How can i import this examples to Platformio ?
Will they run on NRF52 ?
I had tested but they didnt run!
Thanks!
Thanks!
Could you share your project which does not work?
Here the code
https://github.com/tcpipchip/led_ble_mbed_platformio.git
It´s compile and i can transfer to NINA B112.
I can see only the GPIO1 blinking…but…BLE SCANNER can´t see the BLE module!
Thanks!
Could you add mbed_app.json to the root of https://github.com/tcpipchip/led_ble_mbed_platformio?
See also mbed OS Configuraiton docs.
Ivan
see my steps
*i opened your Platformio NRF52 thermometer example
downloaded files from the https://github.com/ARMmbed/mbed-os-example-ble/tree/master/BLE_LED
i replaced the mbed code example into your thermometer source code
i inserted LEDService.h and pretty_printer.h got from MBED
then change the includes to
#include <mbed_events.h>
#include <rtos.h>
#include “mbed.h”
#include “ble/BLE.h”
#include “LEDService.h”
#include “pretty_printer.h”
Then i compiled with platfomio, my leds (gpio01) blinks, but i can´t see the device on BLE SCANNER
No json on platformio, only on
@valeros could you help here?
Thank you so much! If all works i will do the BLOG about, using Platafomio with MBED BLE
Hi @Miguel_Alexandre_Wis! Indeed, this example has some issues. Could you try the following configuration (change board field to your board name):
[platformio]
home_dir = C:\\.platformio
[env:nrf52_dk]
platform = https://github.com/platformio/platform-nordicnrf52.git
framework = mbed
board = nrf52_dk
build_flags = -DPIO_FRAMEWORK_MBED_RTOS_PRESENT
Don’t forget to copy source files LEDService.h, main.cpp, pretty_printer.h from the repository to the src folder in your project and copy mbed_app.json to the root folder of your project (near platformio.ini file).
Thanks to help all!
Still the led blinks but i can’t see the device on BLE SCANNER
here the GIT updated
btw, if you compile online on MBED, works!
If i put
board = nrf52_dk works, i see the module on BLE SCANNER
If i put
board = ublox_evk_nina_b1 NOT works, i cant see the module on BLE SCANNER and the code size is about a few k bytes
I think that this can help to solve!
Hi friends,
Any news ?
Probably the example doesn’t work with ublox_evk_nina_b1 because this board it’s not specified in the mbed_app.json. You can try the next configuration in your mbed_app.json:
"target_overrides": {
"target.features_add": ["BLE"],
"target.features_remove": ["LWIP", "COMMON_PAL", "IPV4", "NANOSTACK_FULL"],
"target.extra_labels_add": ["CORDIO", "CORDIO_LL", "SOFTDEVICE_NONE", "NORDIC_CORDIO"],
"target.extra_labels_remove": ["SOFTDEVICE_COMMON", "SOFTDEVICE_S132_FULL", "NORDIC_SOFTDEVICE"]
Thanks to help
Still not works! No BLE scanned…
That’s strange. Could you please try to build and upload your example using mbed-cli tool? Does it work?
Yes, i will do, VALEROS
I did a lot of tests, i remember that using mbed-cli tools doesnt work, but works very nice on MBED ONLINE COMPILER.
I will try tomorrow!
THANKS!!!
mbed-cli compiles, but BLE SCANNER didnt find it
I compiled (mbed-cli) the LED APPLICATION example to U-BLOX NINA B112 and execute it, but the BLE SCANNER didnt find it. But sends data to serial and blink led
mbed compile -t GCC_ARM -m UBLOX_EVK_NINA_B1
then i burned the BLE_LED.hex
I remember that this example had worked in the past!
Same with the mbed-compiler online version…
Fails too!
I tested on u-blox evb and module stand alone
Can you verify ?
Thanks
One tip,
I did find some hex files created with mbed-cli weeks ago (wich includes the BLE LED example) and they works very fine after i burn on NINA B112.
Is it a MBED-OS update problem to NINA B112 ?
I think the best way to solve the problem is try to find the last working framework version using mbed-cli or the online tool and then try this version with PlatformIO.
