A few days ago I compiled Marlin for a SGN L V1 baord and everything worked fine. Then I tried to flash a TFT35 screen with minor success…
Now I tried tho compile Marlin again and I am getting the following issue:
Unable to find destination disk (Autodetect Error)
Please select it in platformio.ini using the upload_port keyword (linkremoved section_env_upload.html) or copy the firmware (.pio/build/LPC1768/firmware.bin) manually to the appropriate disk
> Executing task in folder Marlin-bugfix-2.0.x: linkremoved run <
Processing LPC1768 (platform: linkremoved /archive/0.1.3.zip; board: nxp_lpc1768; framework: arduino)
---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Tool Manager: Installing toolchain-gccarmnoneeabi @ >=1.90000
Tool Manager: Warning! More than one package has been found by toolchain-gccarmnoneeabi @ >=1.90000 requirements:
- platformio/toolchain-gccarmnoneeabi @ 1.50401.210106
- maxgerhardt/toolchain-gccarmnoneeabi @ 1.40903.0
Tool Manager: Please specify detailed REQUIREMENTS using package owner and version (showed above) to avoid name conflicts
Tool Manager: toolchain-gccarmnoneeabi @ 1.90301.200702 has been installed!
CONFIGURATION: linkremoved nxplpc-arduino-lpc176x/nxp_lpc1768.html
PLATFORM: NXP Arduino LPC176x (0.1.3) > NXP LPC1768
HARDWARE: LPC1768 100MHz, 31.97KB RAM, 464KB Flash
DEBUG: Current (jlink) On-board (cmsis-dap) External (blackmagic, jlink)
- framework-arduino-lpc176x 0.2.6
- toolchain-gccarmnoneeabi 1.90301.200702 (9.3.1)
Converting Marlin.ino
LDF Modes: Finder ~ off, Compatibility ~ strict
Found 1 compatible libraries
|-- <Servo> 1.0.0
Please select it in platformio.ini using the upload_port keyword (https://docs.platformio.org/en/latest/projectconf/section_env_upload.html) or copy the firmware (.pio/build/LPC1768/firmware.bin) manually to the appropriate disk
Linking .pio\build\LPC1768\firmware.elf
c:/users/m/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/bin/ld.exe: region RAM overflowed with stack
*** [.pio\build\LPC1768\firmware.elf] Error 1
================================================================================================= [FAILED] Took 163.69 seconds =================================================================================================
Environment Status Duration
LPC1768 FAILED 00:02:43.689
============================================================================================= 1 failed, 0 succeeded in 00:02:43.689 =============================================================================================The terminal process "linkremoved 'run'" terminated with exit code: 1.
linkremoved because I am a new user.
I have already deleted the C:\Users\<user>\.platformio\
folder reinstalled everything and removed some Win updates…
Thanks a lot!
Mike
