\DHCPv6_Server\DHCPv6_Server_service.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\DHCPv6_client\dhcpv6_client_service.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\MAC\IEEE802_15_4\mac_cca_threshold.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\MAC\IEEE802_15_4\mac_fhss_callbacks.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\MAC\IEEE802_15_4\mac_filter.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\MAC\IEEE802_15_4\mac_header_helper_functions.o
Compiling .pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\MAC\IEEE802_15_4\mac_indirect_data.o
*** [.pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\MAC\IEEE802_15_4\mac_header_helper_functions.o] Build interrupted.
*** [.pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\MAC\IEEE802_15_4\mac_filter.o] Build interrupted.
*** [.pio\build\nucleo_f072rb\FrameworkMbed\features\nanostack\sal-stack-nanostack\source\MAC\IEEE802_15_4\mac_indirect_data.o] Build interrupted.
Error: Aborted by user
The terminal process "C:\Users\AIOTIK-005\.platformio\penv\Scripts\platformio.exe 'run'" terminated with exit code: 1.
